Hello Kyösti Mälkki, Aaron Durbin, Philippe Mathieu-Daudé, Paul Menzel, build bot (Jenkins), coreboot org,
https://review.coreboot.org/19386
Change subject: drivers/spi: Re-factor spi_crop_chunk ......................................................................
spi_crop_chunk is a property of the SPI controller since it depends upon the maximum transfer size that is supported by the controller. Also, it is possible to implement this within spi-generic layer by obtaining following parameters from the controller:
1. max_xfer_size: Maximum transfer size supported by the controller (Size of 0 indicates invalid size, and unlimited transfer size is indicated by UINT32_MAX.)
2. deduct_cmd_len: Whether cmd_len needs to be deducted from the max_xfer_size to determine max data size that can be transferred. (This is used by the amd boards.)
Change-Id: I81c199413f879c664682088e93bfa3f91c6a46e5 Signed-off-by: Furquan Shaikh furquan@chromium.org --- M src/drivers/spi/adesto.c M src/drivers/spi/amic.c M src/drivers/spi/atmel.c M src/drivers/spi/eon.c M src/drivers/spi/gigadevice.c M src/drivers/spi/macronix.c M src/drivers/spi/spansion.c M src/drivers/spi/spi-generic.c M src/drivers/spi/spiconsole.c M src/drivers/spi/sst.c M src/drivers/spi/stmicro.c M src/drivers/spi/winbond.c M src/include/spi-generic.h M src/soc/broadcom/cygnus/spi.c M src/soc/imgtec/pistachio/spi.c M src/soc/intel/baytrail/spi.c M src/soc/intel/braswell/spi.c M src/soc/intel/broadwell/spi.c M src/soc/intel/common/block/fast_spi/fast_spi_flash.c M src/soc/intel/common/block/gspi/gspi.c M src/soc/intel/fsp_baytrail/spi.c M src/soc/intel/fsp_broadwell_de/spi.c M src/soc/marvell/armada38x/spi.c M src/soc/marvell/bg4cd/spi.c M src/soc/mediatek/mt8173/flash_controller.c M src/soc/mediatek/mt8173/spi.c M src/soc/nvidia/tegra124/spi.c M src/soc/nvidia/tegra210/spi.c M src/soc/qualcomm/ipq40xx/spi.c M src/soc/qualcomm/ipq806x/spi.c M src/soc/rockchip/common/spi.c M src/soc/samsung/exynos5420/spi.c M src/southbridge/amd/agesa/hudson/spi.c M src/southbridge/amd/cimx/sb800/spi.c M src/southbridge/amd/sb700/spi.c M src/southbridge/intel/common/spi.c M src/southbridge/intel/fsp_rangeley/spi.c 37 files changed, 92 insertions(+), 119 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/86/19386/7
