Attention is currently required from: Cliff Huang, Patrick Rudolph. Hello build bot (Jenkins), Paul Menzel, Patrick Rudolph,
https://review.coreboot.org/c/coreboot/+/55127
Change subject: soc/intel/common/acpi: add ACPI S0ix _DSM for Intel Power Engine Plug-in ......................................................................
This change adds S0ix device specific method _DSM ( UUID: 57a6512e-3979-4e9d-9708-ff13b2508972) for Intel Power Engine Plug-in.
Alone with this change, two kernel changes are also required: https://chromium-review.googlesource.com/2800280 https://chromium-review.googlesource.com/2800281
Once done, substate_requirement_registers is created under /sys/kernel/debug/pmc_core/ Use: 'cat /sys/kernel/debug/pmc_core/substate_requirement_registers' to check the content.
BUG=b:185437326 brya: _DSM method need to implemented in coreboot for PMC requirement register.
Change-Id: I991662cbebf63bd71139ed37ff2588ba73f30398 Signed-off-by: Cliff Huang cliff.huang@intel.com --- M src/soc/intel/common/block/acpi/Kconfig M src/soc/intel/common/block/acpi/acpi/globalnvs.asl M src/soc/intel/common/block/acpi/acpi/pep.asl 3 files changed, 37 insertions(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/27/55127/5
