Patrick Georgi (pgeorgi@google.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/13832
commit 4a9efea0105ce9d982f40ae1017f9843ecde4121 Author: Julius Werner jwerner@chromium.org Date: Wed Feb 17 16:12:46 2016 -0800
nyan: Fix timestamps and CBFS SPI integration
Nyan is an old board that was committed before several core code modernizations to timestamp and CBFS code. Not all of those later patches were correctly integrated with old boards like this, and the core code has evolved to a point where it doesn't actually boot anymore.
This patch fixes that issue and brings the Nyan boards more in line with how later ARM platforms look.
BRANCH=None BUG=None TEST=My Blaze boots again.
Change-Id: I3277a2f59ad8ed47063f7f6b556685313b1446f8 Signed-off-by: Patrick Georgi pgeorgi@google.com Original-Commit-Id: 6a1679e342a7adc2b2371b6e3f69a898a7a5c717 Original-Change-Id: I2a0a2abbd79b4b5f756125dcbb6cbd9441016d4e Original-Signed-off-by: Julius Werner jwerner@chromium.org Original-Reviewed-on: https://chromium-review.googlesource.com/328543 Original-Reviewed-by: David Hendricks dhendrix@chromium.org --- src/mainboard/google/nyan/Kconfig | 3 + src/mainboard/google/nyan_big/Kconfig | 3 + src/mainboard/google/nyan_blaze/Kconfig | 3 + src/soc/nvidia/tegra124/bootblock.c | 3 + src/soc/nvidia/tegra124/include/soc/memlayout.ld | 3 +- src/soc/nvidia/tegra124/spi.c | 92 ------------------------ 6 files changed, 14 insertions(+), 93 deletions(-)
diff --git a/src/mainboard/google/nyan/Kconfig b/src/mainboard/google/nyan/Kconfig index 8f0c9de..a5ecf84 100644 --- a/src/mainboard/google/nyan/Kconfig +++ b/src/mainboard/google/nyan/Kconfig @@ -19,6 +19,7 @@ config BOARD_SPECIFIC_OPTIONS # dummy def_bool y select SOC_NVIDIA_TEGRA124 select MAINBOARD_HAS_CHROMEOS + select COMMON_CBFS_SPI_WRAPPER select EC_GOOGLE_CHROMEEC select EC_GOOGLE_CHROMEEC_SPI select TEGRA124_MODEL_CD570M @@ -26,6 +27,8 @@ config BOARD_SPECIFIC_OPTIONS # dummy select MAINBOARD_DO_NATIVE_VGA_INIT select BOARD_ROMSIZE_KB_4096 select SPI_FLASH + select SPI_FLASH_GIGADEVICE + select SPI_FLASH_WINBOND select SPI_FLASH_FAST_READ_DUAL_OUTPUT_3B
config CHROMEOS diff --git a/src/mainboard/google/nyan_big/Kconfig b/src/mainboard/google/nyan_big/Kconfig index b6f84f6..fdd40f6 100644 --- a/src/mainboard/google/nyan_big/Kconfig +++ b/src/mainboard/google/nyan_big/Kconfig @@ -20,6 +20,7 @@ config BOARD_SPECIFIC_OPTIONS # dummy select SOC_NVIDIA_TEGRA124 select MAINBOARD_HAS_CHROMEOS select BOARD_ID_AUTO + select COMMON_CBFS_SPI_WRAPPER select EC_GOOGLE_CHROMEEC select EC_GOOGLE_CHROMEEC_SPI select TEGRA124_MODEL_CD570M @@ -27,6 +28,8 @@ config BOARD_SPECIFIC_OPTIONS # dummy select MAINBOARD_DO_NATIVE_VGA_INIT select BOARD_ROMSIZE_KB_4096 select SPI_FLASH + select SPI_FLASH_GIGADEVICE + select SPI_FLASH_WINBOND select SPI_FLASH_FAST_READ_DUAL_OUTPUT_3B
config CHROMEOS diff --git a/src/mainboard/google/nyan_blaze/Kconfig b/src/mainboard/google/nyan_blaze/Kconfig index 0fd763d..f28fb24 100644 --- a/src/mainboard/google/nyan_blaze/Kconfig +++ b/src/mainboard/google/nyan_blaze/Kconfig @@ -19,6 +19,7 @@ config BOARD_SPECIFIC_OPTIONS # dummy def_bool y select ARCH_ARM select BOARD_ID_AUTO + select COMMON_CBFS_SPI_WRAPPER select EC_GOOGLE_CHROMEEC select EC_GOOGLE_CHROMEEC_SPI select SOC_NVIDIA_TEGRA124 @@ -28,6 +29,8 @@ config BOARD_SPECIFIC_OPTIONS # dummy select MAINBOARD_DO_NATIVE_VGA_INIT select BOARD_ROMSIZE_KB_4096 select SPI_FLASH + select SPI_FLASH_GIGADEVICE + select SPI_FLASH_WINBOND select SPI_FLASH_FAST_READ_DUAL_OUTPUT_3B
config CHROMEOS diff --git a/src/soc/nvidia/tegra124/bootblock.c b/src/soc/nvidia/tegra124/bootblock.c index cebe405..2a526a7 100644 --- a/src/soc/nvidia/tegra124/bootblock.c +++ b/src/soc/nvidia/tegra124/bootblock.c @@ -24,6 +24,7 @@ #include <soc/nvidia/tegra/apbmisc.h> #include <soc/pinmux.h> #include <soc/power.h> +#include <timestamp.h> #include <vendorcode/google/chromeos/chromeos.h>
static void run_next_stage(void *entry) @@ -81,6 +82,8 @@ void main(void) PINMUX_PWR_INT_N_FUNC_PMICINTR | PINMUX_INPUT_ENABLE);
+ timestamp_init(0); + run_romstage(); }
diff --git a/src/soc/nvidia/tegra124/include/soc/memlayout.ld b/src/soc/nvidia/tegra124/include/soc/memlayout.ld index c3f5f4e..5bab362 100644 --- a/src/soc/nvidia/tegra124/include/soc/memlayout.ld +++ b/src/soc/nvidia/tegra124/include/soc/memlayout.ld @@ -33,7 +33,8 @@ SECTIONS STACK(0x4000E000, 8K) BOOTBLOCK(0x40010000, 24K) VERSTAGE(0x40016000, 72K) - ROMSTAGE(0x40028000, 96K) + ROMSTAGE(0x40028000, 95K) + TIMESTAMP(0x4003FC00, 1K) SRAM_END(0x40040000)
DRAM_START(0x80000000) diff --git a/src/soc/nvidia/tegra124/spi.c b/src/soc/nvidia/tegra124/spi.c index d5f7861..d5be4a6 100644 --- a/src/soc/nvidia/tegra124/spi.c +++ b/src/soc/nvidia/tegra124/spi.c @@ -798,69 +798,6 @@ int spi_xfer(struct spi_slave *slave, const void *dout, return ret; }
-#define JEDEC_READ 0x03 -#define JEDEC_READ_OUTSIZE 0x04 -#define JEDEC_FAST_READ_DUAL 0x3b -#define JEDEC_FAST_READ_DUAL_OUTSIZE 0x05 - -static struct spi_slave *boot_slave; - -static ssize_t tegra_spi_readat(const struct region_device *rdev, void *dest, - size_t offset, size_t count) -{ - u8 spi_read_cmd[JEDEC_FAST_READ_DUAL_OUTSIZE]; - unsigned int read_cmd_bytes; - int ret = count; - struct tegra_spi_channel *channel; - - channel = to_tegra_spi(boot_slave->bus); - - if (channel->dual_mode) { - /* - * Command 0x3b will interleave data only, command 0xbb will - * interleave the address as well. It's nice to see the address - * plainly when debugging, and we're mostly concerned with - * large transfers so the optimization of using 0xbb isn't - * really worthwhile. - */ - spi_read_cmd[0] = JEDEC_FAST_READ_DUAL; - spi_read_cmd[4] = 0x00; /* dummy byte */ - read_cmd_bytes = JEDEC_FAST_READ_DUAL_OUTSIZE; - } else { - spi_read_cmd[0] = JEDEC_READ; - read_cmd_bytes = JEDEC_READ_OUTSIZE; - } - spi_read_cmd[1] = (offset >> 16) & 0xff; - spi_read_cmd[2] = (offset >> 8) & 0xff; - spi_read_cmd[3] = offset & 0xff; - - spi_claim_bus(boot_slave); - - if (spi_xfer(boot_slave, spi_read_cmd, - read_cmd_bytes, NULL, 0) < 0) { - ret = -1; - printk(BIOS_ERR, "%s: Failed to transfer %u bytes\n", - __func__, sizeof(spi_read_cmd)); - goto tegra_spi_cbfs_read_exit; - } - - if (channel->dual_mode) { - setbits_le32(&channel->regs->command1, SPI_CMD1_BOTH_EN_BIT); - } - if (spi_xfer(boot_slave, NULL, 0, dest, count)) { - ret = -1; - printk(BIOS_ERR, "%s: Failed to transfer %u bytes\n", - __func__, count); - } - if (channel->dual_mode) - clrbits_le32(&channel->regs->command1, SPI_CMD1_BOTH_EN_BIT); - -tegra_spi_cbfs_read_exit: - /* de-assert /CS */ - spi_release_bus(boot_slave); - return ret; -} - struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs) { struct tegra_spi_channel *channel = to_tegra_spi(bus); @@ -869,32 +806,3 @@ struct spi_slave *spi_setup_slave(unsigned int bus, unsigned int cs)
return &channel->slave; } - -static const struct region_device_ops tegra_spi_ops = { - .mmap = mmap_helper_rdev_mmap, - .munmap = mmap_helper_rdev_munmap, - .readat = tegra_spi_readat, -}; - -static struct mmap_helper_region_device mdev = - MMAP_HELPER_REGION_INIT(&tegra_spi_ops, 0, CONFIG_ROM_SIZE); - -const struct region_device *boot_device_ro(void) -{ - return &mdev.rdev; -} - -void boot_device_init(void) -{ - struct tegra_spi_channel *boot_chan; - - boot_chan = &tegra_spi_channels[CONFIG_BOOT_MEDIA_SPI_BUS - 1]; - boot_chan->slave.cs = CONFIG_BOOT_MEDIA_SPI_CHIP_SELECT; - -#if CONFIG_SPI_FLASH_FAST_READ_DUAL_OUTPUT_3B == 1 - boot_chan->dual_mode = 1; -#endif - boot_slave = &boot_chan->slave; - - mmap_helper_device_init(&mdev, _cbfs_cache, _cbfs_cache_size); -}
