Hello build bot (Jenkins), Furquan Shaikh, Tim Wawrzynczak, Duncan Laurie, Rizwan Qureshi, Subrata Banik, Usha P, Patrick Rudolph, Aaron Durbin,
https://review.coreboot.org/c/coreboot/+/43494
Change subject: soc/intel/common/cpu: Update COS mask calculation for NEM enhanced mode ......................................................................
Update the COS mask calculation to accomodate the RW data as per SoC configuration. Currently only one way is allocated for RW data and configured for non-eviction. For earlier platform this served fine, and could accomodate a RW data up to 256Kb. Starting TGL and JSL, the DCACHE_RAM_SIZE is configured for 512Kb, which cannot be mapped to a single way. Hence update the number of ways to be configured for non- eviction as per total LLC size.
The total LLC size/ number of ways gives the way size. DCACHE_RAM_SIZE/ way size gives the number of ways that need to be configured for non- eviction, instead of harcoding it to 1.
TGL uses MSR IA32_CR_SF_QOS_MASK_1(0x1891) and IA32_CR_SF_QOS_MASK_2(0x1892) as COS mask selection register and hence needs to be progarmmed accordingly.
Also JSL and TGL platforms the COS mask selection is mapped to bit 32:33 of MSR IA32_PQR_ASSOC(0xC8F) and need to be updated in edx(maps 63:32) before MSR write instead of eax(maps 31:0). This implementation corrects that as well.
BUG=b:149273819 TEST= Boot waddledoo(JSL), hatch(CML) with NEM enhanced CAR configuration. Pending test on ICL, TGL, KBL, SKL.
Signed-off-by: Aamir Bohra aamir.bohra@intel.com Change-Id: I54e047161853bfc70516c1d607aa479e68836d04 --- M src/include/cpu/x86/msr.h M src/soc/intel/cannonlake/Kconfig M src/soc/intel/common/block/cpu/Kconfig M src/soc/intel/common/block/cpu/car/cache_as_ram.S M src/soc/intel/denverton_ns/Kconfig M src/soc/intel/icelake/Kconfig M src/soc/intel/skylake/Kconfig 7 files changed, 119 insertions(+), 43 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/94/43494/4
