Saurabh Mishra has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/69883 )
Change subject: soc/intel/meteorlake: Select DISPLAY_FSP_VERSION_INFO_2 ......................................................................
Select DISPLAY_FSP_VERSION_INFO_2 for Meteor Lake soc.
BUG=TBD BRANCH=None TEST=Verify MTLRVP build with all the patch in relation chain and verify the version output prints no junk data observed.
Signed-off-by: Saurabh Mishra mishra.saurabh@intel.com Change-Id: I789db9d280c45639eca6ceafea65b96a93a395cf --- M src/soc/intel/meteorlake/Kconfig 1 file changed, 19 insertions(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/83/69883/1
diff --git a/src/soc/intel/meteorlake/Kconfig b/src/soc/intel/meteorlake/Kconfig index b8e4052..5ec2135 100644 --- a/src/soc/intel/meteorlake/Kconfig +++ b/src/soc/intel/meteorlake/Kconfig @@ -16,7 +16,7 @@ select CPU_SUPPORTS_INTEL_TME select CPU_SUPPORTS_PM_TIMER_EMULATION select DEFAULT_X2APIC_LATE_WORKAROUND - select DISPLAY_FSP_VERSION_INFO + select DISPLAY_FSP_VERSION_INFO_2 select DRIVERS_USB_ACPI select EDK2_CPU_TIMER_LIB if PAYLOAD_EDK2 select FSP_COMPRESS_FSP_S_LZ4 @@ -90,6 +90,7 @@ select TSC_MONOTONIC_TIMER select UDELAY_TSC select UDK_202111_BINDING +
config MAX_CPUS int
