Hello Felix Singer, build bot (Jenkins), Furquan Shaikh, Tim Chen, Maulik V Vaghela, Matt DeVillier, Duncan Laurie, Ren Kuo, Subrata Banik, Aamir Bohra, Patrick Rudolph, Seunghwan Kim, Nico Huber, Tony Huang, Tim Wawrzynczak, Karthikeyan Ramasubramanian,
https://review.coreboot.org/c/coreboot/+/48780
Change subject: soc/intel/{icl,tgl,adl,ehl,jsl}: move UART pad config to boards ......................................................................
UART pad configuration should not be done in common code, because that may cause short circuits, when the user sets a wrong UART index. Thus, add the corresponding pads to the early UART gpio table for the boards.
Also switch to `bootblock_mainboard_early_init` to configure the pads in early bootblock before console initialization, to make the console work as early as possible. None of the boards do any other gpio configuration in bootblock, so this should not influence behaviour in a negative way (e.g. breaking overrides).
Only boards selecting INTEL_LPSS_UART_FOR_CONSOLE have been adapted.
Further, clear the `.gpios` field for the SoCs, so that the common code still works but no pad configuration is done anymore and add a temporary note that `.gpios` is intentionally left empty.
As soon as all platforms have moved the pad configuration to the boards, we can adapt the common code an drop the remaining structs all at once.
Change-Id: I5150110dd13e9da981a0c8614ee642037e209ca4 Signed-off-by: Michael Niewöhner foss@mniewoehner.de --- M src/mainboard/google/dedede/bootblock.c M src/mainboard/google/dedede/variants/baseboard/gpio.c M src/mainboard/google/volteer/bootblock.c M src/mainboard/google/volteer/variants/baseboard/gpio.c M src/mainboard/google/volteer/variants/delbin/gpio.c M src/mainboard/google/volteer/variants/eldrid/gpio.c M src/mainboard/google/volteer/variants/elemi/gpio.c M src/mainboard/google/volteer/variants/halvor/gpio.c M src/mainboard/google/volteer/variants/lindar/gpio.c M src/mainboard/google/volteer/variants/malefor/gpio.c M src/mainboard/google/volteer/variants/terrador/gpio.c M src/mainboard/google/volteer/variants/todor/gpio.c M src/mainboard/google/volteer/variants/trondo/gpio.c M src/mainboard/google/volteer/variants/voema/gpio.c M src/mainboard/google/volteer/variants/volteer/gpio.c M src/mainboard/google/volteer/variants/volteer2/gpio.c M src/mainboard/google/volteer/variants/voxel/gpio.c M src/mainboard/intel/adlrvp/Makefile.inc M src/mainboard/intel/adlrvp/bootblock.c A src/mainboard/intel/adlrvp/variants/adlrvp_p/Makefile.inc R src/mainboard/intel/adlrvp/variants/adlrvp_p/early_gpio.c A src/mainboard/intel/adlrvp/variants/adlrvp_p_ext_ec/Makefile.inc A src/mainboard/intel/adlrvp/variants/adlrvp_p_ext_ec/early_gpio.c M src/mainboard/intel/icelake_rvp/bootblock.c M src/mainboard/intel/icelake_rvp/variants/icl_u/gpio.c M src/mainboard/intel/icelake_rvp/variants/icl_y/gpio.c M src/mainboard/intel/jasperlake_rvp/bootblock.c M src/mainboard/intel/jasperlake_rvp/variants/jslrvp/gpio.c M src/mainboard/intel/tglrvp/bootblock.c M src/mainboard/intel/tglrvp/variants/tglrvp_up3/gpio.c M src/mainboard/intel/tglrvp/variants/tglrvp_up4/gpio.c M src/soc/intel/alderlake/uart.c M src/soc/intel/elkhartlake/uart.c M src/soc/intel/icelake/uart.c M src/soc/intel/jasperlake/uart.c M src/soc/intel/tigerlake/uart.c 36 files changed, 203 insertions(+), 68 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/80/48780/6
