Attention is currently required from: Jason Glenesk, Jakub Czapiga, Marshall Dawson, Tim Wawrzynczak, Angel Pons, Rob Barnes, Patrick Rudolph, Felix Held. Hello build bot (Jenkins), Jason Glenesk, Raul Rangel, Furquan Shaikh, Jakub Czapiga, Marshall Dawson, Tim Wawrzynczak, Angel Pons, Rob Barnes, Patrick Rudolph, Felix Held,
https://review.coreboot.org/c/coreboot/+/56628
to look at the new patch set (#18).
Change subject: arch/x86: Refactor the SMBIOS type 17 write function ......................................................................
List of changes: 1. Create Module Type macros as per Memory Type (i.e. DDR2/DDR3/DDR4/DDR5/LPDDR4/LPDDR5) and fix compilation issue due to renaming of existing macros due to scoping the Memory Type. 2. Use dedicated Memory Type and Module type for `Form Factor` and `TypeDetail` conversion using `get_spd_info()` function. 3. Create a new API (convert_form_factor_to_module_type()) for `Form Factor` to 'Module type' conversion as per `Memory Type`. 4. Add new argument as `Memory Type` to smbios_form_factor_to_spd_mod_type() so that smbios_form_factor_to_spd_mod_type() can internally call convert_form_factor_to_module_type() for `Module Type` conversion. 5. Update `test_smbios_form_factor_to_spd_mod_type()` to accommodate different memory types.
Refer to datasheet SPD4.1.2.M-1 for LPDDRx and SPD4.1.2.L-3 for DDRx.
BUG=b:194659789 TEST=Refer to dmidecode -t 17 output as below: Without this code change:
Handle 0x0012, DMI type 17, 40 bytes Memory Device Array Handle: 0x000A Error Information Handle: Not Provided Total Width: 16 bits Data Width: 16 bits Size: 2048 MB Form Factor: Unknown ....
With this code change:
Handle 0x0012, DMI type 17, 40 bytes Memory Device Array Handle: 0x000A Error Information Handle: Not Provided Total Width: 16 bits Data Width: 16 bits Size: 2048 MB Form Factor: Row Of Chips ....
Change-Id: Ia337ac8f50b61ae78d86a07c7a86aa9c248bad50 Signed-off-by: Subrata Banik subrata.banik@intel.com --- M src/arch/x86/smbios.c M src/device/dram/ddr3.c M src/device/dram/ddr4.c M src/device/dram/spd.c M src/include/device/dram/spd.h M src/include/dimm_info_util.h M src/include/spd.h M src/lib/dimm_info_util.c M src/mainboard/scaleway/tagada/ramstage.c M src/northbridge/intel/haswell/haswell_mrc/raminit.c M src/soc/amd/common/fsp/dmi.c M src/soc/amd/common/pi/amd_late_init.c M tests/lib/Makefile.inc M tests/lib/dimm_info_util-test.c 14 files changed, 444 insertions(+), 86 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/28/56628/18
