Attention is currently required from: Patrick Rudolph, Christian Walter, Angel Pons, Lean Sheng Tan.
Hello build bot (Jenkins), Christian Walter, Angel Pons, Lean Sheng Tan,
https://review.coreboot.org/c/coreboot/+/68137
Change subject: [WIP] mb/prodrive/atlas: Populate smbios table with VPD from ECs EMI ......................................................................
The embedded controller stores serial-number and part-number within an EEPROM which is unreachable to the Host CPU. Therefore, on the EC side, we set up a shared memory region with the help of EMI and copy the VPDs to it. On the coreboot side, we can read those back and populate the SMBios table type 1 with the serial-number and type 11 with the part-number.
emi.*: small interface to access the EMI regions vpd.*: uses the emi interface in order to read the VPDs smbios.c: populates smbios type 1 with the serial-number by using vpd.h mainboard.c: uses vpd.h to add a string to smbios type 11 ld_config.*: offers functionality to configure logical devices devicetree.cb: enables address range 0xc00-0xcff for the EMI runtime registers Makefile.inc: adds emi.c, vpd.c, smbios.c, ld_config.c to the ramstage compilation
TODO: ld_config.* is redundant. We can replace this with pnp_device.h or pnp_ops.h
Signed-off-by: David Milosevic David.Milosevic@9elements.com Change-Id: I47bb4883c43ff344a9bda92c3106dd025533b391 --- M 3rdparty/blobs M src/mainboard/prodrive/atlas/Makefile.inc M src/mainboard/prodrive/atlas/devicetree.cb A src/mainboard/prodrive/atlas/emi.c A src/mainboard/prodrive/atlas/emi.h A src/mainboard/prodrive/atlas/ld_config.c A src/mainboard/prodrive/atlas/ld_config.h M src/mainboard/prodrive/atlas/mainboard.c A src/mainboard/prodrive/atlas/smbios.c A src/mainboard/prodrive/atlas/vpd.c A src/mainboard/prodrive/atlas/vpd.h 11 files changed, 529 insertions(+), 3 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/37/68137/5
