Attention is currently required from: Martin Roth, Matt DeVillier.
Felix Held has posted comments on this change by Felix Held. ( https://review.coreboot.org/c/coreboot/+/84786?usp=email )
Change subject: drivers/spi/spi_flash_sfdp: add basic SFDP support ......................................................................
Patch Set 11:
(4 comments)
Commit Message:
https://review.coreboot.org/c/coreboot/+/84786/comment/6e7d0325_a5b8a97f?usp... : PS10, Line 10: a : specific
Nit: Maybe you only tested on one chip, but this should work with any chip that supports this mechan […]
Done
File src/drivers/spi/spi_flash_sfdp.c:
https://review.coreboot.org/c/coreboot/+/84786/comment/9f1615d5_ade311b8?usp... : PS10, Line 46: 0x50444653
Nit: Use the ascii characters instead, or at least include them as a comment?
the cbmem ids also use hex numbers instead of char arrays; the byte order is also in reverse. i'll add a comment
https://review.coreboot.org/c/coreboot/+/84786/comment/2bd17df1_f39c0438?usp... : PS10, Line 158: %#x
%p?
it's an uint32_t, not an actual c pointer, so %#x is correct here
https://review.coreboot.org/c/coreboot/+/84786/comment/32a3c4ea_bb00e59f?usp... : PS10, Line 176: if (get_sfdp_header(flash, &sfdp_rev, ¶m_header_count, &access_protocol) != CB_SUCCESS)
Does this line need to be wrapped?
makes the code look a bit worse, but yes
