Angel Pons has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/43112 )
Change subject: mb/intel/baskingridge: Factor out common MRC settings ......................................................................
There's no need to redefine common settings.
Change-Id: If0cbc147791496bafc85831c1f88d3eb71b63350 Signed-off-by: Angel Pons th3fanbus@gmail.com --- M src/mainboard/intel/baskingridge/romstage.c 1 file changed, 58 insertions(+), 64 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/12/43112/1
diff --git a/src/mainboard/intel/baskingridge/romstage.c b/src/mainboard/intel/baskingridge/romstage.c index e126dc5..120cca1 100644 --- a/src/mainboard/intel/baskingridge/romstage.c +++ b/src/mainboard/intel/baskingridge/romstage.c @@ -46,70 +46,64 @@
void mainboard_fill_pei_data(struct pei_data *pei_data) { - struct pei_data mainboard_pei_data = { - .pei_version = PEI_VERSION, - .mchbar = (uintptr_t)DEFAULT_MCHBAR, - .dmibar = (uintptr_t)DEFAULT_DMIBAR, - .epbar = DEFAULT_EPBAR, - .pciexbar = CONFIG_MMCONF_BASE_ADDRESS, - .smbusbar = SMBUS_IO_BASE, - .hpet_address = HPET_ADDR, - .rcba = (uintptr_t)DEFAULT_RCBA, - .pmbase = DEFAULT_PMBASE, - .gpiobase = DEFAULT_GPIOBASE, - .temp_mmio_base = 0xfed08000, - .system_type = 0, // 0 Mobile, 1 Desktop/Server - .tseg_size = CONFIG_SMM_TSEG_SIZE, - .spd_addresses = { 0xa0, 0xa2, 0xa4, 0xa6 }, - .ec_present = 0, - // 0 = leave channel enabled - // 1 = disable dimm 0 on channel - // 2 = disable dimm 1 on channel - // 3 = disable dimm 0+1 on channel - .dimm_channel0_disabled = 0, - .dimm_channel1_disabled = 0, - .max_ddr3_freq = 1600, - .usb2_ports = { - /* Length, Enable, OCn#, Location */ - { 0x0040, 1, 0, /* P0: Back USB3 port (OC0) */ - USB_PORT_BACK_PANEL }, - { 0x0040, 1, 0, /* P1: Back USB3 port (OC0) */ - USB_PORT_BACK_PANEL }, - { 0x0040, 1, 1, /* P2: Flex Port on bottom (OC1) */ - USB_PORT_FLEX }, - { 0x0040, 1, USB_OC_PIN_SKIP, /* P3: Dock connector */ - USB_PORT_DOCK }, - { 0x0040, 1, USB_OC_PIN_SKIP, /* P4: Mini PCIE */ - USB_PORT_MINI_PCIE }, - { 0x0040, 1, 1, /* P5: USB eSATA header (OC1) */ - USB_PORT_FLEX }, - { 0x0040, 1, 3, /* P6: Front Header J8H2 (OC3) */ - USB_PORT_FRONT_PANEL }, - { 0x0040, 1, 3, /* P7: Front Header J8H2 (OC3) */ - USB_PORT_FRONT_PANEL }, - { 0x0040, 1, 4, /* P8: USB/LAN Jack (OC4) */ - USB_PORT_FRONT_PANEL }, - { 0x0040, 1, 4, /* P9: USB/LAN Jack (OC4) */ - USB_PORT_FRONT_PANEL }, - { 0x0040, 1, 5, /* P10: Front Header J7H3 (OC5) */ - USB_PORT_FRONT_PANEL }, - { 0x0040, 1, 5, /* P11: Front Header J7H3 (OC5) */ - USB_PORT_FRONT_PANEL }, - { 0x0040, 1, 6, /* P12: USB/DP Jack (OC6) */ - USB_PORT_FRONT_PANEL }, - { 0x0040, 1, 6, /* P13: USB/DP Jack (OC6) */ - USB_PORT_FRONT_PANEL }, - }, - .usb3_ports = { - /* Enable, OCn# */ - { 1, 0 }, /* P1; */ - { 1, 0 }, /* P2; */ - { 1, 0 }, /* P3; */ - { 1, 0 }, /* P4; */ - { 1, 0 }, /* P6; */ - { 1, 0 }, /* P6; */ - }, + pei_data->system_type = 0; /* 0 Mobile, 1 Desktop/Server */ + pei_data->spd_addresses[0] = 0xa0; + pei_data->spd_addresses[1] = 0xa2; + pei_data->spd_addresses[2] = 0xa4; + pei_data->spd_addresses[3] = 0xa6; + pei_data->ec_present = 0; + /* + * 0 = leave channel enabled + * 1 = disable dimm 0 on channel + * 2 = disable dimm 1 on channel + * 3 = disable dimm 0+1 on channel + */ + pei_data->dimm_channel0_disabled = 0; + pei_data->dimm_channel1_disabled = 0; + pei_data->max_ddr3_freq = 1600; + + struct usb2_port_setting usb2_ports[MAX_USB2_PORTS] = { + /* Length, Enable, OCn#, Location */ + { 0x0040, 1, 0, /* P0: Back USB3 port (OC0) */ + USB_PORT_BACK_PANEL }, + { 0x0040, 1, 0, /* P1: Back USB3 port (OC0) */ + USB_PORT_BACK_PANEL }, + { 0x0040, 1, 1, /* P2: Flex Port on bottom (OC1) */ + USB_PORT_FLEX }, + { 0x0040, 1, USB_OC_PIN_SKIP, /* P3: Dock connector */ + USB_PORT_DOCK }, + { 0x0040, 1, USB_OC_PIN_SKIP, /* P4: Mini PCIE */ + USB_PORT_MINI_PCIE }, + { 0x0040, 1, 1, /* P5: USB eSATA header (OC1) */ + USB_PORT_FLEX }, + { 0x0040, 1, 3, /* P6: Front Header J8H2 (OC3) */ + USB_PORT_FRONT_PANEL }, + { 0x0040, 1, 3, /* P7: Front Header J8H2 (OC3) */ + USB_PORT_FRONT_PANEL }, + { 0x0040, 1, 4, /* P8: USB/LAN Jack (OC4) */ + USB_PORT_FRONT_PANEL }, + { 0x0040, 1, 4, /* P9: USB/LAN Jack (OC4) */ + USB_PORT_FRONT_PANEL }, + { 0x0040, 1, 5, /* P10: Front Header J7H3 (OC5) */ + USB_PORT_FRONT_PANEL }, + { 0x0040, 1, 5, /* P11: Front Header J7H3 (OC5) */ + USB_PORT_FRONT_PANEL }, + { 0x0040, 1, 6, /* P12: USB/DP Jack (OC6) */ + USB_PORT_FRONT_PANEL }, + { 0x0040, 1, 6, /* P13: USB/DP Jack (OC6) */ + USB_PORT_FRONT_PANEL }, };
- *pei_data = mainboard_pei_data; /* FIXME: Do not overwrite everything */ + struct usb3_port_setting usb3_ports[MAX_USB3_PORTS] = { + /* Enable, OCn# */ + { 1, 0 }, /* P1; */ + { 1, 0 }, /* P2; */ + { 1, 0 }, /* P3; */ + { 1, 0 }, /* P4; */ + { 1, 0 }, /* P6; */ + { 1, 0 }, /* P6; */ + }; + + memcpy(pei_data->usb2_ports, usb2_ports, sizeof(usb2_ports)); + memcpy(pei_data->usb3_ports, usb3_ports, sizeof(usb3_ports)); }
Tristan Corrick has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/43112 )
Patch Set 5: Code-Review+2
Angel Pons has submitted this change. ( https://review.coreboot.org/c/coreboot/+/43112 )
Change-Id: If0cbc147791496bafc85831c1f88d3eb71b63350 Signed-off-by: Angel Pons th3fanbus@gmail.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/43112 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Tristan Corrick tristan@corrick.kiwi --- M src/mainboard/intel/baskingridge/romstage.c 1 file changed, 58 insertions(+), 64 deletions(-)
Approvals: build bot (Jenkins): Verified Tristan Corrick: Looks good to me, approved
diff --git a/src/mainboard/intel/baskingridge/romstage.c b/src/mainboard/intel/baskingridge/romstage.c index 6268417..6bb09a5 100644 --- a/src/mainboard/intel/baskingridge/romstage.c +++ b/src/mainboard/intel/baskingridge/romstage.c @@ -46,70 +46,64 @@
