Sergii Dmytruk has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/81800?usp=email )
Change subject: configs: enable TPM PPI for asrock_b85m_pro4.tpm2_txt_placeholder_acms ......................................................................
This is a good board for compiling TPM PPI sources for the following reasons (based on `config TPM_PPI` definition): - uses TPM - the board is not related to ChromeOS - ACPI tables are enabled - it doesn't use EDK2 payload
At the moment drivers/tpm/ppi.c seems to not be compiled by CI at all, see CB:69161 and CB:81590.
`CONFIG_TPM_PPI` is off by default but at least several configurations under `configs/` (Protectli, MSI) should exercise the file because they use EDK2 payload which changes default value. This is however negated by abuild disabling all payloads and thus effectively preventing `CONFIG_TPM_PPI` from being set. This board not using EDK2 also ensures that `CONFIG_TPM_PPI=y` will not disappear after some future `make savedefconfig`.
Change-Id: I316747a79b3142e9d6188c5986b344c7751d92d7 Signed-off-by: Sergii Dmytruk sergii.dmytruk@3mdeb.com --- M configs/config.asrock_b85m_pro4.tpm2_txt_placeholder_acms 1 file changed, 3 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/00/81800/1
diff --git a/configs/config.asrock_b85m_pro4.tpm2_txt_placeholder_acms b/configs/config.asrock_b85m_pro4.tpm2_txt_placeholder_acms index 4edeb0c..da33450 100644 --- a/configs/config.asrock_b85m_pro4.tpm2_txt_placeholder_acms +++ b/configs/config.asrock_b85m_pro4.tpm2_txt_placeholder_acms @@ -1,8 +1,11 @@ # Known-working configuration to boot with TXT enabled. Since BIOS # and SINIT ACM blobs are missing, use something else as placeholder. # Used ACMs were extracted from a Supermicro X10SLH firmware update. +# +# CONFIG_TPM_PPI=y tests building PPI implementation. CONFIG_VENDOR_ASROCK=y CONFIG_BOARD_ASROCK_B85M_PRO4=y +CONFIG_TPM_PPI=y CONFIG_TPM2=y CONFIG_INTEL_TXT=y CONFIG_INTEL_TXT_BIOSACM_FILE="3rdparty/blobs/cpu/intel/stm/stm.bin"
