Angel Pons has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/49093 )
Change subject: cpu/intel/model_206ax: Replace `generate_cstate_entries` ......................................................................
Leverage the existing `acpigen_write_CST_package` function.
Change-Id: Icec5431987d91242930efcea0c8ea4e3df3182fd Signed-off-by: Angel Pons th3fanbus@gmail.com --- M src/cpu/intel/model_206ax/acpi.c 1 file changed, 15 insertions(+), 37 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/93/49093/1
diff --git a/src/cpu/intel/model_206ax/acpi.c b/src/cpu/intel/model_206ax/acpi.c index beb2fbc..bd743c7 100644 --- a/src/cpu/intel/model_206ax/acpi.c +++ b/src/cpu/intel/model_206ax/acpi.c @@ -19,39 +19,6 @@ return msr.lo & 0xffff; }
-static void generate_cstate_entries(acpi_cstate_t *cstates, - int c1, int c2, int c3) -{ - int cstate_count = 0; - - /* Count number of active C-states */ - if (c1 > 0) - ++cstate_count; - if (c2 > 0) - ++cstate_count; - if (c3 > 0) - ++cstate_count; - - acpigen_write_package(cstate_count + 1); - acpigen_write_byte(cstate_count); - - /* Add an entry if the level is enabled */ - if (c1 > 0) { - cstates[c1].ctype = 1; - acpigen_write_CST_package_entry(&cstates[c1]); - } - if (c2 > 0) { - cstates[c2].ctype = 2; - acpigen_write_CST_package_entry(&cstates[c2]); - } - if (c3 > 0) { - cstates[c3].ctype = 3; - acpigen_write_CST_package_entry(&cstates[c3]); - } - - acpigen_pop_len(); -} - static void generate_C_state_entries(void) { struct cpu_info *info; @@ -75,10 +42,21 @@ if (!cpu || !cpu->cstates) return;
- acpigen_write_method("_CST", 0); - acpigen_emit_byte(RETURN_OP); - generate_cstate_entries(cpu->cstates, conf->acpi_c1, conf->acpi_c2, conf->acpi_c3); - acpigen_pop_len(); + const int acpi_cstates[3] = { conf->acpi_c1, conf->acpi_c2, conf->acpi_c3 }; + + acpi_cstate_t cstate_map[ARRAY_SIZE(acpi_cstates)]; + + /* Count number of active C-states */ + int count = 0; + + for (int i = 0; i < ARRAY_SIZE(acpi_cstates); i++) { + if (acpi_cstates[i] > 0) { + cstate_map[count] = cpu->cstates[acpi_cstates[i]]; + cstate_map[count].ctype = i + 1; + count++; + } + } + acpigen_write_CST_package(cstate_map, count); }
static acpi_tstate_t tss_table_fine[] = {
Attention is currently required from: Nico Huber, Angel Pons, Arthur Heymans. Patrick Rudolph has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/49093 )
Patch Set 2:
(2 comments)
File src/cpu/intel/model_206ax/acpi.c:
https://review.coreboot.org/c/coreboot/+/49093/comment/968b1205_7d875269 PS2, Line 54: acpi_cstates possible buffer overflow.
https://review.coreboot.org/c/coreboot/+/49093/comment/e6d26aa2_55660df9 PS2, Line 55: i + 1 shouldn't the ctype be already correct here? why do you need to update it?
Attention is currently required from: Nico Huber, Arthur Heymans, Patrick Rudolph. Angel Pons has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/49093 )
Patch Set 2:
(2 comments)
https://review.coreboot.org/c/coreboot/+/49093/comment/f234d213_1d3dfe3c PS2, Line 54: acpi_cstates
Sorry, I don't follow. Do you mean a buffer overflow can happen if a devicetree contains invalid `acpi_cX` values?
https://review.coreboot.org/c/coreboot/+/49093/comment/eda43efe_b54b4186 PS2, Line 55: i + 1
I'm just doing what the original code did.
Attention is currently required from: Nico Huber, Angel Pons, Arthur Heymans, Patrick Rudolph. Patrick Rudolph has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/49093 )
Patch Set 2:
(3 comments)
https://review.coreboot.org/c/coreboot/+/49093/comment/ad5b400e_1f0aade5 PS2, Line 50: int count = 0; Reading this code again and again, I'm still not sure what values to put in as acpi_cX. According to the ACPI spec you can specify more than 3 C-states in _CST package, so this selection using the devicetree doesn't make any sense. Why not put all (supported) C-states into _CST?
https://review.coreboot.org/c/coreboot/+/49093/comment/32c52afb_01d0fb00 PS2, Line 54: acpi_cstates
Sorry, I don't follow. […]
yes, if acpi_cX >= ARRAY_SIZE(cpu->cstates)
https://review.coreboot.org/c/coreboot/+/49093/comment/ca6b2b75_23a1307b PS2, Line 55: i + 1
Just checked, there's no ctype in the default map. This only works as acpi_cstates contains the cstates C1 - C3.
Attention is currently required from: Patrick Rudolph, Angel Pons, Arthur Heymans. Nico Huber has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/49093 )
Patch Set 2:
(2 comments)
Patchset:
PS2: Sorry, I thought it would be good to review and say something here, but I might have made it worse...
https://review.coreboot.org/c/coreboot/+/49093/comment/747f2725_8da28bf6 PS2, Line 54: acpi_cstates
Let's call it an out-of-bounds read. You can just add it to the condition
if (acpi_cstates[i] > 0 && acpi_cstates[i] < cpu_cstate_count)
We need to count first, though. `cpu->cstates` is 0 terminated. (Ugh, I don't understand this indirection. It's a static array, why is it not declared here?)(Also, why are those acpi_cstates `int` and not `unsigned`?)
Attention is currently required from: Nico Huber, Patrick Rudolph, Arthur Heymans. Angel Pons has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/49093 )
Patch Set 2:
https://review.coreboot.org/c/coreboot/+/49093/comment/ea1bb25b_52f8da94 PS2, Line 54: acpi_cstates
Let's call it an out-of-bounds read. You can just add it to the condition […]
Yeah, I don't like these things at all. I'll see what I can do. I should also fix Haswell, but I'm stalled on changes like CB:46924 that touch the C-state code.
Patch Set 2:
https://review.coreboot.org/c/coreboot/+/49093/comment/41134389_22a7ea2c PS2, Line 50: int count = 0;
Reading this code again and again, I'm still not sure what values to put in as acpi_cX. […]
Let's fix this in a separate commit.
Patch Set 2:
https://review.coreboot.org/c/coreboot/+/49093/comment/430744dc_a34f005b PS2, Line 54: acpi_cstates
Yeah, I don't like these things at all. I'll see what I can do. […]
Will need to fix in a follow-up. I first need to drop using the `cstates` pointer completely.
Attention is currently required from: Nico Huber, Patrick Rudolph, Arthur Heymans. Hello build bot (Jenkins), Nico Huber, Patrick Georgi, Arthur Heymans, Patrick Rudolph,
Yes, bad devicetree values can trigger undefined behavior. The old code already had this issue, and will be addressed in subsequent commits.
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/93/49093/3
Patch Set 3:
https://review.coreboot.org/c/coreboot/+/49093/comment/f4acc914_86252f6f PS2, Line 54: acpi_cstates
CB:49801
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/93/49093/4
Patch Set 6: Code-Review+2
Angel Pons has submitted this change. ( https://review.coreboot.org/c/coreboot/+/49093 )
Change-Id: Icec5431987d91242930efcea0c8ea4e3df3182fd Signed-off-by: Angel Pons th3fanbus@gmail.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/49093 Reviewed-by: Nico Huber nico.h@gmx.de Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/cpu/intel/model_206ax/acpi.c 1 file changed, 15 insertions(+), 37 deletions(-)
Approvals: build bot (Jenkins): Verified Nico Huber: Looks good to me, approved
diff --git a/src/cpu/intel/model_206ax/acpi.c b/src/cpu/intel/model_206ax/acpi.c index beb2fbc..6c12261 100644 --- a/src/cpu/intel/model_206ax/acpi.c +++ b/src/cpu/intel/model_206ax/acpi.c @@ -19,39 +19,6 @@ return msr.lo & 0xffff; }
- acpigen_write_method("_CST", 0); - acpigen_emit_byte(RETURN_OP); - generate_cstate_entries(cpu->cstates, conf->acpi_c1, conf->acpi_c2, conf->acpi_c3); - acpigen_pop_len(); + const int acpi_cstates[3] = { conf->acpi_c1, conf->acpi_c2, conf->acpi_c3 }; + + acpi_cstate_t acpi_cstate_map[ARRAY_SIZE(acpi_cstates)] = { 0 }; + + /* Count number of active C-states */ + int count = 0; + + for (int i = 0; i < ARRAY_SIZE(acpi_cstates); i++) { + if (acpi_cstates[i] > 0) { + acpi_cstate_map[count] = cpu->cstates[acpi_cstates[i]]; + acpi_cstate_map[count].ctype = i + 1; + count++; + } + } + acpigen_write_CST_package(acpi_cstate_map, count); }
