Tim Wawrzynczak has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/34179 )
Change subject: soc/intel/cannonlake: Add GCFG method to GPIO ASL. ......................................................................
The new method returns the address of a GPIO community's MISCCFG register.
Change-Id: I098ee08573eb4f8a45d9b5ae84f2d85ce525c9b8 Signed-off-by: Tim Wawrzynczak twawrzynczak@chromium.org --- M src/soc/intel/cannonlake/acpi/gpio.asl 1 file changed, 37 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/79/34179/1
diff --git a/src/soc/intel/cannonlake/acpi/gpio.asl b/src/soc/intel/cannonlake/acpi/gpio.asl index 9df1cf7..71a11b1 100644 --- a/src/soc/intel/cannonlake/acpi/gpio.asl +++ b/src/soc/intel/cannonlake/acpi/gpio.asl @@ -107,3 +107,40 @@ Add (Local2, PAD_CFG_BASE, Local2) Return (Add (Local2, Multiply (Local1, 16))) } + +/* + * Get GPIO Community MISCCFG Address + * Arg0 - GPIO Community Number + */ +Method (GCFG, 1, NotSerialized) +{ + /* GPIO Community 0 */ + If (LEqual (Arg0, 0)) + { + Store (PID_GPIOCOM0, Local0) + } + /* GPIO Community 1 */ + If (LEqual (Arg0, 1)) + { + Store (PID_GPIOCOM1, Local0) + } + /* GPIO Community 2 */ + If (LEqual (Arg0, 2)) + { + Store (PID_GPIOCOM2, Local0) + } + /* GPIO Community 3 */ + If (LEqual (Arg0, 3)) + { + Store (PID_GPIOCOM3, Local0) + } + /* GPIO Community 4*/ + If (LEqual (Arg0, 4)) + { + Store (PID_GPIOCOM4, Local0) + } + + Store (PCRB (Local0), Local1) + Add (Local1, 16, Local1) + Return (Local1) +}
Hello Patrick Rudolph, Subrata Banik, Duncan Laurie, Shelley Chen, Furquan Shaikh,
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/79/34179/2
Hello Patrick Rudolph, Subrata Banik, Duncan Laurie, Shelley Chen, build bot (Jenkins), Furquan Shaikh,
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/79/34179/3
Paul Fagerburg has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/34179 )
Patch Set 3: Code-Review+1
Hello Patrick Rudolph, Paul Fagerburg, Subrata Banik, Duncan Laurie, Shelley Chen, build bot (Jenkins), Furquan Shaikh,
Change subject: soc/intel/cannonlake: Add GCFG & CGPM method to GPIO ASL. ......................................................................
The GCFG method returns the address of a GPIO community's MISCCFG register. CGPM sets the PM bits of a GPIO community's MISCCFG register.
Change-Id: I098ee08573eb4f8a45d9b5ae84f2d85ce525c9b8 Signed-off-by: Tim Wawrzynczak twawrzynczak@chromium.org --- M src/soc/intel/cannonlake/acpi/gpio.asl 1 file changed, 62 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/79/34179/5
Patch Set 5: Code-Review+1
Furquan Shaikh has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/34179 )
Patch Set 5:
(4 comments)
https://review.coreboot.org/c/coreboot/+/34179/5/src/soc/intel/cannonlake/ac... File src/soc/intel/cannonlake/acpi/gpio.asl:
https://review.coreboot.org/c/coreboot/+/34179/5/src/soc/intel/cannonlake/ac... PS5, Line 122: ByteAcc DWordAcc?
https://review.coreboot.org/c/coreboot/+/34179/5/src/soc/intel/cannonlake/ac... PS5, Line 129: LAnd I guess you want to use And and not LAnd? LAnd is Logical And whereas And is Bitwise AND. Same for Land and Lor in the statements below.
https://review.coreboot.org/c/coreboot/+/34179/5/src/soc/intel/cannonlake/ac... PS5, Line 127: Store (REG, Local0) : /* Ensure only PM bits can be set */ : Store (LAnd (Arg1, MISCCFG_ENABLE_GPIO_PM_CONFIG), Local1) : /* Clear PM bits */ : Store (LAnd (LNot (MISCCFG_ENABLE_GPIO_PM_CONFIG), Local0), Local0) : Store (LOr (Local1, Local0), Local1) : Store (Local1, REG) : } Just curious. Any reason not to use PCRA and PCRO methods provided by pcr.asl? Then you won't need to define OpRegion, Field here or perform and/or operations. Less code:
Local0 <-- PID_GPIOCOMx
PCRA (Local0, GPIO_MISCCFG, Not (MISCCFG_ENABLE_GPIO_PM_CONFIG)) PCRO (Local0, GPIO_MISCCFG, And (Arg1, MISCCFG_ENABLE_GPIO_PM_CONFIG))
https://review.coreboot.org/c/coreboot/+/34179/5/src/soc/intel/cannonlake/ac... PS5, Line 169: 16 GPIO_MISCCFG
Tim Wawrzynczak has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/34179 )
Patch Set 5:
(4 comments)
DWordAcc?
Done
I guess you want to use And and not LAnd? LAnd is Logical And whereas And is Bitwise AND. […]
Done
Just curious. Any reason not to use PCRA and PCRO methods provided by pcr. […]
Oh I missed those, that's great!
GPIO_MISCCFG
Oh yeah, I was using that until I got the #include<> and then forgot.
Change subject: soc/intel/cannonlake: Add GPID and CGPM methods to GPIO ASL ......................................................................
The GPID method returns the PCR Port ID of the given GPIO community. The CGPM method alters the given GPIO community's PM bits, given in Arg1.
Change-Id: I098ee08573eb4f8a45d9b5ae84f2d85ce525c9b8 Signed-off-by: Tim Wawrzynczak twawrzynczak@chromium.org --- M src/soc/intel/cannonlake/acpi/gpio.asl 1 file changed, 45 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/79/34179/6
Patch Set 6: Code-Review+2
Lance Zhao has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/34179 )
Patch Set 6:
https://review.coreboot.org/c/coreboot/+/34179/6/src/soc/intel/cannonlake/ac... File src/soc/intel/cannonlake/acpi/gpio.asl:
https://review.coreboot.org/c/coreboot/+/34179/6/src/soc/intel/cannonlake/ac... PS6, Line 134: Store (PID_GPIOCOM0, Local0) If some one messed up with GPID number that will accidentally program community 0? What about dothing or return with something safe?
Patch Set 6: -Code-Review
If some one messed up with GPID number that will accidentally program community 0? What about dothin […]
Humm.. I was thinking about the same when reviewing this. But what would be a safe value? Maybe 0? And then caller can just do nothing if 0 is returned?
Patch Set 6:
Caller will do nothing sounds good to me.
Subrata Banik has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/34179 )
Patch Set 6:
Humm.. I was thinking about the same when reviewing this. […]
i would recommend for a check above itself and return If (LAnd (LGreaterEqual (Arg0, 1), LLessEqual (Arg0, 4))
Change-Id: I098ee08573eb4f8a45d9b5ae84f2d85ce525c9b8 Signed-off-by: Tim Wawrzynczak twawrzynczak@chromium.org --- M src/soc/intel/cannonlake/acpi/gpio.asl 1 file changed, 50 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/79/34179/7
Patch Set 8:
https://review.coreboot.org/c/coreboot/+/34179/8/src/soc/intel/cannonlake/ac... File src/soc/intel/cannonlake/acpi/gpio.asl:
https://review.coreboot.org/c/coreboot/+/34179/8/src/soc/intel/cannonlake/ac... PS8, Line 137: Return (0) not sure if you have a check to skip PCR programming if PID is 0 ?
Patch Set 8:
I updated the GPID method to return 0 for an invalid GPIO community, and the one consumer of the function now checks for GPID returning 0, in which case it does nothing.
Patch Set 8:
Check line 153 below
Patch Set 8:
got it, looks good now
Patch Set 8: Code-Review+1
Patch Set 8: Code-Review+2
Martin Roth has submitted this change and it was merged. ( https://review.coreboot.org/c/coreboot/+/34179 )
Change-Id: I098ee08573eb4f8a45d9b5ae84f2d85ce525c9b8 Signed-off-by: Tim Wawrzynczak twawrzynczak@chromium.org Reviewed-on: https://review.coreboot.org/c/coreboot/+/34179 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Subrata Banik subrata.banik@intel.com Reviewed-by: Furquan Shaikh furquan@google.com --- M src/soc/intel/cannonlake/acpi/gpio.asl 1 file changed, 50 insertions(+), 0 deletions(-)
Approvals: build bot (Jenkins): Verified Furquan Shaikh: Looks good to me, approved Subrata Banik: Looks good to me, but someone else must approve
diff --git a/src/soc/intel/cannonlake/acpi/gpio.asl b/src/soc/intel/cannonlake/acpi/gpio.asl index 9df1cf7..65332ad 100644 --- a/src/soc/intel/cannonlake/acpi/gpio.asl +++ b/src/soc/intel/cannonlake/acpi/gpio.asl @@ -16,6 +16,7 @@ #include <soc/gpio_defs.h> #include <soc/irq.h> #include <soc/pcr_ids.h> +#include <intelblocks/gpio.h> #include "gpio_op.asl"
Device (GPIO) @@ -107,3 +108,52 @@ Add (Local2, PAD_CFG_BASE, Local2) Return (Add (Local2, Multiply (Local1, 16))) } + +/* + * Return PCR Port ID of GPIO Communities + * + * Arg0: GPIO Community (0-4) + */ +Method (GPID, 1, Serialized) +{ + Switch (ToInteger (Arg0)) + { + Case (0) { + Store (PID_GPIOCOM0, Local0) + } + Case (1) { + Store (PID_GPIOCOM1, Local0) + } + Case (2) { + Store (PID_GPIOCOM2, Local0) + } + Case (3) { + Store (PID_GPIOCOM3, Local0) + } + Case (4) { + Store (PID_GPIOCOM4, Local0) + } + Default { + Return (0) + } + } + + Return (Local0) +} + +/* + * Configure GPIO Power Management bits + * + * Arg0: GPIO community (0-4) + * Arg1: PM bits in MISCCFG + */ +Method (CGPM, 2, Serialized) +{ + Store (GPID (Arg0), Local0) + If (LNotEqual (Local0, 0)) { + /* Mask off current PM bits */ + PCRA (Local0, GPIO_MISCCFG, Not (MISCCFG_ENABLE_GPIO_PM_CONFIG)) + /* Mask in requested bits */ + PCRO (Local0, GPIO_MISCCFG, And (Arg1, MISCCFG_ENABLE_GPIO_PM_CONFIG)) + } +}
