Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/58903 )
Change subject: mb/purism/librem_skl: Clean up hda_verb.c ......................................................................
Use the `AZALIA_RESET` macro, write hex values in lowercase and remove redundant comments. Also express verb length in decimal.
Tested with BUILD_TIMELESS=1, Purism Librem 15 v4 remains identical.
Change-Id: Id9f5ff9614a8f8c0b7f3a3c633a1dcdda8c5876c Signed-off-by: Angel Pons th3fanbus@gmail.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/58903 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Matt DeVillier matt.devillier@gmail.com --- M src/mainboard/purism/librem_skl/hda_verb.c 1 file changed, 6 insertions(+), 38 deletions(-)
Approvals: build bot (Jenkins): Verified Matt DeVillier: Looks good to me, approved
diff --git a/src/mainboard/purism/librem_skl/hda_verb.c b/src/mainboard/purism/librem_skl/hda_verb.c index d273968..ae76fb3 100644 --- a/src/mainboard/purism/librem_skl/hda_verb.c +++ b/src/mainboard/purism/librem_skl/hda_verb.c @@ -6,52 +6,20 @@ /* coreboot specific header */ 0x10ec0269, /* Codec Vendor / Device ID: Realtek ALC269 */ 0x19910269, /* Subsystem ID */ - 0x0000000c, /* Number of jacks (NID entries) */ + 12, /* Number of jacks (NID entries) */
- 0x0017ff00, /* Function Reset */ - 0x0017ff00, /* Double Function Reset */ - 0x0017ff00, - 0x0017ff00, - - /* Bits 31:28 - Codec Address */ - /* Bits 27:20 - NID */ - /* Bits 19:8 - Verb ID */ - /* Bits 7:0 - Payload */ - - /* NID 0x01, HDA Codec Subsystem ID Verb Table: 0x19910269 */ + AZALIA_RESET(1), AZALIA_SUBVENDOR(0, 0x19910269), - - /* Pin Widget Verb Table */ - - /* Pin Complex (NID 0x12) */ AZALIA_PIN_CFG(0, 0x12, 0x40000000), - - /* Pin Complex (NID 0x14) */ AZALIA_PIN_CFG(0, 0x14, 0x90170110), - - /* Pin Complex (NID 0x15) */ AZALIA_PIN_CFG(0, 0x15, 0x04214020), - - /* Pin Complex (NID 0x17) */ AZALIA_PIN_CFG(0, 0x17, 0x411111f0), - - /* Pin Complex (NID 0x18) */ AZALIA_PIN_CFG(0, 0x18, 0x04a19040), - - /* Pin Complex (NID 0x19) */ AZALIA_PIN_CFG(0, 0x19, 0x90a70130), - - /* Pin Complex (NID 0x1A) */ - AZALIA_PIN_CFG(0, 0x1A, 0x411111f0), - - /* Pin Complex (NID 0x1B) */ - AZALIA_PIN_CFG(0, 0x1B, 0x411111f0), - - /* Pin Complex (NID 0x1D) */ - AZALIA_PIN_CFG(0, 0x1D, 0x40548505), - - /* Pin Complex (NID 0x1E) */ - AZALIA_PIN_CFG(0, 0x1E, 0x411111f0), + AZALIA_PIN_CFG(0, 0x1a, 0x411111f0), + AZALIA_PIN_CFG(0, 0x1b, 0x411111f0), + AZALIA_PIN_CFG(0, 0x1d, 0x40548505), + AZALIA_PIN_CFG(0, 0x1e, 0x411111f0), };
const u32 pc_beep_verbs[] = {};
