Hello build bot (Jenkins), Patrick Georgi, Martin Roth, Angel Pons,
https://review.coreboot.org/c/coreboot/+/40278
Change subject: mb/purism/librem_whl: Add new board Librem Mini (WHL-U) ......................................................................
Add new librem_whl baseboard and Librem Mini variant.
Tested with SeaBIOS, Tianocore, and Heads payloads.
All functions working normally except SATA, which is limited via a FSP UDP to 3Gbps until the correct HSIO PHY settings can be determined.
https://puri.sm/products/librem-mini/
Signed-off-by: Matt DeVillier matt.devillier@puri.sm Change-Id: I36af42766f85eb17f86f6ec9b48b87125fb911e6 --- A src/mainboard/purism/librem_whl/Kconfig A src/mainboard/purism/librem_whl/Kconfig.name A src/mainboard/purism/librem_whl/Makefile.inc A src/mainboard/purism/librem_whl/acpi/mainboard.asl A src/mainboard/purism/librem_whl/board_info.txt A src/mainboard/purism/librem_whl/devicetree.cb A src/mainboard/purism/librem_whl/dsdt.asl A src/mainboard/purism/librem_whl/ramstage.c A src/mainboard/purism/librem_whl/romstage.c A src/mainboard/purism/librem_whl/variants/librem_mini/data.vbt A src/mainboard/purism/librem_whl/variants/librem_mini/gpio.c A src/mainboard/purism/librem_whl/variants/librem_mini/hda_verb.c A src/mainboard/purism/librem_whl/variants/librem_mini/include/variant/gpio.h 13 files changed, 690 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/78/40278/8
