Attention is currently required from: Tim Wawrzynczak, Angel Pons, Sridhar Siricilla, Werner Zeh, Patrick Rudolph, EricR Lai. Hello build bot (Jenkins), Tim Wawrzynczak, Sridhar Siricilla, Angel Pons, Nick Vaccaro, Lean Sheng Tan, Werner Zeh, Patrick Rudolph, EricR Lai,
https://review.coreboot.org/c/coreboot/+/61520
Change subject: soc/intel/common/cse: Add function to perform global reset lock ......................................................................
This patch implements `cse_control_global_reset_lock()` as per ME BWG (doc: 627331) recommendation.
It is recommended that BIOS should set this bit early on in the boot sequence, and then clear it and set the CF9LOCK bit prior to loading the OS in both an Intel CSME Enabled and a Intel CSME Disabled system.
Note: For CSE-Lite SKUs BIOS should set CF9LOCK bit unconditionally.
BUG=b:211954778 TEST=Able to build and boot Brya.
Signed-off-by: Subrata Banik subratabanik@google.com Change-Id: I3894b2cd8b90dc033f475384486815ab2fadf381 --- M src/soc/intel/common/block/cse/cse.c M src/soc/intel/common/block/include/intelblocks/cse.h 2 files changed, 23 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/20/61520/12
