Hello build bot (Jenkins), Werner Zeh,
https://review.coreboot.org/c/coreboot/+/42794
to look at the new patch set (#13).
Change subject: crossgcc: Allow GCC to get asan shadow offset at runtime ......................................................................
Unlike Linux kernel which has a static shadow region layout, we have multiple stages in coreboot and thus require a different shadow offset address at each stage. Unfortunately, GCC currently, only supports adding a static shadow offset at compile time using -fasan-shadow-offset flag.
For this reason, we enable GCC to determine asan shadow offset address at runtime using a callback function __asan_shadow_offset(). This supersedes the need to specify this address at compile time. GCC then make use of this shadow offset to protect stack buffers and globals by inserting red zones around them.
Change-Id: I401631938532a406a6d41e77c6c9716b6b2bf48d Signed-off-by: Harshit Sharma harshitsharmajs@gmail.com --- A util/crossgcc/patches/gcc-8.3.0_asan_shadow_offset_callback.patch 1 file changed, 97 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/94/42794/13
