Attention is currently required from: Mario Scheithauer, Uwe Poeche, Werner Zeh.
Hello Mario Scheithauer, Uwe Poeche, Werner Zeh, build bot (Jenkins), siemens-bot,
https://review.coreboot.org/c/coreboot/+/85606?usp=email
The following approvals got outdated and were removed: Code-Review+1 by Mario Scheithauer, Code-Review+1 by Uwe Poeche, Verified+1 by build bot (Jenkins), Verified-1 by siemens-bot
Change subject: soc/intel/common/block/power_limit: Disable RAPL via MSR completely ......................................................................
Disabling RAPL via Kconfig switch SOC_INTEL_DISABLE_POWER_LIMITS does not turn off RAPL completely (i.d. MMIO & MSR). In the past it was assumed disabling RAPL via MCHBAR is sufficient and the corresponding changes are also reflected in the related MSR (0x610-PACKAGE_POWER_LIMIT). This is not the case for Power Limit 2 (PL2) because Bit[47]-PKG_PWR_LIM_2_EN is still set although PL1 and PL2 were disabled through MCHBAR.
Thus Bit[10]-POWER_LIMITATION_STATUS flag can be set in MSR 0x19C (THERM_STATUS) when the power limit of the SKU exceeds. This may lead to a throttling of the domain level frequency. Moreover related parameters within the same MSR (0x610-PACKAGE_POWER_LIMIT) like PKG_PWR_LIM_TIME, PKG_CLMP_LIM, PKG_PWR_LIM have to be cleared as well for both Power Limits (PL1 & PL2). This is due to the fact that these parameters stray in to the system and may effect different system settings.
With this commit the PACKAGE_POWER_LIMIT MSR is cleared additionally to the MCHBAR setting when build for ElkhartLake.
TEST=Verify MSR(0x610-PACKAGE_POWER_LIMIT) is set to zero during OS runtime except Bit[15]-PKG_PWR_LIM_1_EN (it is known as a bug that this bit will be set to 1 anyway). Moreover using a system stress test tool (e.g. Passmark's BurnInTest) and stressing the system hard should not lead to Bit[10]-POWER_LIMITATION_STATUS flag being set. This is the case when MSR (0x610-PACKAGE_POWER_LIMIT) is not cleared completely and the system is stressed intensively.
Change-Id: I8272339a991667d5ba177f4755ec40e1961d729e Signed-off-by: Johannes Hahn johannes-hahn@siemens.com --- M src/soc/intel/common/block/power_limit/power_limit.c 1 file changed, 8 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/06/85606/5
