Attention is currently required from: Martin Roth, Mathew King. Hello build bot (Jenkins), Raul Rangel, Furquan Shaikh, Patrick Georgi, Martin Roth, Mathew King,
https://review.coreboot.org/c/coreboot/+/52355
Change subject: mb/google/guybrush/var/guybrush: Add GPIO override table ......................................................................
EN_SPKR is routed to SD pin in the ALC1019 speaker amplifier. The concerned pin has a voltage rating of 1.8V whereas the EN_SPKR GPIO has a voltage rating of 3.3 V. The schematics has been updated to bridge the gap. So enable the speaker amplifier by default and add a gpio override table to disable the speakers before board version 2.
Also update the codec ACPI HID name for the kernel machine driver to probe the codec successfully.
BUG=b:182960979 TEST=Build and boot to OS in guybrush. Ensure that the GPIO output state is high.
Change-Id: I32b29bfae9bc94b5119b33a535d8bc825ef89445 Signed-off-by: Karthikeyan Ramasubramanian kramasub@google.com --- M src/mainboard/google/guybrush/variants/baseboard/gpio.c M src/mainboard/google/guybrush/variants/guybrush/Makefile.inc A src/mainboard/google/guybrush/variants/guybrush/gpio.c 3 files changed, 30 insertions(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/55/52355/5
