Attention is currently required from: Felix Held, Fred Reitberger, Jason Glenesk, Jason Nien, Martin Roth, Matt DeVillier, Matt DeVillier.
Hello Fred Reitberger, Jason Glenesk, Jason Nien, Martin Roth, Matt DeVillier, Matt DeVillier, build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/78309?usp=email
The following approvals got outdated and were removed: Code-Review+1 by Matt DeVillier, Verified+1 by build bot (Jenkins)
Change subject: soc/amd/*/Kconfig: rework SPL options ......................................................................
Move all security patch level (SPL) related Kconfig options to the common AMD PSP Kconfig file. Commit 4ab1db82bb30 ("soc/amd: rework SPL file override and SPL fusing handling") already reworked the SPL handling, but missed that another Kconfig option SOC_AMD_COMMON_BLOCK_PSP_FUSE_SPL controlled if the PSP mailbox command to update the SPL fuses was sent by the code that got added to the build when PERFORM_SPL_FUSING was selected. To make things less unexpected, rename PERFORM_SPL_FUSING to SOC_AMD_COMMON_BLOCK_PSP_SPL since it actually controls if the SPL support code is added to the build and also rename SOC_AMD_COMMON_BLOCK_PSP_FUSE_SPL to PERFORM_SPL_FUSING. This changes what PERFORM_SPL_FUSING will do from including the code that could do the fusing if another option is set to being the option that controls if the fusing mailbox command will be set. All SoCs that support SPL now select SOC_AMD_COMMON_BLOCK_PSP_SPL in their Kconfig, which won't burn any SPL fuses. The logic in the Skyrim mainboard Kconfig file is reworked to select PERFORM_SPL_FUSING for all boards on which the SPL fuses should be updated; on Guybrush PERFORM_SPL_FUSING default is changed to y for all variants. The option to include the code that checks the SPL fusing conditions and allows sending the command to update the SPL fuses if the corresponding Kconfig is set doesn't need to be added on the mainboard level, since it's already selected at the SoC level.
Signed-off-by: Felix Held felix-coreboot@felixheld.de Change-Id: I12fd8775db66f16fe632674cd67c6af483e8d4e2 --- M src/mainboard/google/guybrush/Kconfig M src/mainboard/google/skyrim/Kconfig M src/soc/amd/cezanne/Kconfig M src/soc/amd/common/block/psp/Kconfig M src/soc/amd/common/block/psp/Makefile.inc M src/soc/amd/common/block/psp/spl_fuse.c M src/soc/amd/genoa/Kconfig M src/soc/amd/glinda/Kconfig M src/soc/amd/mendocino/Kconfig M src/soc/amd/phoenix/Kconfig 10 files changed, 50 insertions(+), 156 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/09/78309/5
