Rizwan Qureshi (rizwan.qureshi@intel.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/16312
commit e280a89860e77162f5374db19848ac2871816d8f Author: Rizwan Qureshi rizwan.qureshi@intel.com Date: Wed Aug 24 16:05:32 2016 +0530
driver/intel/fsp2.0: Add External stage cache region helper
If ramstage caching outside CBMEM is enabled i.e CONFIG_CACHE_RELOCATED_RAMSTAGE_OUTSIDE_CBMEM, then a helper function to determine the caching region in SMM should be implemented. Add the same to FSP2.0 driver. FSP1.1 driver had the same implementation hence copied stage_cache.c.
The SoC code should implement the smm_subregion to provide the base and size of the caching region within SMM. The fsp/memmap.h provides the prototype and we will reuse the same from FPS 1.1.
Change-Id: I4412a710391dc0cee044b96403c50260c3534e6f Signed-off-by: Rizwan Qureshi rizwan.qureshi@intel.com --- src/drivers/intel/fsp2_0/Makefile.inc | 2 ++ src/drivers/intel/fsp2_0/include/fsp/memmap.h | 47 +++++++++++++++++++++++++++ src/drivers/intel/fsp2_0/stage_cache.c | 28 ++++++++++++++++ 3 files changed, 77 insertions(+)
diff --git a/src/drivers/intel/fsp2_0/Makefile.inc b/src/drivers/intel/fsp2_0/Makefile.inc index 0a6ae43..79b57f6 100644 --- a/src/drivers/intel/fsp2_0/Makefile.inc +++ b/src/drivers/intel/fsp2_0/Makefile.inc @@ -23,6 +23,7 @@ romstage-$(CONFIG_DISPLAY_UPD_DATA) += upd_display.c romstage-$(CONFIG_VERIFY_HOBS) += hob_verify.c romstage-y += util.c romstage-y += memory_init.c +romstage-$(CONFIG_CACHE_RELOCATED_RAMSTAGE_OUTSIDE_CBMEM) += stage_cache.c
ramstage-y += debug.c ramstage-y += graphics.c @@ -32,6 +33,7 @@ ramstage-$(CONFIG_DISPLAY_HOBS) += hob_display.c ramstage-$(CONFIG_VERIFY_HOBS) += hob_verify.c ramstage-y += notify.c ramstage-y += silicon_init.c +ramstage-$(CONFIG_CACHE_RELOCATED_RAMSTAGE_OUTSIDE_CBMEM) += stage_cache.c ramstage-$(CONFIG_DISPLAY_UPD_DATA) += upd_display.c ramstage-y += util.c
diff --git a/src/drivers/intel/fsp2_0/include/fsp/memmap.h b/src/drivers/intel/fsp2_0/include/fsp/memmap.h new file mode 100644 index 0000000..965bce6 --- /dev/null +++ b/src/drivers/intel/fsp2_0/include/fsp/memmap.h @@ -0,0 +1,47 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2015-2016 Intel Corporation. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#ifndef _COMMON_MEMMAP_H_ +#define _COMMON_MEMMAP_H_ + +#include <types.h> + +/* + * mmap_region_granularity must to return a size which is a positive non-zero + * integer multiple of the SMM size when SMM is in use. When not using SMM, + * this value should be set to 8 MiB. + */ +size_t mmap_region_granularity(void); + +/* Fills in the arguments for the entire SMM region covered by chipset + * protections. e.g. TSEG. */ +void smm_region(void **start, size_t *size); + +enum { + /* SMM handler area. */ + SMM_SUBREGION_HANDLER, + /* SMM cache region. */ + SMM_SUBREGION_CACHE, + /* Chipset specific area. */ + SMM_SUBREGION_CHIPSET, + /* Total sub regions supported. */ + SMM_SUBREGION_NUM, +}; + +/* Fills in the start and size for the requested SMM subregion. Returns + * 0 on susccess, < 0 on failure. */ +int smm_subregion(int sub, void **start, size_t *size); + +#endif /* _COMMON_MEMMAP_H_ */ diff --git a/src/drivers/intel/fsp2_0/stage_cache.c b/src/drivers/intel/fsp2_0/stage_cache.c new file mode 100644 index 0000000..98bd174 --- /dev/null +++ b/src/drivers/intel/fsp2_0/stage_cache.c @@ -0,0 +1,28 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2013 Google Inc. + * Copyright (C) 2015 Intel Corp. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <console/console.h> +#include <soc/memmap.h> +#include <stage_cache.h> + +void stage_cache_external_region(void **base, size_t *size) +{ + if (smm_subregion(SMM_SUBREGION_CACHE, base, size)) { + printk(BIOS_ERR, "ERROR: No cache SMM subregion.\n"); + *base = NULL; + *size = 0; + } +}
