Attention is currently required from: Hung-Te Lin, Yu-Ping Wu, cong yang.
Hello Hung-Te Lin, Ruihai Zhou, Yidi Lin, Yu-Ping Wu, build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/80198?usp=email
Change subject: mb/google/geralt: Increase VM18 LDO voltage to 1.9V for Ciri ......................................................................
The current panel voltage measured at mainboard side is 1.79V and the voltage at panel side is 1.74V. Since the panel requires 1.8V or more, increase the circuit voltage to 1.9V to meet the panel requirement. After adjustment mainboard side voltage is 1.89V and panel side is 1.84V.
BUG=b:322080023 TEST=Check ciri vm18 ldo voltage BRANCH=None
Change-Id: I6d6193d45409f53c0b656890c44ddaef253c5e01 Signed-off-by: Cong Yang yangcong5@huaqin.corp-partner.google.com --- M src/mainboard/google/geralt/panel_ciri.c M src/mainboard/google/geralt/regulator.c 2 files changed, 4 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/98/80198/6
