Angel Pons has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/38339 )
Change subject: nb/intel/sandybridge: Drop 'or zero' instances ......................................................................
Change-Id: Icd0dfdf311ac141992ec6a6026ca92e54e8d2094 Signed-off-by: Angel Pons th3fanbus@gmail.com --- M src/northbridge/intel/sandybridge/raminit_common.c 1 file changed, 6 insertions(+), 9 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/39/38339/1
diff --git a/src/northbridge/intel/sandybridge/raminit_common.c b/src/northbridge/intel/sandybridge/raminit_common.c index fc4e6f9..795775c 100644 --- a/src/northbridge/intel/sandybridge/raminit_common.c +++ b/src/northbridge/intel/sandybridge/raminit_common.c @@ -1771,8 +1771,7 @@ /* DRAM command RD */ MCHBAR32(IOSAV_n_SP_CMD_CTL_ch(channel, 1)) = 0x1f105; MCHBAR32(IOSAV_n_SUBSEQ_CTL_ch(channel, 1)) = 0x4041003; - MCHBAR32(IOSAV_n_SP_CMD_ADDR_ch(channel, 1)) = - (slotrank << 24) | 0; + MCHBAR32(IOSAV_n_SP_CMD_ADDR_ch(channel, 1)) = slotrank << 24; MCHBAR32(IOSAV_n_ADDR_UPD_ch(channel, 1)) = 0;
/* DRAM command RD */ @@ -1821,8 +1820,7 @@ /* DRAM command RD */ MCHBAR32(IOSAV_n_SP_CMD_CTL_ch(channel, 1)) = 0x1f105; MCHBAR32(IOSAV_n_SUBSEQ_CTL_ch(channel, 1)) = 0x4041003; - MCHBAR32(IOSAV_n_SP_CMD_ADDR_ch(channel, 1)) = - (slotrank << 24) | 0; + MCHBAR32(IOSAV_n_SP_CMD_ADDR_ch(channel, 1)) = slotrank << 24; MCHBAR32(IOSAV_n_ADDR_UPD_ch(channel, 1)) = 0;
/* DRAM command RD */ @@ -2562,8 +2560,7 @@ /* DRAM command RD */ MCHBAR32(IOSAV_n_SP_CMD_CTL_ch(channel, 1)) = 0x1f105; MCHBAR32(IOSAV_n_SUBSEQ_CTL_ch(channel, 1)) = 0x4041003; - MCHBAR32(IOSAV_n_SP_CMD_ADDR_ch(channel, 1)) = - (slotrank << 24) | 0; + MCHBAR32(IOSAV_n_SP_CMD_ADDR_ch(channel, 1)) = slotrank << 24; MCHBAR32(IOSAV_n_ADDR_UPD_ch(channel, 1)) = 0;
/* DRAM command RD */ @@ -2617,7 +2614,7 @@ MCHBAR32(IOSAV_n_SP_CMD_CTL_ch(channel, 1)) = 0x1f105; MCHBAR32(IOSAV_n_SUBSEQ_CTL_ch(channel, 1)) = 0x4041003; MCHBAR32(IOSAV_n_SP_CMD_ADDR_ch(channel, 1)) = - (slotrank << 24) | 0; + (slotrank << 24); MCHBAR32(IOSAV_n_ADDR_UPD_ch(channel, 1)) = 0;
/* DRAM command RD */ @@ -3069,13 +3066,13 @@ /* DRAM command WR */ MCHBAR32(IOSAV_n_SP_CMD_CTL_ch(channel, 1)) = 0x0001f201; MCHBAR32(IOSAV_n_SUBSEQ_CTL_ch(channel, 1)) = 0x08281064; - MCHBAR32(IOSAV_n_SP_CMD_ADDR_ch(channel, 1)) = 0x00000000 | (slotrank << 24); + MCHBAR32(IOSAV_n_SP_CMD_ADDR_ch(channel, 1)) = slotrank << 24; MCHBAR32(IOSAV_n_ADDR_UPD_ch(channel, 1)) = 0x00000242;
/* DRAM command RD */ MCHBAR32(IOSAV_n_SP_CMD_CTL_ch(channel, 2)) = 0x0001f105; MCHBAR32(IOSAV_n_SUBSEQ_CTL_ch(channel, 2)) = 0x04281064; - MCHBAR32(IOSAV_n_SP_CMD_ADDR_ch(channel, 2)) = 0x00000000 | (slotrank << 24); + MCHBAR32(IOSAV_n_SP_CMD_ADDR_ch(channel, 2)) = slotrank << 24; MCHBAR32(IOSAV_n_ADDR_UPD_ch(channel, 2)) = 0x00000242;
/* DRAM command PRE */
Paul Menzel has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/38339 )
Patch Set 1:
https://review.coreboot.org/c/coreboot/+/38339/1//COMMIT_MSG Commit Message:
https://review.coreboot.org/c/coreboot/+/38339/1//COMMIT_MSG@8 PS1, Line 8: Why was it there in the first place?
Felix Held has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/38339 )
Patch Set 1: Code-Review+2
probably for things to me some sort of uniform
Angel Pons has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/38339 )
Patch Set 1:
Ask the original authors of the code. In any case, it does not change the binary at all.
Frans Hendriks has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/38339 )
Patch Set 1: Code-Review+1
Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/38339 )
Change-Id: Icd0dfdf311ac141992ec6a6026ca92e54e8d2094 Signed-off-by: Angel Pons th3fanbus@gmail.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/38339 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Felix Held felix-coreboot@felixheld.de Reviewed-by: Frans Hendriks fhendriks@eltan.com --- M src/northbridge/intel/sandybridge/raminit_common.c 1 file changed, 6 insertions(+), 9 deletions(-)
Approvals: build bot (Jenkins): Verified Felix Held: Looks good to me, approved Frans Hendriks: Looks good to me, but someone else must approve
diff --git a/src/northbridge/intel/sandybridge/raminit_common.c b/src/northbridge/intel/sandybridge/raminit_common.c index 3e17328..4c36600 100644 --- a/src/northbridge/intel/sandybridge/raminit_common.c +++ b/src/northbridge/intel/sandybridge/raminit_common.c @@ -1771,8 +1771,7 @@ /* DRAM command RD */ MCHBAR32(IOSAV_n_SP_CMD_CTL_ch(channel, 1)) = 0x1f105; MCHBAR32(IOSAV_n_SUBSEQ_CTL_ch(channel, 1)) = 0x4041003; - MCHBAR32(IOSAV_n_SP_CMD_ADDR_ch(channel, 1)) = - (slotrank << 24) | 0; + MCHBAR32(IOSAV_n_SP_CMD_ADDR_ch(channel, 1)) = slotrank << 24; MCHBAR32(IOSAV_n_ADDR_UPD_ch(channel, 1)) = 0;
9elements QA has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/38339 )
Patch Set 2:
Automatic boot test returned (PASS/FAIL/TOTAL): 0/0/0
