Attention is currently required from: Furquan Shaikh, Julius Werner, Angel Pons, Karthik Ramasubramanian. Hello build bot (Jenkins), Furquan Shaikh, Julius Werner, Karthik Ramasubramanian,
https://review.coreboot.org/c/coreboot/+/56580
Change subject: commonlib/mem_pool: Allow configuring the alignment ......................................................................
AMD platforms require the destination to be 64 byte aligned in order to use the SPI DMA controller. This is enforced by the destination address register because the first 6 bits are marked as reserved.
This change adds an option to the mem_pool so the alignment can be configured.
BUG=b:179699789 TEST=Boot guybrush to OS
Signed-off-by: Raul E Rangel rrangel@chromium.org Change-Id: I8d77ffe4411f86c54450305320c9f52ab41a3075 --- M src/commonlib/include/commonlib/mem_pool.h M src/commonlib/mem_pool.c M src/lib/cbfs.c 3 files changed, 16 insertions(+), 11 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/80/56580/8
