Attention is currently required from: Bora Guvendik, Furquan Shaikh, Maulik V Vaghela, Tim Wawrzynczak, Patrick Rudolph. Hello build bot (Jenkins), Maulik V Vaghela, Selma Bensaid, Tim Wawrzynczak, Ronak Kanabar, Tim Wawrzynczak, Patrick Rudolph,
https://review.coreboot.org/c/coreboot/+/54036
Change subject: soc/intel/alderlake: Update meminit code due to upd changes FSP 2147 onwards ......................................................................
DisableDimmMc0Ch0 upds changed to DisableMc0Ch0 in new FSP releases. The definition of the upd also changed. Changed FSP meminit code to work based on new definition of the UPDs.
Before: 0:Enable both DIMMs, 1:Disable DIMM0, 2:Disable DIMM1, 3:Disable both DIMMs
After: 0:Enable, 1:Disable
TEST=Boot to OS
Signed-off-by: Bora Guvendik bora.guvendik@intel.com Change-Id: I5af11ae99db3bbe3373a9bd4ce36453b58d62fec --- M src/soc/intel/alderlake/meminit.c 1 file changed, 14 insertions(+), 13 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/36/54036/2
