Leo Chou has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/81347?usp=email )
Change subject: mb/google/nissa: Create sundance variant ......................................................................
Create the sundance variant of nissa reference board by copying the template files to a new directory named for the variant.
Due to new_variant.py limitation that repo can no longer be used in inside, created this CL manually following google suggestion.
BUG=b:328505938
Change-Id: Ia8ba318f18d2cac69898687311631778e61bf2ea Signed-off-by: leo.chou leo.chou@lcfc.corp-partner.google.com --- M src/mainboard/google/brya/Kconfig M src/mainboard/google/brya/Kconfig.name A src/mainboard/google/brya/variants/sundance/data.vbt A src/mainboard/google/brya/variants/sundance/include/variant/ec.h A src/mainboard/google/brya/variants/sundance/include/variant/gpio.h A src/mainboard/google/brya/variants/sundance/memory/Makefile.mk A src/mainboard/google/brya/variants/sundance/memory/dram_id.generated.txt A src/mainboard/google/brya/variants/sundance/memory/mem_parts_used.txt A src/mainboard/google/brya/variants/sundance/overridetree.cb 9 files changed, 43 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/47/81347/1
diff --git a/src/mainboard/google/brya/Kconfig b/src/mainboard/google/brya/Kconfig index e269b9a..2f35b3c 100644 --- a/src/mainboard/google/brya/Kconfig +++ b/src/mainboard/google/brya/Kconfig @@ -695,6 +695,7 @@ default "Glassway" if BOARD_GOOGLE_GLASSWAY default "Nova" if BOARD_GOOGLE_NOVA default "Bujia" if BOARD_GOOGLE_BUJIA + default "Sundance" if BOARD_GOOGLE_SUNDANCE
config VARIANT_DIR default "brya0" if BOARD_GOOGLE_BRYA0 @@ -752,6 +753,7 @@ default "glassway" if BOARD_GOOGLE_GLASSWAY default "nova" if BOARD_GOOGLE_NOVA default "bujia" if BOARD_GOOGLE_BUJIA + default "sundance" if BOARD_GOOGLE_SUNDANCE
config VBOOT select VBOOT_EARLY_EC_SYNC if !BOARD_GOOGLE_BASEBOARD_NISSA diff --git a/src/mainboard/google/brya/Kconfig.name b/src/mainboard/google/brya/Kconfig.name index e0e752c..ce8b444 100644 --- a/src/mainboard/google/brya/Kconfig.name +++ b/src/mainboard/google/brya/Kconfig.name @@ -166,3 +166,6 @@
config BOARD_GOOGLE_BUJIA bool "-> Bujia" + +config BOARD_GOOGLE_SUNDANCE + bool "-> Sundance" diff --git a/src/mainboard/google/brya/variants/sundance/data.vbt b/src/mainboard/google/brya/variants/sundance/data.vbt new file mode 100644 index 0000000..c510d8c --- /dev/null +++ b/src/mainboard/google/brya/variants/sundance/data.vbt Binary files differ diff --git a/src/mainboard/google/brya/variants/sundance/include/variant/ec.h b/src/mainboard/google/brya/variants/sundance/include/variant/ec.h new file mode 100644 index 0000000..7a2a6ff --- /dev/null +++ b/src/mainboard/google/brya/variants/sundance/include/variant/ec.h @@ -0,0 +1,8 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ + +#ifndef __VARIANT_EC_H__ +#define __VARIANT_EC_H__ + +#include <baseboard/ec.h> + +#endif diff --git a/src/mainboard/google/brya/variants/sundance/include/variant/gpio.h b/src/mainboard/google/brya/variants/sundance/include/variant/gpio.h new file mode 100644 index 0000000..c4fe342 --- /dev/null +++ b/src/mainboard/google/brya/variants/sundance/include/variant/gpio.h @@ -0,0 +1,8 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ + +#ifndef VARIANT_GPIO_H +#define VARIANT_GPIO_H + +#include <baseboard/gpio.h> + +#endif diff --git a/src/mainboard/google/brya/variants/sundance/memory/Makefile.mk b/src/mainboard/google/brya/variants/sundance/memory/Makefile.mk new file mode 100644 index 0000000..bace965 --- /dev/null +++ b/src/mainboard/google/brya/variants/sundance/memory/Makefile.mk @@ -0,0 +1,4 @@ +# SPDX-License-Identifier: GPL-2.0-or-later +# This is an auto-generated file. Do not edit!! + +SPD_SOURCES = diff --git a/src/mainboard/google/brya/variants/sundance/memory/dram_id.generated.txt b/src/mainboard/google/brya/variants/sundance/memory/dram_id.generated.txt new file mode 100644 index 0000000..a000b55 --- /dev/null +++ b/src/mainboard/google/brya/variants/sundance/memory/dram_id.generated.txt @@ -0,0 +1,2 @@ +DRAM Part Name ID to assign + diff --git a/src/mainboard/google/brya/variants/sundance/memory/mem_parts_used.txt b/src/mainboard/google/brya/variants/sundance/memory/mem_parts_used.txt new file mode 100644 index 0000000..73c95bf --- /dev/null +++ b/src/mainboard/google/brya/variants/sundance/memory/mem_parts_used.txt @@ -0,0 +1,12 @@ +# This is a CSV file containing a list of memory parts used by this variant. +# One part per line with an optional fixed ID in column 2. +# Only include a fixed ID if it is required for legacy reasons! +# Generated IDs are dependent on the order of parts in this file, +# so new parts must always be added at the end of the file! +# +# Generate an updated Makefile.mk and dram_id.generated.txt by running the +# part_id_gen tool from util/spd_tools. +# See util/spd_tools/README.md for more details and instructions. + +# Part Name + diff --git a/src/mainboard/google/brya/variants/sundance/overridetree.cb b/src/mainboard/google/brya/variants/sundance/overridetree.cb new file mode 100644 index 0000000..a5e2217 --- /dev/null +++ b/src/mainboard/google/brya/variants/sundance/overridetree.cb @@ -0,0 +1,4 @@ +chip soc/intel/alderlake + device domain 0 on + end +end
