Raul Rangel has uploaded this change for review. ( https://review.coreboot.org/27876
Change subject: soc/amd/stoneyridge: Set undocumented misc register ......................................................................
By setting this register in bootblock AmdInitEnv will no longer trigger a reset in romstage. This fixes a few vboot test failures and also speeds up boot time.
BUG=b:111610455 TEST=Built grunt and made sure bootblock only happens once on cold boot, and S3 resume.
Change-Id: Ie19f7a14deaef45ac63156bec6946273c1b9447e Signed-off-by: Raul E Rangel rrangel@chromium.org --- M src/soc/amd/stoneyridge/southbridge.c 1 file changed, 21 insertions(+), 3 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/76/27876/1
diff --git a/src/soc/amd/stoneyridge/southbridge.c b/src/soc/amd/stoneyridge/southbridge.c index 348d5f1..c75aefd 100644 --- a/src/soc/amd/stoneyridge/southbridge.c +++ b/src/soc/amd/stoneyridge/southbridge.c @@ -556,7 +556,7 @@ } }
-static void setup_spread_spectrum(void) +static void setup_spread_spectrum(int *reboot) { uint16_t rstcfg = pm_read16(PWR_RESET_CFG);
@@ -606,11 +606,24 @@ cntl1 |= CG1PLL_FBDIV_TEST; misc_write32(MISC_CLK_CNTL1, cntl1);
- soft_reset(); + *reboot |= 1; +} + +static void setup_misc(int *reboot) +{ + uint32_t reg = misc_read32(0x50); + if (!(reg & (1 << 16))) { + reg |= 1 << 16; + + misc_write32(0x50, reg); + *reboot |= 1; + } }
void bootblock_fch_early_init(void) { + int reboot = 0; + sb_enable_rom(); sb_lpc_port80(); sb_lpc_decode(); @@ -619,7 +632,12 @@ sb_disable_4dw_burst(); /* Must be disabled on CZ(ST) */ sb_acpi_mmio_decode(); sb_enable_cf9_io(); - setup_spread_spectrum(); + setup_spread_spectrum(&reboot); + setup_misc(&reboot); + + if (reboot) + soft_reset(); + sb_enable_legacy_io(); enable_aoac_devices(); }
