Attention is currently required from: Angel Pons, Bill XIE, Nicholas Chin.
Keith Hui has posted comments on this change by Keith Hui. ( https://review.coreboot.org/c/coreboot/+/85413?usp=email )
Change subject: mb/asus/p8z77-v: Attempt to correctly route PCIe lanes ......................................................................
Patch Set 7:
(2 comments)
Patchset:
PS6:
Looks like GPIO 5 is reset by either RSMRST# (pin 101) or SLPS5# (pin 84) depending on the setting i […]
According to the SIO datasheet I could temporarily change RSTOUT2# to GP76 using config register 0x2b and manually pulse the reset lines on the PCH PCIe slots this way. (I would need this one to be OD - it has a pull up.) Am I being too ambitious?
Looks like the root cause is a disruption of PCIe clock between PCIEX1_2 and ASM1061. Sadly the only reset signal ASM1061 gets is PLTRST#, so a system_reset() is still going to be necessary.
Patchset:
PS7: I implemented the additional logic Nicholas suggested. Let's give it a try.
