Ravishankar Sarawadi has uploaded this change for review. ( https://review.coreboot.org/25087
Change subject: [WIP]soc/intel/common/block/gspi: move SPI to GSPI mapping to common ......................................................................
Move SPI to GSPI bus and devfn mapping to GSPI common code.
BUG=None BRANCH=None TEST=Build coreboot and do BAT test for SKL, CNL platform.
Change-Id: I175ca6eab369276c693c78acc4d8ac9cd49ad152 Signed-off-by: Ravi Sarawadi ravishankar.sarawadi@intel.com --- M src/soc/intel/cannonlake/gspi.c M src/soc/intel/common/block/gspi/gspi.c M src/soc/intel/skylake/gspi.c 3 files changed, 30 insertions(+), 54 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/87/25087/1
diff --git a/src/soc/intel/cannonlake/gspi.c b/src/soc/intel/cannonlake/gspi.c index e4f682d..945c8c8 100644 --- a/src/soc/intel/cannonlake/gspi.c +++ b/src/soc/intel/cannonlake/gspi.c @@ -43,30 +43,3 @@ { return EARLY_GSPI_BASE_ADDRESS; } - -/* - * SPI Bus 0 is Fast SPI and GSPI starts from SPI bus # 1 onwards. Thus, adjust - * the bus # accordingly when referring to SPI / GSPI bus numbers. - */ -#define GSPI_TO_SPI_BUS(x) ((x) + 1) -#define SPI_TO_GSPI_BUS(x) ((x) - 1) - -int gspi_soc_spi_to_gspi_bus(unsigned int spi_bus, unsigned int *gspi_bus) -{ - if (spi_bus == 0) - return -1; - - *gspi_bus = SPI_TO_GSPI_BUS(spi_bus); - if (*gspi_bus >= CONFIG_SOC_INTEL_COMMON_BLOCK_GSPI_MAX) - return -1; - - return 0; -} - -int gspi_soc_bus_to_devfn(unsigned int gspi_bus) -{ - if (gspi_bus >= CONFIG_SOC_INTEL_COMMON_BLOCK_GSPI_MAX) - return -1; - - return spi_soc_bus_to_devfn(GSPI_TO_SPI_BUS(gspi_bus)); -} diff --git a/src/soc/intel/common/block/gspi/gspi.c b/src/soc/intel/common/block/gspi/gspi.c index 60c7391..db68a2b 100644 --- a/src/soc/intel/common/block/gspi/gspi.c +++ b/src/soc/intel/common/block/gspi/gspi.c @@ -22,6 +22,7 @@ #include <device/device.h> #include <device/pci_def.h> #include <intelblocks/gspi.h> +#include <intelblocks/spi.h> #include <string.h> #include <timer.h>
@@ -172,6 +173,35 @@
#endif
+/* + * SPI Bus 0 is Fast SPI and GSPI starts from SPI bus # 1 onwards. Thus, adjust + * the bus # accordingly when referring to SPI / GSPI bus numbers. + */ +#define GSPI_TO_SPI_BUS(x) ((x) + 1) +#define SPI_TO_GSPI_BUS(x) ((x) - 1) + +__attribute__((weak)) int gspi_soc_spi_to_gspi_bus(unsigned int spi_bus, + unsigned int *gspi_bus) +{ + if (spi_bus == 0) + return -1; + + if (SPI_TO_GSPI_BUS(spi_bus) >= CONFIG_SOC_INTEL_COMMON_BLOCK_GSPI_MAX) + return -1; + + *gspi_bus = SPI_TO_GSPI_BUS(spi_bus); + + return 0; +} + +__attribute__((weak)) int gspi_soc_bus_to_devfn(unsigned int gspi_bus) +{ + if (gspi_bus >= CONFIG_SOC_INTEL_COMMON_BLOCK_GSPI_MAX) + return -1; + + return spi_soc_bus_to_devfn(GSPI_TO_SPI_BUS(gspi_bus)); +} + static uintptr_t gspi_calc_base_addr(unsigned int gspi_bus) { uintptr_t bus_base, gspi_base_addr; diff --git a/src/soc/intel/skylake/gspi.c b/src/soc/intel/skylake/gspi.c index 252be777..393763d 100644 --- a/src/soc/intel/skylake/gspi.c +++ b/src/soc/intel/skylake/gspi.c @@ -42,30 +42,3 @@ { return EARLY_GSPI_BASE_ADDRESS; } - -/* - * SPI Bus 0 is Fast SPI and GSPI starts from SPI bus # 1 onwards. Thus, adjust - * the bus # accordingly when referring to SPI / GSPI bus numbers. - */ -#define GSPI_TO_SPI_BUS(x) (x + 1) -#define SPI_TO_GSPI_BUS(x) (x - 1) - -int gspi_soc_spi_to_gspi_bus(unsigned int spi_bus, unsigned int *gspi_bus) -{ - if (spi_bus == 0) - return -1; - - *gspi_bus = SPI_TO_GSPI_BUS(spi_bus); - if (*gspi_bus >= CONFIG_SOC_INTEL_COMMON_BLOCK_GSPI_MAX) - return -1; - - return 0; -} - -int gspi_soc_bus_to_devfn(unsigned int gspi_bus) -{ - if (gspi_bus >= CONFIG_SOC_INTEL_COMMON_BLOCK_GSPI_MAX) - return -1; - - return spi_soc_bus_to_devfn(GSPI_TO_SPI_BUS(gspi_bus)); -}
