Attention is currently required from: Dinesh Gehlot, Eric Lai, Kapil Porwal, Matt DeVillier, Nick Vaccaro, Paul Menzel, Subrata Banik.
Hello Dinesh Gehlot, Eric Lai, Kapil Porwal, Nick Vaccaro, Subrata Banik, build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/81135?usp=email
Change subject: mb/google/nissa/var/glassway: Adjust touchscreen power sequencing ......................................................................
Adjust touchscreen power sequencing for eKTH5015M.
The INX touch panel (eKTH5015M) contains a pull-up register which causes TCHSCR_REPORT_EN pull-up abnormally from Z1 power on.Because the t25 must be at least greater than 20ms, TCHSCR_REPORT_EN is initialized to GPO_L in the early stage (romstage) to meet the spec.
BUG=b:328170008 BRANCH=firmware-nissa-15217.B TEST=Build and check I2C devices timing meet spec. [INFO ] input: Elan Touchscreen as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-10/i2c-ELAN0001:00/input/in4
Change-Id: I50f9c21ddee2bc9c1d313f63049cb587b4ae047a Signed-off-by: Frank Chu frank_chu@pegatron.corp-partner.google.com --- M src/mainboard/google/brya/Kconfig M src/mainboard/google/brya/variants/glassway/gpio.c M src/mainboard/google/brya/variants/glassway/overridetree.cb 3 files changed, 18 insertions(+), 15 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/35/81135/16
