Timothy Pearson (tpearson@raptorengineeringinc.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/8663
commit 42ecb7ce7143ff3d392a742933f7f7084673e37e Author: Timothy Pearson tpearson@raptorengineeringinc.com Date: Fri Mar 13 12:48:31 2015 -0500
cpu/amd/model_10xxx: Move GFXUMA size calculation to separate function
This is required for early CBMEM support.
Change-Id: I31d9b6a04ef963a7d3e045d9c5201ae64604218a Signed-off-by: Timothy Pearson tpearson@raptorengineeringinc.com --- src/cpu/amd/model_10xxx/Makefile.inc | 2 ++ src/cpu/amd/model_10xxx/ram_calc.c | 43 ++++++++++++++++++++++++++++++ src/cpu/amd/model_10xxx/ram_calc.h | 25 +++++++++++++++++ src/northbridge/amd/amdfam10/northbridge.c | 17 ++---------- 4 files changed, 72 insertions(+), 15 deletions(-)
diff --git a/src/cpu/amd/model_10xxx/Makefile.inc b/src/cpu/amd/model_10xxx/Makefile.inc index ba12dcd..c17e66c 100644 --- a/src/cpu/amd/model_10xxx/Makefile.inc +++ b/src/cpu/amd/model_10xxx/Makefile.inc @@ -3,6 +3,8 @@ ramstage-y += model_10xxx_init.c ramstage-y += processor_name.c
romstage-y += update_microcode.c +romstage-y += ram_calc.c +ramstage-y += ram_calc.c ramstage-y += monotonic_timer.c ramstage-$(CONFIG_HAVE_ACPI_TABLES) += powernow_acpi.c
diff --git a/src/cpu/amd/model_10xxx/ram_calc.c b/src/cpu/amd/model_10xxx/ram_calc.c new file mode 100644 index 0000000..98b80e9 --- /dev/null +++ b/src/cpu/amd/model_10xxx/ram_calc.c @@ -0,0 +1,43 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2015 Timothy Pearson tpearson@raptorengineeringinc.com, Raptor Engineering + * Copyright (C) 2007 Advanced Micro Devices, Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +#include <cpu/cpu.h> +#include <cpu/x86/msr.h> +#include <cpu/amd/mtrr.h> + +#include "ram_calc.h" + +uint64_t get_uma_memory_size(uint64_t topmem) +{ + uint64_t uma_size = 0; + if (IS_ENABLED(CONFIG_GFXUMA)) { + /* refer to UMA Size Consideration in 780 BDG. */ + if (topmem > 0x40000000) /* 1GB and above system memory */ + uma_size = 0x10000000; /* 256M recommended UMA */ + + else if (topmem > 0x20000000) /* 512M - 1023M system memory */ + uma_size = 0x8000000; /* 128M recommended UMA */ + + else if (topmem > 0x10000000) /* 256M - 511M system memory */ + uma_size = 0x4000000; /* 64M recommended UMA */ + } + + return uma_size; +} diff --git a/src/cpu/amd/model_10xxx/ram_calc.h b/src/cpu/amd/model_10xxx/ram_calc.h new file mode 100644 index 0000000..7ece338 --- /dev/null +++ b/src/cpu/amd/model_10xxx/ram_calc.h @@ -0,0 +1,25 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2015 Timothy Pearson tpearson@raptorengineeringinc.com, Raptor Engineering + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +#ifndef _AMD_MODEL_10XXX_MEM_CALC_H_ +#define _AMD_MODEL_10XXX_MEM_CALC_H_ + +uint64_t get_uma_memory_size(uint64_t topmem); + +#endif diff --git a/src/northbridge/amd/amdfam10/northbridge.c b/src/northbridge/amd/amdfam10/northbridge.c index 5ce7ae6..e2b1441 100644 --- a/src/northbridge/amd/amdfam10/northbridge.c +++ b/src/northbridge/amd/amdfam10/northbridge.c @@ -33,6 +33,7 @@ #include <cpu/x86/lapic.h> #include <cpu/amd/mtrr.h> #include <cpu/amd/amdfam10_sysconf.h> +#include <cpu/amd/model_10xxx/ram_calc.h>
#if CONFIG_LOGICAL_CPUS #include <cpu/amd/multicore.h> @@ -740,21 +741,7 @@ static void setup_uma_memory(void) { #if CONFIG_GFXUMA uint32_t topmem = (uint32_t) bsp_topmem(); - /* refer to UMA Size Consideration in 780 BDG. */ - switch (topmem) { - case 0x10000000: /* 256M system memory */ - uma_memory_size = 0x4000000; /* 64M recommended UMA */ - break; - - case 0x20000000: /* 512M system memory */ - uma_memory_size = 0x8000000; /* 128M recommended UMA */ - break; - - default: /* 1GB and above system memory */ - uma_memory_size = 0x10000000; /* 256M recommended UMA */ - break; - } - + uma_memory_size = get_uma_memory_size(topmem); uma_memory_base = topmem - uma_memory_size; /* TOP_MEM1 */ printk(BIOS_INFO, "%s: uma size 0x%08llx, memory start 0x%08llx\n", __func__, uma_memory_size, uma_memory_base);
