Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/78193?usp=email )
2 is the latest approved patch-set. No files were changed between the latest approved patch-set and the submitted one. )Change subject: cpu/intel/model_206ax: Use haswell cstate_map ......................................................................
Make the code look like on newer platforms. This doesn't change functionality.
Test: Lenovo X220 still boots and advertises all C-states as before.
Change-Id: Ie7076d11720d55a4ac11318cbbdab9f75d08e15e Signed-off-by: Patrick Rudolph patrick.rudolph@9elements.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/78193 Reviewed-by: Kyösti Mälkki kyosti.malkki@gmail.com Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Felix Held felix-coreboot@felixheld.de --- M src/cpu/intel/model_206ax/acpi.c M src/cpu/intel/model_206ax/model_206ax.h 2 files changed, 37 insertions(+), 50 deletions(-)
Approvals: build bot (Jenkins): Verified Kyösti Mälkki: Looks good to me, approved Felix Held: Looks good to me, approved
diff --git a/src/cpu/intel/model_206ax/acpi.c b/src/cpu/intel/model_206ax/acpi.c index 2fceda1..c4f5839 100644 --- a/src/cpu/intel/model_206ax/acpi.c +++ b/src/cpu/intel/model_206ax/acpi.c @@ -13,79 +13,52 @@ #include "model_206ax.h" #include "chip.h"
+#define MWAIT_RES(state, sub_state) \ + { \ + .addrl = (((state) << 4) | (sub_state)), \ + .space_id = ACPI_ADDRESS_SPACE_FIXED, \ + .bit_width = ACPI_FFIXEDHW_VENDOR_INTEL, \ + .bit_offset = ACPI_FFIXEDHW_CLASS_MWAIT, \ + .access_size = ACPI_FFIXEDHW_FLAG_HW_COORD, \ + } + /* * List of supported C-states in this processor * * Latencies are typical worst-case package exit time in uS * taken from the SandyBridge BIOS specification. */ -static const acpi_cstate_t cstate_map[] = { - { /* 0: C0 */ - }, { /* 1: C1 */ +static acpi_cstate_t cstate_map[NUM_C_STATES] = { + [C_STATE_C0] = { }, + [C_STATE_C1] = { .latency = 1, .power = 1000, - .resource = { - .addrl = 0x00, /* MWAIT State 0 */ - .space_id = ACPI_ADDRESS_SPACE_FIXED, - .bit_width = ACPI_FFIXEDHW_VENDOR_INTEL, - .bit_offset = ACPI_FFIXEDHW_CLASS_MWAIT, - .access_size = ACPI_FFIXEDHW_FLAG_HW_COORD, - } + .resource = MWAIT_RES(0, 0), }, - { /* 2: C1E */ + [C_STATE_C1E] = { .latency = 1, .power = 1000, - .resource = { - .addrl = 0x01, /* MWAIT State 0 Sub-state 1 */ - .space_id = ACPI_ADDRESS_SPACE_FIXED, - .bit_width = ACPI_FFIXEDHW_VENDOR_INTEL, - .bit_offset = ACPI_FFIXEDHW_CLASS_MWAIT, - .access_size = ACPI_FFIXEDHW_FLAG_HW_COORD, - } + .resource = MWAIT_RES(0, 1), }, - { /* 3: C3 */ + [C_STATE_C3] = { .latency = 63, .power = 500, - .resource = { - .addrl = 0x10, /* MWAIT State 1 */ - .space_id = ACPI_ADDRESS_SPACE_FIXED, - .bit_width = ACPI_FFIXEDHW_VENDOR_INTEL, - .bit_offset = ACPI_FFIXEDHW_CLASS_MWAIT, - .access_size = ACPI_FFIXEDHW_FLAG_HW_COORD, - } + .resource = MWAIT_RES(1, 0), }, - { /* 4: C6 */ + [C_STATE_C6] = { .latency = 87, .power = 350, - .resource = { - .addrl = 0x20, /* MWAIT State 2 */ - .space_id = ACPI_ADDRESS_SPACE_FIXED, - .bit_width = ACPI_FFIXEDHW_VENDOR_INTEL, - .bit_offset = ACPI_FFIXEDHW_CLASS_MWAIT, - .access_size = ACPI_FFIXEDHW_FLAG_HW_COORD, - } + .resource = MWAIT_RES(2, 0), }, - { /* 5: C7 */ + [C_STATE_C7] = { .latency = 90, .power = 200, - .resource = { - .addrl = 0x30, /* MWAIT State 3 */ - .space_id = ACPI_ADDRESS_SPACE_FIXED, - .bit_width = ACPI_FFIXEDHW_VENDOR_INTEL, - .bit_offset = ACPI_FFIXEDHW_CLASS_MWAIT, - .access_size = ACPI_FFIXEDHW_FLAG_HW_COORD, - } + .resource = MWAIT_RES(3, 0), }, - { /* 6: C7S */ + [C_STATE_C7S] = { .latency = 90, .power = 200, - .resource = { - .addrl = 0x31, /* MWAIT State 3 Sub-state 1 */ - .space_id = ACPI_ADDRESS_SPACE_FIXED, - .bit_width = ACPI_FFIXEDHW_VENDOR_INTEL, - .bit_offset = ACPI_FFIXEDHW_CLASS_MWAIT, - .access_size = ACPI_FFIXEDHW_FLAG_HW_COORD, - } + .resource = MWAIT_RES(3, 1), }, };
diff --git a/src/cpu/intel/model_206ax/model_206ax.h b/src/cpu/intel/model_206ax/model_206ax.h index b145523..ecbf323 100644 --- a/src/cpu/intel/model_206ax/model_206ax.h +++ b/src/cpu/intel/model_206ax/model_206ax.h @@ -109,6 +109,20 @@ # error "CONFIG_IED_REGION_SIZE is not a power of 2" #endif
+/* + * List of supported C-states for Sandy Bridge/Ivy Bridge. + */ +enum { + C_STATE_C0 = 0, + C_STATE_C1 = 1, + C_STATE_C1E = 2, + C_STATE_C3 = 3, + C_STATE_C6 = 4, + C_STATE_C7 = 5, + C_STATE_C7S = 6, + NUM_C_STATES, +}; + /* Lock MSRs */ void intel_model_206ax_finalize_smm(void);
