Patrick Rudolph has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/46821 )
Change subject: cpu/x86/mpinit/sipi_vector: Move code to C ......................................................................
Use a C helper function to do early x86 CPU init. The code is compiled without SSE and without optimizations.
Use existing code to update microcode.
Tested on Supermicro X11SSH: * The microcode is still updated on all core * All cores call into MPinit code
Change-Id: Ib6c2ffa2ce8c42eee9f3fe8ec8cff933942207ca Signed-off-by: Patrick Rudolph patrick.rudolph@9elements.com --- M src/cpu/x86/Makefile.inc M src/cpu/x86/mp_init.c M src/cpu/x86/sipi_vector.S A src/cpu/x86/sipi_vector_c_handler.c M src/include/cpu/x86/mp.h 5 files changed, 150 insertions(+), 124 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/21/46821/1
diff --git a/src/cpu/x86/Makefile.inc b/src/cpu/x86/Makefile.inc index 66b1a68..54e2397 100644 --- a/src/cpu/x86/Makefile.inc +++ b/src/cpu/x86/Makefile.inc @@ -26,8 +26,11 @@
$(eval $(call create_class_compiler,sipi_vec,$(ARCH-$(TARGET_STAGE)-y))) sipi_vec-generic-ccopts = $(rmodule_$(ARCH-$(TARGET_STAGE)-y)-generic-ccopts) +sipi_vec-generic-ccopts += -mno-sse -O0
sipi_vec-$(CONFIG_PARALLEL_MP) += sipi_vector.S +sipi_vec-$(CONFIG_PARALLEL_MP) += sipi_vector_c_handler.c +sipi_vec-$(CONFIG_PARALLEL_MP) += $(top)/src/cpu/intel/microcode/microcode.c
$(SIPI_DOTO): $$(sipi_vec-objs) $(COMPILER_RT_sipi_vec) $(LD_sipi_vec) -nostdlib -r -o $@ $(COMPILER_RT_FLAGS_sipi_vec) --whole-archive --start-group $(sipi_vec-objs) --no-whole-archive $(COMPILER_RT_sipi_vec) --end-group diff --git a/src/cpu/x86/mp_init.c b/src/cpu/x86/mp_init.c index 4870529..83d71190 100644 --- a/src/cpu/x86/mp_init.c +++ b/src/cpu/x86/mp_init.c @@ -83,29 +83,6 @@ int num_records; };
-/* This needs to match the layout in the .module_parametrs section. */ -struct sipi_params { - uint16_t gdtlimit; - uint32_t gdt; - uint16_t unused; - uint32_t idt_ptr; - uint32_t stack_top; - uint32_t stack_size; - uint32_t microcode_lock; /* 0xffffffff means parallel loading. */ - uint32_t microcode_ptr; - uint32_t msr_table_ptr; - uint32_t msr_count; - uint32_t c_handler; - atomic_t ap_count; -} __packed; - -/* This also needs to match the assembly code for saved MSR encoding. */ -struct saved_msr { - uint32_t index; - uint32_t lo; - uint32_t hi; -} __packed; - /* The sipi vector rmodule is included in the ramstage using 'objdump -B'. */ extern char _binary_sipi_vector_start[];
diff --git a/src/cpu/x86/sipi_vector.S b/src/cpu/x86/sipi_vector.S index ba1ecb7..52ca6ba 100644 --- a/src/cpu/x86/sipi_vector.S +++ b/src/cpu/x86/sipi_vector.S @@ -1,10 +1,14 @@ /* SPDX-License-Identifier: GPL-2.0-only */
#include <cpu/x86/cr.h> -#include <cpu/amd/mtrr.h> #include <cpu/x86/msr.h> #include <arch/ram_segs.h>
+#define CR0_CLEAR_FLAGS_CACHE_ENABLE (CR0_CD | CR0_NW) +#define CR0_CLEAR_FLAGS \ + (CR0_PG | CR0_AM | CR0_WP | CR0_NE | CR0_TS | CR0_EM | CR0_MP) +#define CR0_SET_FLAGS (CR0_CLEAR_FLAGS_CACHE_ENABLE | CR0_PE) + /* The SIPI vector is responsible for initializing the APs in the system. It * loads microcode, sets up MSRs, and enables caching before calling into * C code. */ @@ -34,11 +38,6 @@ ap_count: .long 0
-#define CR0_CLEAR_FLAGS_CACHE_ENABLE (CR0_CD | CR0_NW) -#define CR0_SET_FLAGS (CR0_CLEAR_FLAGS_CACHE_ENABLE | CR0_PE) -#define CR0_CLEAR_FLAGS \ - (CR0_PG | CR0_AM | CR0_WP | CR0_NE | CR0_TS | CR0_EM | CR0_MP) - .text .code16 .global _start @@ -101,102 +100,13 @@ /* Save CPU number. */ mov %ecx, %esi
- /* Determine if one should check microcode versions. */ - mov microcode_ptr, %edi - test %edi, %edi - jz microcode_done /* Bypass if no microde exists. */ + /* sipi_secondary_early_entry(ap_start_params), preserve proper stack alignment */ + sub $8, %esp + push %esi + leal ap_start_params, %eax + push %eax + call sipi_secondary_early_entry
- /* Get the Microcode version. */ - mov $1, %eax - cpuid - mov $IA32_BIOS_SIGN_ID, %ecx - rdmsr - /* If something already loaded skip loading again. */ - test %edx, %edx - jnz microcode_done - - /* Determine if parallel microcode loading is allowed. */ - cmpl $0xffffffff, microcode_lock - je load_microcode - - /* Protect microcode loading. */ -lock_microcode: - lock bts $0, microcode_lock - jc lock_microcode - -load_microcode: - /* Load new microcode. */ - mov $IA32_BIOS_UPDT_TRIG, %ecx - xor %edx, %edx - mov %edi, %eax - /* The microcode pointer is passed in pointing to the header. Adjust - * pointer to reflect the payload (header size is 48 bytes). */ - add $48, %eax - pusha - wrmsr - popa - - /* Unconditionally unlock microcode loading. */ - cmpl $0xffffffff, microcode_lock - je microcode_done - - xor %eax, %eax - mov %eax, microcode_lock - -microcode_done: - /* - * Load MSRs. Each entry in the table consists of: - * 0: index, - * 4: value[31:0] - * 8: value[63:32] - */ - mov msr_table_ptr, %edi - mov msr_count, %ebx - test %ebx, %ebx - jz 1f - -#if CONFIG(X86_AMD_FIXED_MTRRS) - /* Allow modification of RdDram and WrDram bits */ - mov $SYSCFG_MSR, %ecx - rdmsr - or $SYSCFG_MSR_MtrrFixDramModEn, %eax - wrmsr -#endif - -load_msr: - mov (%edi), %ecx - mov 4(%edi), %eax - mov 8(%edi), %edx - wrmsr - add $12, %edi - dec %ebx - jnz load_msr - -#if CONFIG(X86_AMD_FIXED_MTRRS) - mov $SYSCFG_MSR, %ecx - rdmsr - and $~SYSCFG_MSR_MtrrFixDramModEn, %eax - wrmsr -#endif - -1: - /* Enable caching. */ - mov %cr0, %eax - and $~(CR0_CLEAR_FLAGS_CACHE_ENABLE), %eax - mov %eax, %cr0 - -#if CONFIG(SSE) - /* Enable sse instructions. */ - mov %cr4, %eax - orl $(CR4_OSFXSR | CR4_OSXMMEXCPT), %eax - mov %eax, %cr4 -#endif - - /* c_handler(cpu_num), preserve proper stack alignment */ - sub $12, %esp - push %esi /* cpu_num */ - mov c_handler, %eax - call *%eax halt_jump: hlt jmp halt_jump diff --git a/src/cpu/x86/sipi_vector_c_handler.c b/src/cpu/x86/sipi_vector_c_handler.c new file mode 100644 index 0000000..dab6c65 --- /dev/null +++ b/src/cpu/x86/sipi_vector_c_handler.c @@ -0,0 +1,113 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ + +#include <cpu/x86/mp.h> +#include <cpu/x86/msr.h> +#include <cpu/x86/cr.h> +#include <arch/cpu.h> +#include <cpu/intel/microcode.h> +#include <cpu/amd/mtrr.h> + +asmlinkage void sipi_secondary_early_entry(struct sipi_params *params, int cpu_num); + +#define CR0_CLEAR_FLAGS_CACHE_ENABLE (CR0_CD | CR0_NW) + +static void sipi_update_microcode(struct sipi_params *params) +{ + /* Determine if one should check microcode versions. */ + if (!params->microcode_ptr) + return; + + /* Get the Microcode version. */ + const uint32_t rev = get_current_microcode_rev(); + + /* If something already loaded skip loading again. */ + if (rev) + return; + + /* Determine if parallel microcode loading is allowed. */ + if (params->microcode_lock != 0xffffffff) { + + /* Protect microcode loading. */ + asm volatile( + "\tlock_microcode:\n" + "\tlock bts $0, %0\n" + "\tjc lock_microcode\n" + : "=m"(params->microcode_lock) + : "m"(params->microcode_lock)); + } + + /* Load new microcode. */ + intel_microcode_load_unlocked((void *)((uintptr_t)params->microcode_ptr)); + + /* Unconditionally unlock microcode loading. */ + if (params->microcode_lock != 0xffffffff) + params->microcode_lock = 0; +} + +static void sipi_set_mtrrs(struct sipi_params *params) +{ + struct saved_msr *smsr; + if (!params->msr_count) + return; + + if (CONFIG(X86_AMD_FIXED_MTRRS)) { + msr_t msr; + /* Enable access to AMD RdDram and WrDram extension bits */ + msr = rdmsr(SYSCFG_MSR); + msr.lo |= SYSCFG_MSR_MtrrFixDramModEn; + wrmsr(SYSCFG_MSR, msr); + } + + /* Load MSRs */ + smsr = (struct saved_msr *)params->msr_table_ptr; + for (size_t i = 0; i < params->msr_count; i++) { + msr_t msr = {.lo = smsr->lo, .hi = smsr->hi}; + wrmsr(smsr->index, msr); + } + + if (CONFIG(X86_AMD_FIXED_MTRRS)) { + msr_t msr; + /* Enable access to AMD RdDram and WrDram extension bits */ + msr = rdmsr(SYSCFG_MSR); + msr.lo &= ~SYSCFG_MSR_MtrrFixDramModEn; + wrmsr(SYSCFG_MSR, msr); + } +} + +static void sipi_enable_caches(struct sipi_params *params) +{ + /* Enable caches */ + CRx_TYPE cr0 = read_cr0(); + cr0 &= ~(CR0_CLEAR_FLAGS_CACHE_ENABLE); + write_cr0(cr0); +} + +static void sipi_enable_sse(struct sipi_params *params) +{ + /* Enable sse instructions. */ + if (CONFIG(SSE)) { + CRx_TYPE cr4 = read_cr4(); + cr4 &= (CR4_OSFXSR | CR4_OSXMMEXCPT); + write_cr4(cr4); + } +} + +/* + * Early CPU bringup hook. + * - No Microcode has been loaded + * - Caches are disabled + * - SSE is disabled + * - MTRR haven't been set up + * + * You have been warned, expect the unexpected! + */ +asmlinkage void sipi_secondary_early_entry(struct sipi_params *params, int cpu_num) +{ + sipi_update_microcode(params); + sipi_set_mtrrs(params); + sipi_enable_caches(params); + sipi_enable_sse(params); + + void (*doit)(int) = (void (*)(int))params->c_handler; + doit(cpu_num); +} \ No newline at end of file diff --git a/src/include/cpu/x86/mp.h b/src/include/cpu/x86/mp.h index b2704eb..75cbe26 100644 --- a/src/include/cpu/x86/mp.h +++ b/src/include/cpu/x86/mp.h @@ -143,4 +143,27 @@ /* Send SMI to self with single execution. */ void smm_initiate_relocation(void);
+/* This needs to match the layout in the .module_parametrs section. */ +struct sipi_params { + uint16_t gdtlimit; + uint32_t gdt; + uint16_t unused; + uint32_t idt_ptr; + uint32_t stack_top; + uint32_t stack_size; + uint32_t microcode_lock; /* 0xffffffff means parallel loading. */ + uint32_t microcode_ptr; + uint32_t msr_table_ptr; + uint32_t msr_count; + uint32_t c_handler; + atomic_t ap_count; +} __packed; + +/* This also needs to match the assembly code for saved MSR encoding. */ +struct saved_msr { + uint32_t index; + uint32_t lo; + uint32_t hi; +} __packed; + #endif /* _X86_MP_H_ */
build bot (Jenkins) has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/46821 )
Patch Set 1:
https://review.coreboot.org/c/coreboot/+/46821/1/src/cpu/x86/sipi_vector_c_h... File src/cpu/x86/sipi_vector_c_handler.c:
https://review.coreboot.org/c/coreboot/+/46821/1/src/cpu/x86/sipi_vector_c_h... PS1, Line 113: } adding a line without newline at end of file
Paul Menzel has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/46821 )
Patch Set 1:
(2 comments)
https://review.coreboot.org/c/coreboot/+/46821/1//COMMIT_MSG Commit Message:
https://review.coreboot.org/c/coreboot/+/46821/1//COMMIT_MSG@8 PS1, Line 8: What is the problem or motivation for the change?
https://review.coreboot.org/c/coreboot/+/46821/1/src/cpu/x86/sipi_vector_c_h... PS1, Line 87: /* Enable sse instructions. */ Remove the (unneeded) dot/period at the end – also for consistency with the other comments.
Hello build bot (Jenkins), Patrick Georgi, Martin Roth, Christian Walter, Tim Wawrzynczak, Aaron Durbin,
Use a C helper function to do early x86 CPU init. This allows easier code changes that are hopefully less error prone than assembly code. This changes assumes that stack works even without microcode updates installed on the specific secondary CPU core.
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/21/46821/2
Aaron Durbin has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/46821 )
Patch Set 2:
(4 comments)
https://review.coreboot.org/c/coreboot/+/46821/2/src/cpu/x86/sipi_vector.S File src/cpu/x86/sipi_vector.S:
https://review.coreboot.org/c/coreboot/+/46821/2/src/cpu/x86/sipi_vector.S@8... PS2, Line 86: 1: FWIW, we should move '1:' label above 'movl ap_count, %eax' so it reloads the real value in memory. For another patch, though. We could probably reduce the number of instructions to just use eax and stop using ecx.
https://review.coreboot.org/c/coreboot/+/46821/2/src/cpu/x86/sipi_vector_c_h... File src/cpu/x86/sipi_vector_c_handler.c:
https://review.coreboot.org/c/coreboot/+/46821/2/src/cpu/x86/sipi_vector_c_h... PS2, Line 27: /* Determine if parallel microcode loading is allowed. */ We should have a lot more commentary on this code as to why we're not using spinlocks and how we're inherently relying on sipi_params object being in uncacheable memory. However, spinlocks could be used if microcode_lock was transformed into a spinlock type.
https://review.coreboot.org/c/coreboot/+/46821/2/src/cpu/x86/sipi_vector_c_h... PS2, Line 35: : "=m"(params->microcode_lock) This should be ¶ms->microcode_lock, I think. What's the disassembly look like?
https://review.coreboot.org/c/coreboot/+/46821/2/src/cpu/x86/sipi_vector_c_h... PS2, Line 104: struct sipi_params * const... but it appears we're wanting to manipulate microcode_lock object itself. Everything but sipi_update_microcode() should be using const params.
TODO: Clean up code and reuse existing C code.
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/21/46821/3
Patrick Rudolph has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/46821 )
Patch Set 3:
(5 comments)
Done
Done
We should have a lot more commentary on this code as to why we're not using spinlocks and how we're […]
yes, the plan is to clean the code. I just reused the existing comments from assebmly when converting it to C.
This should be ¶ms->microcode_lock, I think. […]
params->microcode_lock is correct. it generates the following assembly code: 2e0: f0 0f ba 68 14 00 lock btsl $0x0,0x14(%eax) 2e6: 72 f8 jb 0x2e0
where eax is params
const... but it appears we're wanting to manipulate microcode_lock object itself. […]
Done
Patch Set 3: Code-Review+2
Tim Wawrzynczak has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/46821 )
https://review.coreboot.org/c/coreboot/+/46821/3/src/include/cpu/x86/mp.h File src/include/cpu/x86/mp.h:
https://review.coreboot.org/c/coreboot/+/46821/3/src/include/cpu/x86/mp.h@14... PS3, Line 146: module_parametrs module_parameters
Hello build bot (Jenkins), Patrick Georgi, Martin Roth, Tim Wawrzynczak, Christian Walter, Aaron Durbin,
Change-Id: Ib6c2ffa2ce8c42eee9f3fe8ec8cff933942207ca Signed-off-by: Patrick Rudolph patrick.rudolph@9elements.com --- M src/cpu/x86/Makefile.inc M src/cpu/x86/mp_init.c M src/cpu/x86/sipi_vector.S A src/cpu/x86/sipi_vector_c_handler.c M src/include/cpu/x86/mp.h 5 files changed, 156 insertions(+), 127 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/21/46821/4
Arthur Heymans has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/46821 )
Patch Set 4:
(4 comments)
https://review.coreboot.org/c/coreboot/+/46821/1/src/cpu/x86/sipi_vector_c_h... PS1, Line 70: Enable Disable
https://review.coreboot.org/c/coreboot/+/46821/4/src/cpu/x86/sipi_vector_c_h... File src/cpu/x86/sipi_vector_c_handler.c:
https://review.coreboot.org/c/coreboot/+/46821/4/src/cpu/x86/sipi_vector_c_h... PS4, Line 40: intel_microcode_load_unlocked The update trigger mechanism is the same for AMD CPUs (wrmsr 0x79), maybe that can be placed in a more generic place as this seems to do more Intel specific things?
https://review.coreboot.org/c/coreboot/+/46821/4/src/cpu/x86/sipi_vector_c_h... PS4, Line 70: Enable Disable
https://review.coreboot.org/c/coreboot/+/46821/4/src/include/cpu/x86/mp.h File src/include/cpu/x86/mp.h:
https://review.coreboot.org/c/coreboot/+/46821/4/src/include/cpu/x86/mp.h@16... PS4, Line 162: /* This also needs to match the assembly code for saved MSR encoding. */ stale comment.
Patch Set 4:
Looks like I was wrong. AMD use a different MSR for that.
Patrick Rudolph has abandoned this change. ( https://review.coreboot.org/c/coreboot/+/46821 )
Abandoned
patch series replaced by CB:49303
