Andrey Petrov (andrey.petrov@intel.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/13371
commit ed8da6f2a646e2c433e766203185dcf7d601983a Author: Zhao, Lijian lijian.zhao@intel.com Date: Wed Dec 2 15:34:45 2015 -0800
soc/intel/apollolake: Fill northbridge ASL
Northbridge resource assignment: Dynamicly update memory resources for northbridge devices, exclude any fixed MMIO resources.
Change-Id: I9595f9a12434fa423862836d19f7266d6023fc5a Signed-off-by: Zhao, Lijian lijian.zhao@intel.com --- src/soc/intel/apollolake/acpi/northbridge.asl | 126 ++++++++++++++++++++++++++ 1 file changed, 126 insertions(+)
diff --git a/src/soc/intel/apollolake/acpi/northbridge.asl b/src/soc/intel/apollolake/acpi/northbridge.asl new file mode 100644 index 0000000..1349c6a --- /dev/null +++ b/src/soc/intel/apollolake/acpi/northbridge.asl @@ -0,0 +1,126 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2016 Intel Corp. + * (Written by Lance Zhao lijian.zhao@intel.com for Intel Corp.) + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + */ + + Name(_HID, EISAID("PNP0A08")) /* PCIe */ + Name(_CID, EISAID("PNP0A03")) /* PCI */ + Name(_ADR, 0) + Name(_BBN, 0) + +Device (MCHC) +{ + Name (_ADR, 0x00000000) /*Dev0 Func0 */ + + OperationRegion (MCHP, PCI_Config, 0x00, 0x100) + Field (MCHP, DWordAcc, NoLock, Preserve) + { + Offset(0x60), + MCNF, 32, /* PCI MMCONF base */ + Offset (0xA8), + TUUD, 64, /* Top of Upper Used Memory */ + Offset(0xB4), + BGSM, 32, /* Base of Graphics Stolen Memory */ + Offset(0xBC), + TLUD, 32, /* Top of Low Useable DRAM */ + } + Name (MCRS, ResourceTemplate() + { + /* Bus Numbers */ + WordBusNumber (ResourceProducer, MinFixed, MaxFixed, PosDecode, + 0x0000, 0x0000, 0x00ff, 0x0000, 0x0100,,,) + + /* IO Region 0 */ + DWordIO (ResourceProducer, MinFixed, MaxFixed, PosDecode, EntireRange, + 0x0000, 0x0000, 0x0cf7, 0x0000, 0x0cf8,,,) + + /* PCI Config Space */ + Io (Decode16, 0x0cf8, 0x0cf8, 0x0001, 0x0008) + + /* IO Region 1 */ + DWordIO (ResourceProducer, MinFixed, MaxFixed, PosDecode, EntireRange, + 0x0000, 0x01000, 0xffff, 0x0000, 0xf000,,,) + + /* VGA memory (0xa0000-0xbffff) */ + DWordMemory (ResourceProducer, PosDecode, MinFixed, MaxFixed, + Cacheable, ReadWrite, + 0x00000000, 0x000a0000, 0x000bffff, 0x00000000, + 0x00020000,,,) + + /* Data and GFX stolen memory */ + DWordMemory (ResourceProducer, PosDecode, MinFixed, MaxFixed, + Cacheable, ReadWrite, + 0x00000000, 0x3be00000, 0x3fffffff, 0x00000000, + 0x04200000,,, STOM) + + /* + * PCI MMIO Region (TOLUD - PCI extended base MMCONF) + * This assumes that MMCONF is placed after PCI config space, + * and that no resources are allocated after the MMCONF region. + * This works, sicne MMCONF is hardcoded to 0xe00000000. + */ + DWordMemory (ResourceProducer, PosDecode, MinFixed, MaxFixed, + NonCacheable, ReadWrite, + 0x00000000, 0x00000000, 0x00000000, 0x00000000, + 0x00000000,,, PM01) + + /* PCI Memory Region (TOUUD - (TOUUD + ABOVE_4G_MMIO_SIZE)) */ + QWordMemory (ResourceProducer, PosDecode, MinFixed, MaxFixed, + NonCacheable, ReadWrite, + 0x00000000, 0x10000, 0x1ffff, 0x00000000, + 0x10000,,, PM02) +}) + +/* Current Resource Settings */ +Method (_CRS, 0, Serialized) +{ + + /* Find PCI resource area in MCRS */ + CreateDwordField (MCRS, ^PM01._MIN, PMIN) + CreateDwordField (MCRS, ^PM01._MAX, PMAX) + CreateDwordField (MCRS, ^PM01._LEN, PLEN) + + /* Read C-Unit PCI CFG Reg. 0xBC for TOLUD (shadow from B-Unit) */ + And(^MCHC.TLUD, 0xFFF00000, PMIN) + /* Read MMCONF base */ + And(^MCHC.MCNF, 0xF0000000, PMAX) + + /* Calculate PCI MMIO Length */ + Add(Subtract(PMAX, PMIN), 1, PLEN) + + /* Find GFX resource area in GCRS */ + CreateDwordField(MCRS, ^STOM._MIN, GMIN) + CreateDwordField(MCRS, ^STOM._MAX, GMAX) + CreateDwordField(MCRS, ^STOM._LEN, GLEN) + + /* Read BGSM */ + And(^MCHC.BGSM, 0xFFF00000, GMIN) + + /* Read TOLUD */ + And(^MCHC.TLUD, 0xFFF00000, GMAX) + Decrement(GMAX) + Add(Subtract(GMAX, GMIN), 1, GLEN) + + /* Patch PM02 range based on Memory Size */ + CreateQwordField (MCRS, ^PM02._MIN, MMIN) + CreateQwordField (MCRS, ^PM02._MAX, MMAX) + CreateQwordField (MCRS, ^PM02._LEN, MLEN) + + Store (^MCHC.TUUD, Local0) + + If (LLessEqual (Local0, 0x1000000000)) { + Store (0, MMIN) + Store (0, MLEN) + } + Subtract (Add (MMIN, MLEN), 1, MMAX) + + Return (MCRS) +} +} \ No newline at end of file
