Rizwan Qureshi (rizwan.qureshi@intel.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/18469
commit f77fd08d7d1c4fbdbe259b700454981ab4c4e8b2 Author: Rizwan Qureshi rizwan.qureshi@intel.com Date: Thu Feb 23 14:43:39 2017 +0530
soc/intel/skylake: indicate voltage margining enabled/disabled
Support for voltage margining is dependent on the platform. Enbaling voltage margining puts additional constraints for the SLP_S0# to be asserted and hence moving to S0ix state. If the platform PMIC/VR supports PCH voltage reduction, voltage marigining can be enabled.
Use the UPD provided by FSP to enable/disable voltage margining.
Change-Id: Iea214e9d7d6126e8367426485c6446ced63caa66 Signed-off-by: Rizwan Qureshi rizwan.qureshi@intel.com --- src/soc/intel/skylake/chip.h | 8 ++++++++ src/soc/intel/skylake/chip_fsp20.c | 4 ++++ 2 files changed, 12 insertions(+)
diff --git a/src/soc/intel/skylake/chip.h b/src/soc/intel/skylake/chip.h index 2e4adb2..8e6fa69 100644 --- a/src/soc/intel/skylake/chip.h +++ b/src/soc/intel/skylake/chip.h @@ -333,6 +333,14 @@ struct soc_intel_skylake_config { * Values: 0x0 - 4s, 0x1 - 6s, 0x2 - 8s, 0x3 - 10s, 0x4 - 12s, 0x5 - 14s */ u8 PmConfigPwrBtnOverridePeriod; + + /* + * PCH Pm Slp S0 Voltage Margining Enable + * Indicates platform has support for VCCPrim_Core Voltage Margining + * in SLP_S0# asserted state. + */ + u8 PchPmSlpS0VmEnable; + /* * Reset Power Cycle Duration could be customized in the unit of second. * PCH HW default is 4 seconds, and range is 1~4 seconds. diff --git a/src/soc/intel/skylake/chip_fsp20.c b/src/soc/intel/skylake/chip_fsp20.c index 8b8c37c..81e8df9 100644 --- a/src/soc/intel/skylake/chip_fsp20.c +++ b/src/soc/intel/skylake/chip_fsp20.c @@ -220,6 +220,10 @@ void platform_fsp_silicon_init_params_cb(FSPS_UPD *supd) params->PchPmPwrBtnOverridePeriod = config->PmConfigPwrBtnOverridePeriod; params->PchPmPwrCycDur = config->PmConfigPwrCycDur; + + /* Indicate whether platform supports Voltage margining */ + params->PchPmSlpS0VmEnable = config->PchPmSlpS0VmEnable; + params->PchSirqEnable = config->SerialIrqConfigSirqEnable; params->PchSirqMode = config->SerialIrqConfigSirqMode;
