Subrata Banik has submitted this change. ( https://review.coreboot.org/c/coreboot/+/69041 )
Change subject: soc/intel/meteorlake: Use index 0x10 instead of 0 for IOE P2SB ......................................................................
This patch uses index 0x10 for IOE P2SB memory resource allocation instead of static 0.
Additionally, switches to `mmio_resource` from `mmio_resource_kb`.
TEST=Able to build and boot Google/Rex and observed log as below.
Without the code change:
[SPEW ] PCI: 00:13.0 resource base 3fff0aa0000 size 1400 align 0 gran 0 limit 0 flags f0000200 index 0
With the code change:
[SPEW ] PCI: 00:13.0 resource base 3fff0aa0000 size 1400 align 0 gran 0 limit 0 flags f0000200 index 10
Signed-off-by: Subrata Banik subratabanik@google.com Change-Id: I44caac73e245f536f3a22baafa1a6a0370e1dd37 Reviewed-on: https://review.coreboot.org/c/coreboot/+/69041 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Eric Lai eric_lai@quanta.corp-partner.google.com Reviewed-by: Kapil Porwal kapilporwal@google.com Reviewed-by: Ivy Jian ivy.jian@quanta.corp-partner.google.com --- M src/soc/intel/meteorlake/p2sb.c 1 file changed, 33 insertions(+), 1 deletion(-)
Approvals: build bot (Jenkins): Verified Eric Lai: Looks good to me, approved Ivy Jian: Looks good to me, approved Kapil Porwal: Looks good to me, approved
diff --git a/src/soc/intel/meteorlake/p2sb.c b/src/soc/intel/meteorlake/p2sb.c index d700c70..ae9b9a4 100644 --- a/src/soc/intel/meteorlake/p2sb.c +++ b/src/soc/intel/meteorlake/p2sb.c @@ -35,7 +35,7 @@ static void ioe_p2sb_read_resources(struct device *dev) { /* Add the fixed MMIO resource for IOM */ - mmio_resource_kb(dev, 0, IOM_BASE_ADDR / KiB, IOM_BASE_SIZE / KiB); + mmio_range(dev, PCI_BASE_ADDRESS_0, IOM_BASE_ADDR, IOM_BASE_SIZE); }
static void p2sb_read_resources(struct device *dev)
