Karthik Ramasubramanian has submitted this change. ( https://review.coreboot.org/c/coreboot/+/86169?usp=email )
Change subject: soc/intel/common/block/cse: Add API to match current PM event ......................................................................
Introduce an API to read the Converged Security and Management Engine (CSME) host firmware status register to obtain the current Power Management event and compare it with a specified input event.
BUG=b:391449110 TEST=Build Brox BIOS image and boot to OS.
Change-Id: Ie9a49382ee2c1a8f59da6233e510cf2e38ac32ad Signed-off-by: Karthikeyan Ramasubramanian kramasub@google.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/86169 Reviewed-by: Kapil Porwal kapilporwal@google.com Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Subrata Banik subratabanik@google.com Reviewed-by: Dinesh Gehlot digehlot@google.com --- M src/soc/intel/common/block/cse/cse.c M src/soc/intel/common/block/include/intelblocks/cse.h 2 files changed, 33 insertions(+), 0 deletions(-)
Approvals: Dinesh Gehlot: Looks good to me, approved build bot (Jenkins): Verified Kapil Porwal: Looks good to me, approved Subrata Banik: Looks good to me, approved
diff --git a/src/soc/intel/common/block/cse/cse.c b/src/soc/intel/common/block/cse/cse.c index 6389044..53c5fe1 100644 --- a/src/soc/intel/common/block/cse/cse.c +++ b/src/soc/intel/common/block/cse/cse.c @@ -298,6 +298,28 @@ return !hfs1.fields.mfg_mode; }
+#define ME_HFSTS2_CUR_PM_EVENT_SHIFT 24 +#define ME_HFSTS2_CUR_PM_EVENT_MASK (0xf << ME_HFSTS2_CUR_PM_EVENT_SHIFT) + +static uint8_t cse_get_hfs2_current_pm_event(void) +{ + uint32_t data = me_read_config32(PCI_ME_HFSTS2); + return (uint8_t)((data & ME_HFSTS2_CUR_PM_EVENT_MASK) >> + ME_HFSTS2_CUR_PM_EVENT_SHIFT); +} + +bool cse_check_host_cold_reset(void) +{ + uint8_t event = cse_get_hfs2_current_pm_event(); + + switch (event) { + case PWR_CYCLE_RESET_CMOFF: + return true; + default: + return false; + } +} + bool cse_is_hfs3_fw_sku_lite(void) { union me_hfsts3 hfs3; diff --git a/src/soc/intel/common/block/include/intelblocks/cse.h b/src/soc/intel/common/block/include/intelblocks/cse.h index c97e4ec..99dd7d5 100644 --- a/src/soc/intel/common/block/include/intelblocks/cse.h +++ b/src/soc/intel/common/block/include/intelblocks/cse.h @@ -383,6 +383,10 @@ CSE_RESET_ONLY = 3, };
+enum cse_fw_sts_current_pm_event { + PWR_CYCLE_RESET_CMOFF = 0xb, +}; + /* * Sends GLOBAL_RESET_REQ cmd to CSE with reset type GLOBAL_RESET. * Returns 0 on failure and 1 on success. @@ -618,4 +622,11 @@ */ bool is_cse_boot_to_rw(void);
+/* + * Check if the CSE FW Status Current Power Management Event indicates that the + * host came out of cold reset. + * Returns true if the host came out of a cold reset, false otherwise. + */ +bool cse_check_host_cold_reset(void); + #endif // SOC_INTEL_COMMON_CSE_H
