Angel Pons has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/43111 )
Change subject: mb/supermicro/x10slm-f: Factor out common MRC settings ......................................................................
There's no need to redefine common settings.
Change-Id: Iee5ca6188de4cea9393efb66baa089969353b4e6 Signed-off-by: Angel Pons th3fanbus@gmail.com --- M src/mainboard/supermicro/x10slm-f/romstage.c 1 file changed, 45 insertions(+), 45 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/11/43111/1
diff --git a/src/mainboard/supermicro/x10slm-f/romstage.c b/src/mainboard/supermicro/x10slm-f/romstage.c index 8ef9040..bdcbb47 100644 --- a/src/mainboard/supermicro/x10slm-f/romstage.c +++ b/src/mainboard/supermicro/x10slm-f/romstage.c @@ -21,51 +21,51 @@
void mainboard_fill_pei_data(struct pei_data *pei_data) { - struct pei_data mainboard_pei_data = { - .pei_version = PEI_VERSION, - .mchbar = (uintptr_t)DEFAULT_MCHBAR, - .dmibar = (uintptr_t)DEFAULT_DMIBAR, - .epbar = DEFAULT_EPBAR, - .pciexbar = CONFIG_MMCONF_BASE_ADDRESS, - .smbusbar = SMBUS_IO_BASE, - .hpet_address = HPET_ADDR, - .rcba = (uintptr_t)DEFAULT_RCBA, - .pmbase = DEFAULT_PMBASE, - .gpiobase = DEFAULT_GPIOBASE, - .temp_mmio_base = 0xfed08000, - .system_type = 1, /* desktop/server */ - .tseg_size = CONFIG_SMM_TSEG_SIZE, - .spd_addresses = { 0xa0, 0xa2, 0xa4, 0xa6 }, - .ec_present = 0, - .ddr_refresh_2x = 1, - .max_ddr3_freq = 1600, - .usb2_ports = { - /* Length, Enable, OCn#, Location */ - { 0x0040, 1, 0, USB_PORT_INTERNAL }, - { 0x0040, 1, 0, USB_PORT_BACK_PANEL }, - { 0x0110, 1, 1, USB_PORT_BACK_PANEL }, - { 0x0110, 1, 1, USB_PORT_BACK_PANEL }, - { 0x0110, 1, 2, USB_PORT_BACK_PANEL }, - { 0x0110, 1, 2, USB_PORT_BACK_PANEL }, - { 0x0040, 0, USB_OC_PIN_SKIP, USB_PORT_SKIP }, - { 0x0040, 0, USB_OC_PIN_SKIP, USB_PORT_SKIP }, - { 0x0040, 1, 4, USB_PORT_BACK_PANEL }, - { 0x0040, 1, 4, USB_PORT_BACK_PANEL }, - { 0x0040, 0, USB_OC_PIN_SKIP, USB_PORT_SKIP }, - { 0x0040, 0, USB_OC_PIN_SKIP, USB_PORT_SKIP }, - { 0x0040, 1, 6, USB_PORT_BACK_PANEL }, - { 0x0040, 1, 6, USB_PORT_BACK_PANEL }, - }, - .usb3_ports = { - /* Enable, OCn# */ - { 1, 1 }, - { 1, 1 }, - { 0, USB_OC_PIN_SKIP }, - { 0, USB_OC_PIN_SKIP }, - { 1, 3 }, - { 1, 3 }, - }, + pei_data->system_type = 1; /* Desktop/Server */ + pei_data->spd_addresses[0] = 0xa0; + pei_data->spd_addresses[1] = 0xa2; + pei_data->spd_addresses[2] = 0xa4; + pei_data->spd_addresses[3] = 0xa6; + pei_data->ec_present = 0; + /* + * 0 = leave channel enabled + * 1 = disable dimm 0 on channel + * 2 = disable dimm 1 on channel + * 3 = disable dimm 0+1 on channel + */ + pei_data->dimm_channel0_disabled = 0; + pei_data->dimm_channel1_disabled = 0; + pei_data->ddr_refresh_2x = 1; + pei_data->max_ddr3_freq = 1600; + + struct usb2_port_setting usb2_ports[MAX_USB2_PORTS] = { + /* Length, Enable, OCn#, Location */ + { 0x0040, 1, 0, USB_PORT_INTERNAL }, + { 0x0040, 1, 0, USB_PORT_BACK_PANEL }, + { 0x0110, 1, 1, USB_PORT_BACK_PANEL }, + { 0x0110, 1, 1, USB_PORT_BACK_PANEL }, + { 0x0110, 1, 2, USB_PORT_BACK_PANEL }, + { 0x0110, 1, 2, USB_PORT_BACK_PANEL }, + { 0x0040, 0, USB_OC_PIN_SKIP, USB_PORT_SKIP }, + { 0x0040, 0, USB_OC_PIN_SKIP, USB_PORT_SKIP }, + { 0x0040, 1, 4, USB_PORT_BACK_PANEL }, + { 0x0040, 1, 4, USB_PORT_BACK_PANEL }, + { 0x0040, 0, USB_OC_PIN_SKIP, USB_PORT_SKIP }, + { 0x0040, 0, USB_OC_PIN_SKIP, USB_PORT_SKIP }, + { 0x0040, 1, 6, USB_PORT_BACK_PANEL }, + { 0x0040, 1, 6, USB_PORT_BACK_PANEL }, };
- *pei_data = mainboard_pei_data; /* FIXME: Do not overwrite everything */ + struct usb3_port_setting usb3_ports[MAX_USB3_PORTS] = { + /* Enable, OCn# */ + { 1, 1 }, + { 1, 1 }, + { 0, USB_OC_PIN_SKIP }, + { 0, USB_OC_PIN_SKIP }, + { 1, 3 }, + { 1, 3 }, + }; + + memcpy(pei_data->usb2_ports, usb2_ports, sizeof(usb2_ports)); + memcpy(pei_data->usb3_ports, usb3_ports, sizeof(usb3_ports)); }
Tristan Corrick has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/43111 )
Patch Set 5: Code-Review+2
Angel Pons has submitted this change. ( https://review.coreboot.org/c/coreboot/+/43111 )
Change-Id: Iee5ca6188de4cea9393efb66baa089969353b4e6 Signed-off-by: Angel Pons th3fanbus@gmail.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/43111 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Tristan Corrick tristan@corrick.kiwi --- M src/mainboard/supermicro/x10slm-f/romstage.c 1 file changed, 45 insertions(+), 45 deletions(-)
Approvals: build bot (Jenkins): Verified Tristan Corrick: Looks good to me, approved
diff --git a/src/mainboard/supermicro/x10slm-f/romstage.c b/src/mainboard/supermicro/x10slm-f/romstage.c index 6c12266..c1631b3 100644 --- a/src/mainboard/supermicro/x10slm-f/romstage.c +++ b/src/mainboard/supermicro/x10slm-f/romstage.c @@ -22,51 +22,51 @@
