Felix Singer has submitted this change. ( https://review.coreboot.org/c/coreboot/+/69941 )
Change subject: util/crossgcc/buildgcc: Use one line per configure option ......................................................................
To improve the readability and visibility of the configure options, move each of them to a separate line.
Change-Id: Ifc39e4d0849d220d85e1d9ce92fc008fec610694 Signed-off-by: Felix Singer felixsinger@posteo.net Reviewed-on: https://review.coreboot.org/c/coreboot/+/69941 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Elyes Haouas ehaouas@noos.fr --- M util/crossgcc/buildgcc 1 file changed, 90 insertions(+), 38 deletions(-)
Approvals: build bot (Jenkins): Verified Elyes Haouas: Looks good to me, approved
diff --git a/util/crossgcc/buildgcc b/util/crossgcc/buildgcc index 0272691..4662742 100755 --- a/util/crossgcc/buildgcc +++ b/util/crossgcc/buildgcc @@ -624,9 +624,11 @@
# shellcheck disable=SC2086 CC="$(hostcc host)" CXX="$(hostcxx host)" \ - ../${GMP_DIR}/configure --disable-shared --enable-fat \ - --prefix="$TARGETDIR" $OPTIONS \ - || touch .failed + ../${GMP_DIR}/configure \ + --disable-shared \ + --enable-fat \ + --prefix="$TARGETDIR" \ + $OPTIONS || touch .failed # shellcheck disable=SC2086 $MAKE $JOBS || touch .failed $MAKE install DESTDIR=$DESTDIR || touch .failed @@ -639,10 +641,12 @@ build_MPFR() { test "$UNAME" = "Darwin" && CFLAGS="$CFLAGS -force_cpusubtype_ALL" CC="$(hostcc host)" CXX="$(hostcxx host)" \ - ../${MPFR_DIR}/configure --disable-shared --prefix="$TARGETDIR" \ + ../${MPFR_DIR}/configure \ + --disable-shared \ + --prefix="$TARGETDIR" \ --infodir="$TARGETDIR/info" \ - --with-gmp="$DESTDIR$TARGETDIR" CFLAGS="$HOSTCFLAGS" || \ - touch .failed + --with-gmp="$DESTDIR$TARGETDIR" \ + CFLAGS="$HOSTCFLAGS" || touch .failed # shellcheck disable=SC2086 $MAKE $JOBS || touch .failed $MAKE install DESTDIR=$DESTDIR || touch .failed @@ -657,10 +661,13 @@
build_MPC() { CC="$(hostcc host)" CXX="$(hostcxx host)" \ - ../${MPC_DIR}/configure --disable-shared --prefix="$TARGETDIR" \ - --infodir="$TARGETDIR/info" --with-mpfr="$DESTDIR$TARGETDIR" \ - --with-gmp="$DESTDIR$TARGETDIR" CFLAGS="$HOSTCFLAGS" || \ - touch .failed + ../${MPC_DIR}/configure \ + --disable-shared \ + --prefix="$TARGETDIR" \ + --infodir="$TARGETDIR/info" \ + --with-mpfr="$DESTDIR$TARGETDIR" \ + --with-gmp="$DESTDIR$TARGETDIR" \ + CFLAGS="$HOSTCFLAGS" || touch .failed
# work around build problem of libmpfr.la if [ "$DESTDIR" != "" ]; then @@ -685,14 +692,18 @@ fi # shellcheck disable=SC2086 CC="$(hostcc target)" CXX="$(hostcxx target)" \ - ../binutils-${BINUTILS_VERSION}/configure --prefix="$TARGETDIR" \ - --target=${TARGETARCH} --enable-targets=${TARGETARCH}${ADDITIONALTARGET} \ - --disable-werror --disable-nls --enable-lto \ - --enable-gold --enable-multilib \ + ../binutils-${BINUTILS_VERSION}/configure \ + --prefix="$TARGETDIR" \ + --target=${TARGETARCH} \ + --enable-targets=${TARGETARCH}${ADDITIONALTARGET} \ + --disable-werror \ + --disable-nls \ + --enable-lto \ + --enable-gold \ + --enable-multilib \ ${BINUTILS_OPTIONS} \ CFLAGS="$HOSTCFLAGS" \ - CXXFLAGS="$HOSTCFLAGS" \ - || touch .failed + CXXFLAGS="$HOSTCFLAGS" || touch .failed # shellcheck disable=SC2086 $MAKE $JOBS || touch .failed $MAKE install DESTDIR=$DESTDIR || touch .failed @@ -708,14 +719,21 @@ CXXFLAGS_FOR_BUILD="$HOSTCFLAGS" \ CXXFLAGS_FOR_TARGET="$HOSTCFLAGS -fPIC" \ ../gcc-${GCC_VERSION}/configure \ - --prefix="$TARGETDIR" --libexecdir="$TARGETDIR/lib" \ + --prefix="$TARGETDIR" \ + --libexecdir="$TARGETDIR/lib" \ --enable-bootstrap \ - --disable-werror --disable-nls \ - --disable-shared --disable-multilib \ - --disable-libssp --disable-libquadmath --disable-libcc1 \ + --disable-werror \ + --disable-nls \ + --disable-shared \ + --disable-multilib \ + --disable-libssp \ + --disable-libquadmath \ + --disable-libcc1 \ --disable-libsanitizer \ - ${GCC_OPTIONS} --enable-languages="${LANGUAGES}" \ - --with-gmp="$DESTDIR$TARGETDIR" --with-mpfr="$DESTDIR$TARGETDIR" \ + ${GCC_OPTIONS} \ + --enable-languages="${LANGUAGES}" \ + --with-gmp="$DESTDIR$TARGETDIR" \ + --with-mpfr="$DESTDIR$TARGETDIR" \ --with-mpc="$DESTDIR$TARGETDIR" \ --with-pkgversion="coreboot bootstrap v$CROSSGCC_VERSION" \ && \ @@ -750,19 +768,35 @@ CXXFLAGS="$HOSTCFLAGS $CLANGCXXFLAGS" \ CXXFLAGS_FOR_BUILD="$HOSTCFLAGS $CLANGCXXFLAGS" \ ../gcc-${GCC_VERSION}/configure \ - --prefix="$TARGETDIR" --libexecdir="$TARGETDIR/lib" \ - --target=${TARGETARCH} --disable-werror --disable-shared \ - --enable-lto --enable-plugins --enable-gold --enable-ld=default \ - --disable-libssp --disable-bootstrap --disable-nls \ - --disable-libquadmath --without-headers \ + --prefix="$TARGETDIR" \ + --libexecdir="$TARGETDIR/lib" \ + --target=${TARGETARCH} \ + --disable-werror \ + --disable-shared \ + --enable-lto \ + --enable-plugins \ + --enable-gold \ + --enable-ld=default \ + --disable-libssp \ + --disable-bootstrap \ + --disable-nls \ + --disable-libquadmath \ + --without-headers \ --disable-threads \ - --enable-interwork --enable-multilib --enable-targets=all \ - --disable-libatomic --disable-libcc1 --disable-decimal-float \ - ${GCC_OPTIONS} --enable-languages="${LANGUAGES}" \ + --enable-interwork \ + --enable-multilib \ + --enable-targets=all \ + --disable-libatomic \ + --disable-libcc1 \ + --disable-decimal-float \ + ${GCC_OPTIONS} \ + --enable-languages="${LANGUAGES}" \ --with-system-zlib \ - --with-gmp="$DESTDIR$TARGETDIR" --with-mpfr="$DESTDIR$TARGETDIR" \ + --with-gmp="$DESTDIR$TARGETDIR" \ + --with-mpfr="$DESTDIR$TARGETDIR" \ --with-mpc="$DESTDIR$TARGETDIR" \ - --with-gnu-as --with-gnu-ld \ + --with-gnu-as \ + --with-gnu-ld \ --with-pkgversion="coreboot toolchain v$CROSSGCC_VERSION" \ && \ mkdir -p gcc/$TARGETARCH && \ @@ -810,10 +844,12 @@ ln -nsf "$CRT_DIR" ../compiler-rt ln -nsf "$LLVMCMAKE_DIR" ../cmake
- $CMAKE -G "Unix Makefiles" -DCMAKE_INSTALL_PREFIX="$DESTDIR$TARGETDIR" \ + $CMAKE -G "Unix Makefiles" \ + -DCMAKE_INSTALL_PREFIX="$DESTDIR$TARGETDIR" \ -DCLANG_VENDOR="coreboot toolchain v$CROSSGCC_VERSION - " \ -DLLVM_ENABLE_PROJECTS="clang;clang-tools-extra;compiler-rt" \ - -DLLVM_INCLUDE_BENCHMARKS="OFF" -DCMAKE_BUILD_TYPE=Release \ + -DLLVM_INCLUDE_BENCHMARKS="OFF" \ + -DCMAKE_BUILD_TYPE=Release \ -DLLVM_TARGETS_TO_BUILD="AArch64;ARM;PowerPC;RISCV;X86" \ ../llvm || touch .failed # shellcheck disable=SC2086 @@ -835,8 +871,8 @@
build_CMAKE() { CC="$(hostcc host)" CXX="$(hostcxx host)" CFLAGS="$HOSTCFLAGS" \ - ../${CMAKE_DIR}/configure --prefix="$TARGETDIR" \ - || touch .failed + ../${CMAKE_DIR}/configure \ + --prefix="$TARGETDIR" || touch .failed # shellcheck disable=SC2086 $MAKE $JOBS || touch .failed $MAKE install DESTDIR=$DESTDIR || touch .failed @@ -844,8 +880,8 @@
build_NASM() { CC="$(hostcc host)" CXX="$(hostcxx host)" CFLAGS="$HOSTCFLAGS" - ../${NASM_DIR}/configure --prefix="$TARGETDIR" \ - || touch .failed + ../${NASM_DIR}/configure \ + --prefix="$TARGETDIR" || touch .failed # shellcheck disable=SC2086 $MAKE $JOBS || touch .failed $MAKE install DESTDIR=$DESTDIR || touch .failed
