Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/78279?usp=email )
Change subject: mb/google/rex/var/rex0: update thermal settings to start fan earlier ......................................................................
Internal testing showed that CPU heatsink gets hot and temperature goes over 75C. In this situation, the fan does not even start to lower down CPU temperature. This is because of existing temperature thresholds of TSR0 and TSR1 sensors are set at 45C to start fan. With updated new settings based on tuning from thermal team, the fan starts early at 43C for TSR0 and TSR1 so the CPU temperature stays below 75C.
BUG=b:302673874 TEST=Built and tested on google/rex board
Signed-off-by: Sumeet Pawnikar sumeet.r.pawnikar@intel.com Change-Id: I6580652d6165946e98ecf1b46ace3352cd34dcdf Reviewed-on: https://review.coreboot.org/c/coreboot/+/78279 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Eric Lai ericllai@google.com --- M src/mainboard/google/rex/variants/rex0/overridetree.cb 1 file changed, 14 insertions(+), 14 deletions(-)
Approvals: build bot (Jenkins): Verified Eric Lai: Looks good to me, approved
diff --git a/src/mainboard/google/rex/variants/rex0/overridetree.cb b/src/mainboard/google/rex/variants/rex0/overridetree.cb index 1d4ba63..034a694 100644 --- a/src/mainboard/google/rex/variants/rex0/overridetree.cb +++ b/src/mainboard/google/rex/variants/rex0/overridetree.cb @@ -186,25 +186,25 @@ [0] = { .target = DPTF_TEMP_SENSOR_0, .thresholds = { - TEMP_PCT(75, 90), - TEMP_PCT(70, 80), - TEMP_PCT(65, 70), - TEMP_PCT(60, 60), - TEMP_PCT(55, 50), - TEMP_PCT(50, 40), - TEMP_PCT(45, 30), + TEMP_PCT(70, 97), + TEMP_PCT(65, 90), + TEMP_PCT(60, 80), + TEMP_PCT(55, 75), + TEMP_PCT(50, 65), + TEMP_PCT(45, 45), + TEMP_PCT(43, 30), } }, [1] = { .target = DPTF_TEMP_SENSOR_1, .thresholds = { - TEMP_PCT(75, 90), - TEMP_PCT(70, 80), - TEMP_PCT(65, 70), - TEMP_PCT(60, 60), - TEMP_PCT(55, 50), - TEMP_PCT(50, 40), - TEMP_PCT(45, 30), + TEMP_PCT(70, 97), + TEMP_PCT(65, 90), + TEMP_PCT(60, 80), + TEMP_PCT(55, 75), + TEMP_PCT(50, 65), + TEMP_PCT(45, 45), + TEMP_PCT(43, 30), } }, [2] = {
