Attention is currently required from: Arthur Heymans, Patrick Rudolph, Christian Walter.
Angel Pons has uploaded a new patch set (#7) to the change originally created by Arthur Heymans. ( https://review.coreboot.org/c/coreboot/+/62649 )
Change subject: mb/prodrive/hermes: Allow using the Intel iGPU as primary ......................................................................
Configure the Intel iGPU as primary video adapter if enabled according to EEPROM settings. The default is to use the ASPEED BMC as primary video adapter, which only has a VGA output and the remote KVM output.
TODO: Figure out why iGPU video stops working after booting Linux and doing a warm (no power cycle) reboot.
TEST=Test that DP and HDMI outputs work in pre-OS and on Linux using the Poseidon piggy-back board, which has two DisplayPort outputs and one HDMI output from a LSPCON.
Change-Id: I24d9ebc2055dc246e7f257aa2f3853b22c8af370 Signed-off-by: Arthur Heymans arthur@aheymans.xyz --- M src/mainboard/prodrive/hermes/eeprom.h M src/mainboard/prodrive/hermes/mainboard.c M src/mainboard/prodrive/hermes/romstage.c 3 files changed, 56 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/49/62649/7
