Timothy Pearson (tpearson@raptorengineeringinc.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/12026
-gerrit
commit f610ca1911e87beffadd6dd0448fad2ef6f6059b Author: Timothy Pearson tpearson@raptorengineeringinc.com Date: Sun Aug 2 21:31:48 2015 -0500
cpu/amd/family_10h-family_15h: Fix incorrect revision detection
Change-Id: I7a881a94d62ed455415f9dfc887fd698ac919429 Signed-off-by: Timothy Pearson tpearson@raptorengineeringinc.com --- src/cpu/amd/family_10h-family_15h/fidvid.c | 10 +++++----- 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/src/cpu/amd/family_10h-family_15h/fidvid.c b/src/cpu/amd/family_10h-family_15h/fidvid.c index 471456a..ed8cafa 100644 --- a/src/cpu/amd/family_10h-family_15h/fidvid.c +++ b/src/cpu/amd/family_10h-family_15h/fidvid.c @@ -375,7 +375,7 @@ static void recalculateVsSlamTimeSettingOnCorePre(device_t dev) pci_write_config32(dev, 0xd8, dtemp); }
-static u32 nb_clk_did(int node, u32 cpuRev,u8 procPkg) { +static u32 nb_clk_did(int node, uint64_t cpuRev, uint8_t procPkg) { u8 link0isGen3 = 0; u8 offset; if (AMD_CpuFindCapability(node, 0, &offset)) { @@ -446,7 +446,7 @@ static u32 power_up_down(int node, u8 procPkg) { return dword; }
-static void config_clk_power_ctrl_reg0(int node, u32 cpuRev, u8 procPkg) { +static void config_clk_power_ctrl_reg0(int node, uint64_t cpuRev, uint8_t procPkg) { device_t dev = NODE_PCI(node, 3);
/* Program fields in Clock Power/Control register0 (F3xD4) */ @@ -471,7 +471,7 @@ static void config_clk_power_ctrl_reg0(int node, u32 cpuRev, u8 procPkg) {
-static void config_power_ctrl_misc_reg(device_t dev,u32 cpuRev, u8 procPkg) { +static void config_power_ctrl_misc_reg(device_t dev, uint64_t cpuRev, uint8_t procPkg) { /* check PVI/SVI */ u32 dword = pci_read_config32(dev, 0xa0);
@@ -504,7 +504,7 @@ static void config_power_ctrl_misc_reg(device_t dev,u32 cpuRev, u8 procPkg) { pci_write_config32(dev, 0xa0, dword); }
-static void config_nb_syn_ptr_adj(device_t dev, u32 cpuRev) { +static void config_nb_syn_ptr_adj(device_t dev, uint64_t cpuRev) { /* Note the following settings are additional from the ported * function setFidVidRegs() */ @@ -526,7 +526,7 @@ static void config_nb_syn_ptr_adj(device_t dev, u32 cpuRev) { pci_write_config32(dev, 0xdc, dword); }
-static void config_acpi_pwr_state_ctrl_regs(device_t dev, u32 cpuRev, u8 procPkg) { +static void config_acpi_pwr_state_ctrl_regs(device_t dev, uint64_t cpuRev, uint8_t procPkg) { if (is_fam15h()) { /* Family 15h BKDG Rev. 3.14 D18F3x80 recommended settings */ pci_write_config32(dev, 0x80, 0xe20be281);
