Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/65384 )
Change subject: mb/system76/adl: Add Lemur Pro 11 as a variant ......................................................................
The Lemur Pro 11 (lemp11) is an Alder Lake-U board.
Tested with a custom TianoCore UefiPayloadPkg.
Working:
- PS/2 keyboard, touchpad - DIMM slot (with NMSO480E82-3200EA00) - M.2 NVMe SSD (with MZVL2500HCJQ) - M.2 SATA SSD (with WDS100T2B0B) - All USB ports - SD card reader - Webcam - WiFi/Bluetooth - Integrated graphics using Intel GOP driver - HDMI output - DisplayPort output over USB-C - Internal microphone - Internal speakers - Combined headset + mic 3.5mm audio - S0ix suspend/resume - Booting Pop!_OS Linux 22.04 with kernel 6.1.11 - Internal flashing with flashrom v1.2-1203-gf4ddd3234330
Not working:
- On-board RAM: Requires CB:65567 - Detection of devices in TBT slot on boot
Change-Id: Ic930df1ebacc8c7ef14dbb6c67a97eddb918b365 Signed-off-by: Tim Crawford tcrawford@system76.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/65384 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Jeremy Soller jeremy@system76.com --- M Documentation/mainboard/index.md A Documentation/mainboard/system76/lemp11.md M src/mainboard/system76/adl/Kconfig M src/mainboard/system76/adl/Kconfig.name M src/mainboard/system76/adl/Makefile.inc A src/mainboard/system76/adl/spd/samsung-P4AAF165WA-BCWDE.spd.hex A src/mainboard/system76/adl/variants/lemp11/board_info.txt A src/mainboard/system76/adl/variants/lemp11/data.vbt A src/mainboard/system76/adl/variants/lemp11/gpio.c A src/mainboard/system76/adl/variants/lemp11/gpio_early.c A src/mainboard/system76/adl/variants/lemp11/hda_verb.c A src/mainboard/system76/adl/variants/lemp11/overridetree.cb A src/mainboard/system76/adl/variants/lemp11/romstage.c 13 files changed, 601 insertions(+), 1 deletion(-)
Approvals: build bot (Jenkins): Verified Jeremy Soller: Looks good to me, approved
diff --git a/Documentation/mainboard/index.md b/Documentation/mainboard/index.md index a1cd9f5..342a1f1 100644 --- a/Documentation/mainboard/index.md +++ b/Documentation/mainboard/index.md @@ -211,6 +211,7 @@ - [Gazelle 16](system76/gaze16.md) - [Lemur Pro 9](system76/lemp9.md) - [Lemur Pro 10](system76/lemp10.md) +- [Lemur Pro 11](system76/lemp11.md) - [Oryx Pro 5](system76/oryp5.md) - [Oryx Pro 6](system76/oryp6.md) - [Oryx Pro 7](system76/oryp7.md) diff --git a/Documentation/mainboard/system76/lemp11.md b/Documentation/mainboard/system76/lemp11.md new file mode 100644 index 0000000..f05d63a --- /dev/null +++ b/Documentation/mainboard/system76/lemp11.md @@ -0,0 +1,62 @@ +# System76 Lemur Pro 11 (lemp11) + +## Specs + +- CPU + - Intel Core i5-1235U + - Intel Core i7-1255U +- EC + - ITE IT5570E running [System76 EC](https://github.com/system76/ec) +- Graphics + - Intel Iris Xe Graphics + - eDP 14.0" 1920x1080@60Hz LCD + - 1x HDMI 2.1 + - 1x DisplayPort 1.4 over USB-C +- Memory + - Channel 0: 8-GB on-board DDR4 (Samsung K4AAG165WA-BCWE) + - Channel 1: 8-GB/16-GB/32-GB DDR4 SO-DIMM @ 3200 MHz +- Networking + - M.2 NVMe/CNVi WiFi/Bluetooth (Intel Wi-Fi 6 AX200/201) +- Power + - 65W (19V, 3.42A) AC barrel adapter (AcBel ADA012) + - USB-C charging, compatible with 65W+ chargers + - 73Wh 4-cell Lithium-ion battery (L140BAT-4) +- Sound + - Realtek ALC256 codec + - Internal speakers and microphone + - Combined 3.5 mm headphone/microphone jack + - HDMI, USB-C DisplayPort audio +- Storage + - M.2 PCIe NVMe Gen 4 SSD + - M.2 PCIe NVMe Gen 3 or SATA 3 SSD + - MicroSD card reader (RTS5227S) +- USB + - 1x USB Type-C with Thunderbolt 4 + - 1x USB 3.2 (Gen 2) Type-A + - 1x USB 3.2 (Gen 1) Type-A +- Dimensions + - 1.65cm x 32.2cm x 21.68cm, 1.15kg + +## Flashing coreboot + +```eval_rst ++---------------------+---------------------+ +| Type | Value | ++=====================+=====================+ +| Socketed flash | no | ++---------------------+---------------------+ +| Vendor | Macronix | ++---------------------+---------------------+ +| Model | MX25L25673G | ++---------------------+---------------------+ +| Size | 32 MiB | ++---------------------+---------------------+ +| Package | WSON-8 | ++---------------------+---------------------+ +| Internal flashing | yes | ++---------------------+---------------------+ +| External flashing | yes | ++---------------------+---------------------+ +``` + +The flash chip (U41) is left of the DIMM slot. diff --git a/src/mainboard/system76/adl/Kconfig b/src/mainboard/system76/adl/Kconfig index a450534..9329ee0 100644 --- a/src/mainboard/system76/adl/Kconfig +++ b/src/mainboard/system76/adl/Kconfig @@ -1,4 +1,4 @@ -if BOARD_SYSTEM76_DARP8 || BOARD_SYSTEM76_GALP6 +if BOARD_SYSTEM76_DARP8 || BOARD_SYSTEM76_GALP6 || BOARD_SYSTEM76_LEMP11
config BOARD_SPECIFIC_OPTIONS def_bool y @@ -11,6 +11,7 @@ select HAVE_ACPI_TABLES select HAVE_CMOS_DEFAULT select HAVE_OPTION_TABLE + select HAVE_SPD_IN_CBFS if BOARD_SYSTEM76_LEMP11 select INTEL_GMA_HAVE_VBT select INTEL_LPSS_UART_FOR_CONSOLE select MAINBOARD_HAS_TPM2 @@ -29,6 +30,7 @@ config VARIANT_DIR default "darp8" if BOARD_SYSTEM76_DARP8 default "galp6" if BOARD_SYSTEM76_GALP6 + default "lemp11" if BOARD_SYSTEM76_LEMP11
config OVERRIDE_DEVICETREE default "variants/$(CONFIG_VARIANT_DIR)/overridetree.cb" @@ -36,14 +38,17 @@ config MAINBOARD_PART_NUMBER default "darp8" if BOARD_SYSTEM76_DARP8 default "galp6" if BOARD_SYSTEM76_GALP6 + default "lemp11" if BOARD_SYSTEM76_LEMP11
config MAINBOARD_SMBIOS_PRODUCT_NAME default "Darter Pro" if BOARD_SYSTEM76_DARP8 default "Galago Pro" if BOARD_SYSTEM76_GALP6 + default "Lemur Pro" if BOARD_SYSTEM76_LEMP11
config MAINBOARD_VERSION default "darp8" if BOARD_SYSTEM76_DARP8 default "galp6" if BOARD_SYSTEM76_GALP6 + default "lemp11" if BOARD_SYSTEM76_LEMP11
config CBFS_SIZE default 0xA00000 diff --git a/src/mainboard/system76/adl/Kconfig.name b/src/mainboard/system76/adl/Kconfig.name index 5e3aee3..fa0b28b 100644 --- a/src/mainboard/system76/adl/Kconfig.name +++ b/src/mainboard/system76/adl/Kconfig.name @@ -3,3 +3,6 @@
config BOARD_SYSTEM76_GALP6 bool "galp6" + +config BOARD_SYSTEM76_LEMP11 + bool "lemp11" diff --git a/src/mainboard/system76/adl/Makefile.inc b/src/mainboard/system76/adl/Makefile.inc index 8989d5c..f3dc7e1 100644 --- a/src/mainboard/system76/adl/Makefile.inc +++ b/src/mainboard/system76/adl/Makefile.inc @@ -8,3 +8,5 @@ ramstage-y += ramstage.c ramstage-y += variants/$(VARIANT_DIR)/hda_verb.c ramstage-y += variants/$(VARIANT_DIR)/gpio.c + +SPD_SOURCES = samsung-P4AAF165WA-BCWDE diff --git a/src/mainboard/system76/adl/spd/samsung-P4AAF165WA-BCWDE.spd.hex b/src/mainboard/system76/adl/spd/samsung-P4AAF165WA-BCWDE.spd.hex new file mode 100644 index 0000000..28e4a61 --- /dev/null +++ b/src/mainboard/system76/adl/spd/samsung-P4AAF165WA-BCWDE.spd.hex @@ -0,0 +1,33 @@ +# Samsung P4AAF165WA-BCWDE +23 11 0C 03 46 29 00 08 00 60 00 03 02 03 00 00 +00 00 05 0D F8 FF 02 00 6E 6E 6E 11 00 6E 30 11 +F0 0A 20 08 00 F0 2B 34 28 00 78 00 14 3C 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 16 36 0B 35 +16 36 0B 35 00 00 16 36 0B 35 16 36 0B 35 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 9C B5 00 00 00 00 E7 00 DE DE +0F 11 02 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 DB 08 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +80 CE 00 00 00 00 00 00 00 50 34 41 41 46 31 36 +35 57 41 2D 42 43 57 44 45 20 20 20 20 00 80 CE +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 +00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 diff --git a/src/mainboard/system76/adl/variants/lemp11/board_info.txt b/src/mainboard/system76/adl/variants/lemp11/board_info.txt new file mode 100644 index 0000000..301c2d3 --- /dev/null +++ b/src/mainboard/system76/adl/variants/lemp11/board_info.txt @@ -0,0 +1,2 @@ +Board name: lemp11 +Release year: 2022 diff --git a/src/mainboard/system76/adl/variants/lemp11/data.vbt b/src/mainboard/system76/adl/variants/lemp11/data.vbt new file mode 100644 index 0000000..3d822c3 --- /dev/null +++ b/src/mainboard/system76/adl/variants/lemp11/data.vbt Binary files differ diff --git a/src/mainboard/system76/adl/variants/lemp11/gpio.c b/src/mainboard/system76/adl/variants/lemp11/gpio.c new file mode 100644 index 0000000..e8eb1e2 --- /dev/null +++ b/src/mainboard/system76/adl/variants/lemp11/gpio.c @@ -0,0 +1,227 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ + +#include <mainboard/gpio.h> +#include <soc/gpio.h> + +static const struct pad_config gpio_table[] = { + /* ------- GPIO Group GPD ------- */ + PAD_CFG_NF(GPD0, UP_20K, PWROK, NF1), // PM_BATLOW# + PAD_CFG_NF(GPD1, NATIVE, PWROK, NF1), // AC_PRESENT + PAD_NC(GPD2, NONE), + PAD_CFG_NF(GPD3, UP_20K, PWROK, NF1), // PWR_BTN# + PAD_CFG_NF(GPD4, NONE, PWROK, NF1), // SUSB#_PCH + PAD_CFG_NF(GPD5, NONE, PWROK, NF1), // SUSC#_PCH + PAD_CFG_NF(GPD6, NONE, PWROK, NF1), // SLP_A# + PAD_CFG_GPI(GPD7, NONE, PWROK), // GPD7_REST + PAD_CFG_NF(GPD8, NONE, PWROK, NF1), // SUS_CLK + PAD_CFG_GPO(GPD9, 0, PWROK), // SLP_WLAN# + PAD_CFG_NF(GPD10, NONE, PWROK, NF1), // SLP_S5# + PAD_NC(GPD11, NONE), + + /* ------- GPIO Group GPP_A ------- */ + PAD_CFG_NF(GPP_A0, UP_20K, DEEP, NF1), // ESPI_IO0_EC + PAD_CFG_NF(GPP_A1, UP_20K, DEEP, NF1), // ESPI_IO1_EC + PAD_CFG_NF(GPP_A2, UP_20K, DEEP, NF1), // ESPI_IO2_EC + PAD_CFG_NF(GPP_A3, UP_20K, DEEP, NF1), // ESPI_IO3_EC + PAD_CFG_NF(GPP_A4, UP_20K, DEEP, NF1), // ESPI_CS_EC# + PAD_CFG_NF(GPP_A5, UP_20K, DEEP, NF1), // ESPI_ALRT0# + PAD_NC(GPP_A6, NONE), + PAD_NC(GPP_A7, NONE), + PAD_NC(GPP_A8, NONE), + PAD_CFG_NF(GPP_A9, DN_20K, DEEP, NF1), // ESPI_CLK_EC + PAD_CFG_NF(GPP_A10, NONE, DEEP, NF1), // ESPI_RESET# + PAD_NC(GPP_A11, NONE), + PAD_CFG_NF(GPP_A12, UP_20K, DEEP, NF1), // SATAGP1 + PAD_CFG_GPO(GPP_A13, 1, PLTRST), // PCH_BT_EN + PAD_NC(GPP_A14, NONE), + PAD_NC(GPP_A15, NONE), + PAD_CFG_NF(GPP_A16, NONE, DEEP, NF1), // USB_OC3# + PAD_NC(GPP_A17, NONE), + PAD_CFG_NF(GPP_A18, NONE, DEEP, NF1), // HDMI_HPD + PAD_NC(GPP_A19, NONE), + PAD_NC(GPP_A20, NONE), + PAD_NC(GPP_A21, NONE), + PAD_CFG_GPI(GPP_A22, NONE, DEEP), // SSD2_PCIE_WAKE# + PAD_NC(GPP_A23, NONE), + + /* ------- GPIO Group GPP_B ------- */ + PAD_CFG_NF(GPP_B0, NONE, DEEP, NF1), // VCCIN_AUX_VID0 + PAD_CFG_NF(GPP_B1, NONE, DEEP, NF1), // VCCIN_AUX_VID1 + PAD_CFG_NF(GPP_B2, NONE, DEEP, NF1), // VRALERT# + PAD_CFG_GPI(GPP_B3, NONE, DEEP), // SCI# + PAD_CFG_GPI(GPP_B4, NONE, DEEP), // SWI# + PAD_NC(GPP_B5, NONE), + PAD_NC(GPP_B6, NONE), + PAD_NC(GPP_B7, NONE), + PAD_NC(GPP_B8, NONE), + // GPP_B9 missing + // GPP_B10 missing + PAD_CFG_NF(GPP_B11, NONE, PWROK, NF1), // TBT_I2C_INT + PAD_CFG_NF(GPP_B12, NONE, DEEP, NF1), // SLP_S0# + PAD_CFG_NF(GPP_B13, NONE, DEEP, NF1), // PLT_RST# + PAD_CFG_NF(GPP_B14, NONE, DEEP, NF1), // Top swap override + PAD_NC(GPP_B15, NONE), + PAD_NC(GPP_B16, NONE), + PAD_CFG_GPO(GPP_B17, 1, PLTRST), // WLAN_RST# + PAD_NC(GPP_B18, NONE), // NO REBOOT strap + // GPP_B19 missing + // GPP_B20 missing + // GPP_B21 missing + // GPP_B22 missing + PAD_NC(GPP_B23, NONE), // CPUNSSC CLOCK FREQ strap + + /* ------- GPIO Group GPP_C ------- */ + PAD_CFG_NF(GPP_C0, NONE, DEEP, NF1), // SMB_CLK_DDR + PAD_CFG_NF(GPP_C1, NONE, DEEP, NF1), // CMB_DATA_DDR + PAD_CFG_GPO(GPP_C2, 1, PLTRST), // TLS CONFIDENTIALITY strap + PAD_CFG_NF(GPP_C3, NONE, DEEP, NF1), // SML0_CLK + PAD_CFG_NF(GPP_C4, NONE, DEEP, NF1), // SML0_DATA + PAD_NC(GPP_C5, NONE), // ESPI OR EC LESS strap + PAD_CFG_NF(GPP_C6, NONE, DEEP, NF1), // TBT_I2C_SCL + PAD_CFG_NF(GPP_C7, NONE, DEEP, NF1), // TBT_I2C_SDA + // GPP_C8 missing + // GPP_C9 missing + // GPP_C10 missing + // GPP_C11 missing + // GPP_C12 missing + // GPP_C13 missing + // GPP_C14 missing + // GPP_C15 missing + // GPP_C16 missing + // GPP_C17 missing + // GPP_C18 missing + // GPP_C19 missing + // GPP_C20 missing + // GPP_C21 missing + // GPP_C22 missing + // GPP_C23 missing + + /* ------- GPIO Group GPP_D ------- */ + PAD_CFG_GPO(GPP_D0, 1, DEEP), // SB_BLON + PAD_CFG_GPI(GPP_D1, NONE, DEEP), // SB_KBCRST# + PAD_CFG_GPO(GPP_D2, 0, DEEP), // ROM_I2C_EN + PAD_NC(GPP_D3, NONE), + PAD_NC(GPP_D4, NONE), + // GPP_D5 (SSD0_CLKREQ#) configured by FSP + // GPP_D6 (SSD1_CLKREQ#) configured by FSP + // GPP_D7 (WLAN_CLKREQ#) configured by FSP + PAD_NC(GPP_D8, NONE), + PAD_NC(GPP_D9, NONE), + PAD_NC(GPP_D10, NONE), + PAD_NC(GPP_D11, NONE), + PAD_NC(GPP_D12, NONE), + PAD_CFG_GPI(GPP_D13, NONE, DEEP), // WLAN_WAKEUP# + PAD_CFG_GPO(GPP_D14, 1, PLTRST), // SSD2_PWR_EN + PAD_NC(GPP_D15, NONE), + PAD_CFG_GPO(GPP_D16, 1, DEEP), // SSD1_PWR_EN + PAD_NC(GPP_D17, NONE), + PAD_NC(GPP_D18, NONE), + PAD_CFG_GPO(GPP_D19, 0, DEEP), // SATA_LED# + + /* ------- GPIO Group GPP_E ------- */ + PAD_CFG_GPI(GPP_E0, NONE, DEEP), // CNVI_WAKE# + _PAD_CFG_STRUCT(GPP_E1, 0x40100100, 0x3000), // TPM_PIRQ# + PAD_NC(GPP_E2, NONE), + PAD_CFG_GPO(GPP_E3, 1, PLTRST), // WIFI_RF_EN + PAD_CFG_GPO(GPP_E4, 0, PLTRST), // TBT_FORCE_PWR + PAD_NC(GPP_E5, NONE), + PAD_CFG_GPO(GPP_E6, 0, DEEP), // JTAG ODT DISABLE strap + PAD_CFG_GPI(GPP_E7, NONE, DEEP), // SMI# + PAD_CFG_GPO(GPP_E8, 0, DEEP), // SLP_DRAM# + PAD_CFG_NF(GPP_E9, NONE, DEEP, NF1), // USB_OC0# + PAD_NC(GPP_E10, NONE), + PAD_CFG_GPI(GPP_E11, NONE, DEEP), // BOARD_ID1 + PAD_CFG_GPI_INT(GPP_E12, NONE, PLTRST, LEVEL), // TP_ATTN# + PAD_NC(GPP_E13, NONE), + PAD_CFG_NF(GPP_E14, NONE, DEEP, NF1), // EDP_HPD + PAD_NC(GPP_E15, NONE), + PAD_NC(GPP_E16, NONE), + PAD_NC(GPP_E17, NONE), + // GPP_E18 (TBT_LSX0_TXD) configured by FSP + // GPP_E19 (TBT_LSX0_RXD) configured by FSP + PAD_NC(GPP_E20, NONE), + PAD_NC(GPP_E21, NONE), + PAD_NC(GPP_E22, NONE), + PAD_NC(GPP_E23, NONE), + + /* ------- GPIO Group GPP_F ------- */ + PAD_CFG_NF(GPP_F0, NONE, DEEP, NF1), // CNVI_BRI_DT + PAD_CFG_NF(GPP_F1, UP_20K, DEEP, NF1), // CNVI_BRI_RSP + PAD_CFG_NF(GPP_F2, NONE, DEEP, NF1), // CNVI_RGI_DT + PAD_CFG_NF(GPP_F3, UP_20K, DEEP, NF1), // CNVI_RGI_RSP + PAD_CFG_NF(GPP_F4, NONE, DEEP, NF1), // CNVI_RST# + // GPP_F5 (CNVI_CLKREQ) configured by FSP + PAD_CFG_NF(GPP_F6, NONE, DEEP, NF1), // CNVI_GNSS_PA_BLANKING + PAD_NC(GPP_F7, NONE), // MCRO LDO BYPASS strap + // GPP_F8 missing + PAD_NC(GPP_F9, NONE), + PAD_CFG_GPO(GPP_F10, 1, PLTRST), // CARD_RTD3_RST# + PAD_NC(GPP_F11, NONE), + PAD_NC(GPP_F12, NONE), + PAD_NC(GPP_F13, NONE), + PAD_NC(GPP_F14, NONE), + PAD_NC(GPP_F15, NONE), + PAD_NC(GPP_F16, NONE), + PAD_CFG_GPO(GPP_F17, 1, PLTRST), // GPIO_SDCARD_EN + PAD_CFG_GPO(GPP_F18, 0, DEEP), // CCD_WP# + // GPP_F19 (CARD_CLKREQ#) configured by FSP + PAD_CFG_GPO(GPP_F20, 1, PLTRST), // M2_SSD2_RST# + PAD_NC(GPP_F21, NONE), + PAD_NC(GPP_F22, NONE), + PAD_NC(GPP_F23, NONE), + + /* ------- GPIO Group GPP_H ------- */ + PAD_CFG_GPO(GPP_H0, 1, PLTRST), // MS_SSD1_RST# + PAD_NC(GPP_H1, NONE), + PAD_CFG_GPO(GPP_H2, 1, PLTRST), // WLAN_RST# + PAD_CFG_GPI(GPP_H3, NONE, DEEP), // TPM_DET + PAD_CFG_NF(GPP_H4, NONE, DEEP, NF1), // I2C_SDA_TP + PAD_CFG_NF(GPP_H5, NONE, DEEP, NF1), // I2C_SCL_TP + PAD_CFG_NF(GPP_H6, NONE, DEEP, NF1), // PCH_I2C_SDA + PAD_CFG_NF(GPP_H7, NONE, DEEP, NF1), // PCH_I2C_SCL + PAD_CFG_NF(GPP_H8, NONE, DEEP, NF2), // CNVI_MFUART2_RXD + PAD_CFG_NF(GPP_H9, NONE, DEEP, NF2), // CNVI_MFUART2_TXD + // GPP_H10 (UART0_RX) configured in bootblock + // GPP_H11 (UART0_TX) configured in bootblock + PAD_CFG_NF(GPP_H12, NONE, DEEP, NF1), // SATA1_DEVSLP1 + PAD_NC(GPP_H13, NONE), + // GPP_H14 missing + PAD_CFG_NF(GPP_H15, NONE, DEEP, NF1), // HDMI_CTRLCLK + // GPP_H16 missing + PAD_CFG_NF(GPP_H17, NONE, DEEP, NF1), // HDMI_CTRLDATA + PAD_CFG_NF(GPP_H18, NONE, DEEP, NF1), // CPU_C10_GATE# + PAD_NC(GPP_H19, NONE), + PAD_CFG_GPO(GPP_H20, 0, DEEP), // PM_CLKRUN# + PAD_NC(GPP_H21, NONE), + PAD_NC(GPP_H22, NONE), + PAD_NC(GPP_H23, NONE), + + /* ------- GPIO Group GPP_R ------- */ + PAD_CFG_NF(GPP_R0, NONE, DEEP, NF1), // HDA_BITCLK + PAD_CFG_NF(GPP_R1, NATIVE, DEEP, NF1), // HDA_SYNC + PAD_CFG_NF(GPP_R2, NATIVE, DEEP, NF1), // HDA_SDOUT + PAD_CFG_NF(GPP_R3, NATIVE, DEEP, NF1), // HDA_SDIN0 + PAD_CFG_NF(GPP_R4, NONE, DEEP, NF1), // HDA_RST# + PAD_NC(GPP_R5, NONE), + PAD_NC(GPP_R6, NONE), // DMIC_CLK + PAD_NC(GPP_R7, NONE), // DMIC_DAT + + /* ------- GPIO Group GPP_S ------- */ + PAD_NC(GPP_S0, NONE), + PAD_NC(GPP_S1, NONE), + PAD_NC(GPP_S2, NONE), + PAD_NC(GPP_S3, NONE), + PAD_NC(GPP_S4, NONE), + PAD_NC(GPP_S5, NONE), + PAD_NC(GPP_S6, NONE), + PAD_NC(GPP_S7, NONE), + + /* ------- GPIO Group GPP_T ------- */ + PAD_NC(GPP_T2, NONE), + PAD_NC(GPP_T3, NONE), +}; + +void mainboard_configure_gpios(void) +{ + gpio_configure_pads(gpio_table, ARRAY_SIZE(gpio_table)); +} diff --git a/src/mainboard/system76/adl/variants/lemp11/gpio_early.c b/src/mainboard/system76/adl/variants/lemp11/gpio_early.c new file mode 100644 index 0000000..c80c798 --- /dev/null +++ b/src/mainboard/system76/adl/variants/lemp11/gpio_early.c @@ -0,0 +1,14 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ + +#include <mainboard/gpio.h> +#include <soc/gpio.h> + +static const struct pad_config early_gpio_table[] = { + PAD_CFG_NF(GPP_H10, NONE, DEEP, NF1), // UART0_RX + PAD_CFG_NF(GPP_H11, NONE, DEEP, NF1), // UART0_TX +}; + +void mainboard_configure_early_gpios(void) +{ + gpio_configure_pads(early_gpio_table, ARRAY_SIZE(early_gpio_table)); +} diff --git a/src/mainboard/system76/adl/variants/lemp11/hda_verb.c b/src/mainboard/system76/adl/variants/lemp11/hda_verb.c new file mode 100644 index 0000000..d03c67a --- /dev/null +++ b/src/mainboard/system76/adl/variants/lemp11/hda_verb.c @@ -0,0 +1,25 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ + +#include <device/azalia_device.h> + +const u32 cim_verb_data[] = { + /* Realtek, ALC256 */ + 0x10ec0256, + 0x15587718, + 11, + AZALIA_SUBVENDOR(0, 0x15587718), + AZALIA_PIN_CFG(0, 0x12, 0x90a60130), + AZALIA_PIN_CFG(0, 0x13, 0x40000000), + AZALIA_PIN_CFG(0, 0x14, 0x90170110), + AZALIA_PIN_CFG(0, 0x18, 0x411111f0), + AZALIA_PIN_CFG(0, 0x19, 0x411111f0), + AZALIA_PIN_CFG(0, 0x1a, 0x411111f0), + AZALIA_PIN_CFG(0, 0x1b, 0x411111f0), + AZALIA_PIN_CFG(0, 0x1d, 0x41700001), + AZALIA_PIN_CFG(0, 0x1e, 0x411111f0), + AZALIA_PIN_CFG(0, 0x21, 0x02211020), +}; + +const u32 pc_beep_verbs[] = {}; + +AZALIA_ARRAY_SIZES; diff --git a/src/mainboard/system76/adl/variants/lemp11/overridetree.cb b/src/mainboard/system76/adl/variants/lemp11/overridetree.cb new file mode 100644 index 0000000..82943cb --- /dev/null +++ b/src/mainboard/system76/adl/variants/lemp11/overridetree.cb @@ -0,0 +1,161 @@ +chip soc/intel/alderlake + register "power_limits_config[ADL_P_142_242_282_15W_CORE]" = "{ + .tdp_pl1_override = 15, + .tdp_pl2_override = 46, + .tdp_pl4 = 65, + }" + + # GPE configuration + register "pmc_gpe0_dw0" = "PMC_GPP_A" + register "pmc_gpe0_dw1" = "PMC_GPP_R" + register "pmc_gpe0_dw2" = "PMC_GPD" + + device domain 0 on + subsystemid 0x1558 0x7718 inherit + + device ref pcie4_0 on + # PCIe PEG0 x4, Clock 0 (SSD2) + register "cpu_pcie_rp[CPU_RP(1)]" = "{ + .clk_src = 0, + .clk_req = 0, + .flags = PCIE_RP_LTR | PCIE_RP_AER, + }" + chip soc/intel/common/block/pcie/rtd3 + register "enable_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_HIGH(GPP_D14)" # SSD2_PWR_EN + register "reset_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_F20)" # M2_CPU_SSD2_RST# + register "srcclk_pin" = "0" # SSD0_CLKREQ# + device generic 0 on end + end + end + device ref tcss_xhci on + register "tcss_ports[0]" = "TCSS_PORT_DEFAULT(OC_SKIP)" + chip drivers/usb/acpi + device ref tcss_root_hub on + chip drivers/usb/acpi + register "desc" = ""TBT Type-C"" + register "type" = "UPC_TYPE_C_USB2_SS_SWITCH" + device ref tcss_usb3_port1 on end + end + end + end + end + device ref xhci on + # USB2 + register "usb2_ports[0]" = "USB2_PORT_MID(OC_SKIP)" # Type-A Left + register "usb2_ports[1]" = "USB2_PORT_MID(OC_SKIP)" # Type-A Right + register "usb2_ports[2]" = "USB2_PORT_TYPE_C(OC_SKIP)" # J_TYPEC1 + register "usb2_ports[3]" = "USB2_PORT_MID(OC_SKIP)" # 3G/LTE + register "usb2_ports[6]" = "USB2_PORT_MID(OC_SKIP)" # Camera + register "usb2_ports[9]" = "USB2_PORT_MID(OC_SKIP)" # Bluetooth + # USB3 + register "usb3_ports[0]" = "USB3_PORT_DEFAULT(OC_SKIP)" # Type-A Left + register "usb3_ports[1]" = "USB3_PORT_DEFAULT(OC_SKIP)" # Type-A Right + register "usb3_ports[3]" = "USB3_PORT_DEFAULT(OC_SKIP)" # 3G/LTE + # ACPI + chip drivers/usb/acpi + device ref xhci_root_hub on + chip drivers/usb/acpi + register "desc" = ""USB2 Type-A Left"" + register "type" = "UPC_TYPE_A" + device ref usb2_port1 on end + end + chip drivers/usb/acpi + register "desc" = ""USB2 Type-A Right"" + register "type" = "UPC_TYPE_A" + device ref usb2_port2 on end + end + chip drivers/usb/acpi + register "desc" = ""USB2 Type-C"" + register "type" = "UPC_TYPE_C_USB2_SS_SWITCH" + device ref usb2_port3 on end + end + chip drivers/usb/acpi + register "desc" = ""USB2 3G/LTE"" + register "type" = "UPC_TYPE_INTERNAL" + device ref usb2_port4 on end + end + chip drivers/usb/acpi + register "desc" = ""USB2 Camera"" + register "type" = "UPC_TYPE_INTERNAL" + device ref usb2_port7 on end + end + chip drivers/usb/acpi + register "desc" = ""USB2 Bluetooth"" + register "type" = "UPC_TYPE_INTERNAL" + device ref usb2_port10 on end + end + chip drivers/usb/acpi + register "desc" = ""USB3 Type-A Left"" + register "type" = "UPC_TYPE_A" + device ref usb3_port1 on end + end + chip drivers/usb/acpi + register "desc" = ""USB3 Type-A Right"" + register "type" = "UPC_TYPE_A" + device ref usb3_port2 on end + end + chip drivers/usb/acpi + register "desc" = ""USB3 Type-C"" + register "type" = "UPC_TYPE_C_USB2_SS_SWITCH" + device ref usb3_port3 on end + end + end + end + end + device ref tcss_dma0 on + chip drivers/intel/usb4/retimer + register "dfp[0].power_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_HIGH(GPP_E4)" + use tcss_usb3_port1 as dfp[0].typec_port + device generic 0 on end + end + end + device ref pcie_rp5 on + # PCIe RP#5 x1, Clock 2 (WLAN) + register "pch_pcie_rp[PCH_RP(5)]" = "{ + .clk_src = 2, + .clk_req = 2, + .flags = PCIE_RP_LTR | PCIE_RP_AER, + }" + chip soc/intel/common/block/pcie/rtd3 + register "enable_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_HIGH(GPP_A13)" # PCH_BT_EN + register "reset_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_B17)" # WLAN_RST# + register "srcclk_pin" = "2" # WLAN_CLKREQ# + device generic 0 on end + end + end + device ref pcie_rp6 on + # PCIe RP#6 x1, Clock 6 (CARD) + register "pch_pcie_rp[PCH_RP(6)]" = "{ + .clk_src = 6, + .clk_req = 6, + .flags = PCIE_RP_HOTPLUG | PCIE_RP_LTR | PCIE_RP_AER, + }" + end + device ref pcie_rp9 on + # PCIe RP#9 x4, Clock 1 (SSD1) + register "pch_pcie_rp[PCH_RP(9)]" = "{ + .clk_src = 1, + .clk_req = 1, + .flags = PCIE_RP_LTR, + }" + chip soc/intel/common/block/pcie/rtd3 + register "enable_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_HIGH(GPP_D16)" # SSD1_PWR_EN + register "reset_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_H0)" # M2_SSD1_RST# + register "srcclk_pin" = "1" # SSD1_CLKREQ# + device generic 0 on end + end + end + device ref pmc hidden + chip drivers/intel/pmc_mux + device generic 0 on + chip drivers/intel/pmc_mux/conn + # J_TYPEC1 + use usb2_port3 as usb2_port + use tcss_usb3_port1 as usb3_port + device generic 0 alias conn0 on end + end + end + end + end + end +end diff --git a/src/mainboard/system76/adl/variants/lemp11/romstage.c b/src/mainboard/system76/adl/variants/lemp11/romstage.c new file mode 100644 index 0000000..989b5df --- /dev/null +++ b/src/mainboard/system76/adl/variants/lemp11/romstage.c @@ -0,0 +1,23 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ + +#include <soc/meminit.h> +#include <soc/romstage.h> + +void mainboard_memory_init_params(FSPM_UPD *mupd) +{ + const struct mb_cfg board_cfg = { + .type = MEM_TYPE_DDR4, + }; + const struct mem_spd spd_info = { + .topo = MEM_TOPO_MIXED, + .cbfs_index = 0, + .smbus[1] = { .addr_dimm[0] = 0x52, }, + }; + const bool half_populated = false; + + mupd->FspmConfig.PchHdaAudioLinkHdaEnable = 1; + mupd->FspmConfig.DmiMaxLinkSpeed = 4; + mupd->FspmConfig.GpioOverride = 0; + + memcfg_init(mupd, &board_cfg, &spd_info, half_populated); +}
