Attention is currently required from: Jason Glenesk, Raul Rangel, Matt DeVillier, Tim Van Patten, Fred Reitberger.
Hello build bot (Jenkins), Jason Glenesk, Raul Rangel, Matt DeVillier, Fred Reitberger, Felix Held,
https://review.coreboot.org/c/coreboot/+/74126
Change subject: soc/amd/mendocino: Reinterpret smu_power_and_thm_limit ......................................................................
The FSP will return the TDP in the format 0xX0000, where 'X' is the value we're interested in. For example: 0xF0000 (15W), 0x60000 (6W). Re-interpret the value so the caller just sees the TDP directly, without needing to re-interpret things themselves.
BUG=b:253301653 TEST=Manually verify value is correct
Change-Id: I632e702d986a4ac85605040e09c1afab2bbdc59d Signed-off-by: Tim Van Patten timvp@google.com --- M src/soc/amd/mendocino/fsp_misc_data_hob.c 1 file changed, 26 insertions(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/26/74126/5
