Attention is currently required from: Bora Guvendik, Cliff Huang, Anil Kumar K. Hello Bora Guvendik, build bot (Jenkins), Cliff Huang, Anil Kumar K,
https://review.coreboot.org/c/coreboot/+/63945
Change subject: mb/intel/adlrvp: x4 slot support (SD card support) for Adl-P RVP ......................................................................
Use clock src and clock req to 7 for x4 slot. Remove free running clock setting for clock 6. Configure gpio for source clock OEB native function going to x4 slot.
BUG=b:233252409 BRANCH=firmware-brya-14505.B
TEST=insert SD AIC to x4 slot. boot to OS and use 'lspci' to check the device. ex: 58:00.0 SD Host controller: O2 Micro, Inc. Device 8621 (rev 01) NOTE: The bus number varies.
Signed-off-by: Cliff Huang cliff.huang@intel.corp-partner.google.com Change-Id: Iba5d83d133b6ae8cd389ddd971db308170094300 --- M src/mainboard/intel/adlrvp/devicetree.cb M src/mainboard/intel/adlrvp/early_gpio.c M src/mainboard/intel/adlrvp/gpio.c 3 files changed, 16 insertions(+), 9 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/45/63945/6
