Patrick Georgi (pgeorgi@google.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/16721
commit 81b941167af36ebb68a5b1d519458b9997b03796 Author: Lin Huang hl@rock-chips.com Date: Wed Sep 21 17:05:43 2016 +0800
google/gru: set W2W_DIFFCS_DLY to 5
It will enable PHY_PER_CS_TRAINING when DDR DDR frequency >= 666. For per cs training, the controller should consider the PHY delay line switch time,there should be more cycles to switch delay line. So need increase W2W_DIFFCS_DLY_ value from 0x1 to 0x5.
BRANCH=none BUG=chrome-os-partner:56940 TEST=do memtester on kevin board, and pass
Change-Id: I00df2d4724b0b77f3e7565809fb35bbd2ff01ea5 Signed-off-by: Patrick Georgi pgeorgi@chromium.org Original-Commit-Id: c135ea3e33d810ed322d947eb8d512d1ac119cfc Original-Change-Id: I81b99cbc085769b7028e770509d79bd8d550820b Original-Signed-off-by: Lin Huang hl@rock-chips.com Original-Reviewed-on: https://chromium-review.googlesource.com/387506 Original-Reviewed-by: Douglas Anderson dianders@chromium.org Original-Reviewed-by: Derek Basehore dbasehore@chromium.org Original-Reviewed-by: Julius Werner jwerner@chromium.org --- src/mainboard/google/gru/sdram_params/sdram-lpddr3-hynix-4GB-200.c | 4 ++-- src/mainboard/google/gru/sdram_params/sdram-lpddr3-hynix-4GB-666.c | 4 ++-- src/mainboard/google/gru/sdram_params/sdram-lpddr3-hynix-4GB-800.c | 4 ++-- src/mainboard/google/gru/sdram_params/sdram-lpddr3-hynix-4GB-933.c | 6 +++--- 4 files changed, 9 insertions(+), 9 deletions(-)
diff --git a/src/mainboard/google/gru/sdram_params/sdram-lpddr3-hynix-4GB-200.c b/src/mainboard/google/gru/sdram_params/sdram-lpddr3-hynix-4GB-200.c index c877158..5330141 100644 --- a/src/mainboard/google/gru/sdram_params/sdram-lpddr3-hynix-4GB-200.c +++ b/src/mainboard/google/gru/sdram_params/sdram-lpddr3-hynix-4GB-200.c @@ -279,8 +279,8 @@ struct rk3399_sdram_params params = { 0x05050502, /* DENALI_CTL_215_DATA */ 0x02080808, /* DENALI_CTL_216_DATA */ 0x02050202, /* DENALI_CTL_217_DATA */ - 0x02010202, /* DENALI_CTL_218_DATA */ - 0x00010202, /* DENALI_CTL_219_DATA */ + 0x02050202, /* DENALI_CTL_218_DATA */ + 0x00050202, /* DENALI_CTL_219_DATA */ 0x00020202, /* DENALI_CTL_220_DATA */ 0x02010200, /* DENALI_CTL_221_DATA */ 0x00010201, /* DENALI_CTL_222_DATA */ diff --git a/src/mainboard/google/gru/sdram_params/sdram-lpddr3-hynix-4GB-666.c b/src/mainboard/google/gru/sdram_params/sdram-lpddr3-hynix-4GB-666.c index 591924d..4b73cb0 100644 --- a/src/mainboard/google/gru/sdram_params/sdram-lpddr3-hynix-4GB-666.c +++ b/src/mainboard/google/gru/sdram_params/sdram-lpddr3-hynix-4GB-666.c @@ -279,8 +279,8 @@ struct rk3399_sdram_params params = { 0x08080803, /* DENALI_CTL_215_DATA */ 0x08080808, /* DENALI_CTL_216_DATA */ 0x02050203, /* DENALI_CTL_217_DATA */ - 0x02010303, /* DENALI_CTL_218_DATA */ - 0x00010203, /* DENALI_CTL_219_DATA */ + 0x02050303, /* DENALI_CTL_218_DATA */ + 0x00050203, /* DENALI_CTL_219_DATA */ 0x00020202, /* DENALI_CTL_220_DATA */ 0x03020400, /* DENALI_CTL_221_DATA */ 0x00020401, /* DENALI_CTL_222_DATA */ diff --git a/src/mainboard/google/gru/sdram_params/sdram-lpddr3-hynix-4GB-800.c b/src/mainboard/google/gru/sdram_params/sdram-lpddr3-hynix-4GB-800.c index b738644..3056e55 100644 --- a/src/mainboard/google/gru/sdram_params/sdram-lpddr3-hynix-4GB-800.c +++ b/src/mainboard/google/gru/sdram_params/sdram-lpddr3-hynix-4GB-800.c @@ -279,8 +279,8 @@ struct rk3399_sdram_params params = { 0x0a0a0a03, /* DENALI_CTL_215_DATA */ 0x08080808, /* DENALI_CTL_216_DATA */ 0x02050103, /* DENALI_CTL_217_DATA */ - 0x02010103, /* DENALI_CTL_218_DATA */ - 0x00010103, /* DENALI_CTL_219_DATA */ + 0x02050103, /* DENALI_CTL_218_DATA */ + 0x00050103, /* DENALI_CTL_219_DATA */ 0x00020202, /* DENALI_CTL_220_DATA */ 0x03020500, /* DENALI_CTL_221_DATA */ 0x00020501, /* DENALI_CTL_222_DATA */ diff --git a/src/mainboard/google/gru/sdram_params/sdram-lpddr3-hynix-4GB-933.c b/src/mainboard/google/gru/sdram_params/sdram-lpddr3-hynix-4GB-933.c index 362489b..3947881 100644 --- a/src/mainboard/google/gru/sdram_params/sdram-lpddr3-hynix-4GB-933.c +++ b/src/mainboard/google/gru/sdram_params/sdram-lpddr3-hynix-4GB-933.c @@ -278,9 +278,9 @@ struct rk3399_sdram_params params = { 0x04040001, /* DENALI_CTL_214_DATA */ 0x0c0c0c04, /* DENALI_CTL_215_DATA */ 0x08080808, /* DENALI_CTL_216_DATA */ - 0x02010103, /* DENALI_CTL_217_DATA */ - 0x02010103, /* DENALI_CTL_218_DATA */ - 0x00010103, /* DENALI_CTL_219_DATA */ + 0x02050103, /* DENALI_CTL_217_DATA */ + 0x02050103, /* DENALI_CTL_218_DATA */ + 0x00050103, /* DENALI_CTL_219_DATA */ 0x00020202, /* DENALI_CTL_220_DATA */ 0x06030600, /* DENALI_CTL_221_DATA */ 0x00030603, /* DENALI_CTL_222_DATA */
