Chris Wang has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/73426 )
Change subject: mb/google/skyrim: Move SPL setting to variants ......................................................................
Move the sustained_power_limit_mW setting from the baseboard to variants. This setting will be needed before STT is enabled, but once STT is enabled, this setting should be removed.
BUG=b:265267957 BRANCH=none TEST=Build/Boot to ChromeOS Signed-off-by: Chris Wang chris.wang@amd.corp-partner.google.com
Change-Id: I7b9779600cfa8c7581732e936a714728fd618d20 --- M src/mainboard/google/skyrim/variants/baseboard/devicetree.cb M src/mainboard/google/skyrim/variants/crystaldrift/overridetree.cb M src/mainboard/google/skyrim/variants/markarth/overridetree.cb M src/mainboard/google/skyrim/variants/skyrim/overridetree.cb 4 files changed, 32 insertions(+), 2 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/26/73426/1
diff --git a/src/mainboard/google/skyrim/variants/baseboard/devicetree.cb b/src/mainboard/google/skyrim/variants/baseboard/devicetree.cb index c92131c..6892742 100644 --- a/src/mainboard/google/skyrim/variants/baseboard/devicetree.cb +++ b/src/mainboard/google/skyrim/variants/baseboard/devicetree.cb @@ -260,8 +260,6 @@ register "fast_ppt_limit_mW" = "30000" register "slow_ppt_time_constant_s" = "5" register "stapm_time_constant_s" = "275" - # Remove the sustained_power_limit_mW when STT is enabled - register "sustained_power_limit_mW" = "15000" register "thermctl_limit_degreeC" = "100" register "vrm_current_limit_mA" = "28000" register "vrm_maximum_current_limit_mA" = "50000" diff --git a/src/mainboard/google/skyrim/variants/crystaldrift/overridetree.cb b/src/mainboard/google/skyrim/variants/crystaldrift/overridetree.cb index 7a56f93..9f58641 100644 --- a/src/mainboard/google/skyrim/variants/crystaldrift/overridetree.cb +++ b/src/mainboard/google/skyrim/variants/crystaldrift/overridetree.cb @@ -1,5 +1,10 @@ # SPDX-License-Identifier: GPL-2.0-or-later
chip soc/amd/mendocino + + # Set Package Power Parameters + # Remove the sustained_power_limit_mW when STT is enabled + register "sustained_power_limit_mW" = "15000" + device domain 0 on end end # chip soc/amd/mendocino diff --git a/src/mainboard/google/skyrim/variants/markarth/overridetree.cb b/src/mainboard/google/skyrim/variants/markarth/overridetree.cb index f50820b..b7132a8 100644 --- a/src/mainboard/google/skyrim/variants/markarth/overridetree.cb +++ b/src/mainboard/google/skyrim/variants/markarth/overridetree.cb @@ -2,6 +2,10 @@
register "dxio_tx_vboost_enable" = "1" diff --git a/src/mainboard/google/skyrim/variants/skyrim/overridetree.cb b/src/mainboard/google/skyrim/variants/skyrim/overridetree.cb index 0b9781e..3c33741 100644 --- a/src/mainboard/google/skyrim/variants/skyrim/overridetree.cb +++ b/src/mainboard/google/skyrim/variants/skyrim/overridetree.cb @@ -27,6 +27,11 @@ end
chip soc/amd/mendocino + + # Set Package Power Parameters + # Remove the sustained_power_limit_mW when STT is enabled + register "sustained_power_limit_mW" = "15000" + device domain 0 on device ref gpp_bridge_a on # Internal GPP Bridge 0 to Bus A device ref xhci_1 on # XHCI1 controller
