Hello Felix Singer, Elyes HAOUAS, build bot (Jenkins), Nico Huber, Martin Roth, Patrick Georgi, Paul Menzel, Duncan Laurie, Stefan Reinauer,
https://review.coreboot.org/c/coreboot/+/45513
Change subject: lint: check for misuse of Kconfig SUBSYSTEM_*_ID ......................................................................
Check that nobody misuses the Kconfigs SUBSYSTEM_*_ID. They are meant to be used for overriding the devicetree subsystem ids locally but shall not be added to a board's Kconfig. Instead, the devicetree option `subsystemid` should be used.
Add a linter script for this that finds and warns about such misuse.
Also add a note in the Kconfigs' description.
TEST=CB:45513
Change-Id: I21c021c718154f1396f795a555af47a76d6efe03 Signed-off-by: Michael Niewöhner foss@mniewoehner.de --- M src/device/Kconfig A util/lint/lint-stable-024-kconfig-no-subsystem 2 files changed, 24 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/13/45513/6
