Subrata Banik has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/30209 )
Change subject: soc/intel/common/block/lpc: create LPC_GET_DEV macro ......................................................................
Patch Set 2:
https://review.coreboot.org/c/coreboot/+/30209/2/src/soc/intel/common/block/... File src/soc/intel/common/block/lpc/lpc_lib.c:
https://review.coreboot.org/c/coreboot/+/30209/2/src/soc/intel/common/block/... PS2, Line 29: #if !defined(__SIMPLE_DEVICE__) : #include <device/device.h> : #define LPC_GET_DEV pcidev_on_root(PCH_DEV_SLOT_LPC, 0x0) : #else : #define LPC_GET_DEV PCH_DEV_LPC : #endif
would this be inherently taken care by: […]
right now we have a #define __SIMPLE_DEVICE__ guard at line 18 https://review.coreboot.org/c/coreboot/+/30209/2/src/soc/intel/common/block/...
this tells all PCH_DEV_LPC reference to go to simple device check in entire file.
problem is this file only complies to simple_device as we have guard above. after deleting tha guard, ramstage has started giving error as below (because of fetching code from !__SIMPLE_DEVICE__ in pch_devs.h)
CC ramstage/soc/intel/common/block/lpc/lpc_lib.o In file included from src/soc/intel/common/block/lpc/lpc_lib.c:27: src/soc/intel/common/block/lpc/lpc_lib.c: In function 'lpc_set_bios_control_reg': src/soc/intel/cannonlake/include/soc/pci_devs.h:26:30: error: initialization of 'pci_devfn_t' {aka 'unsigned in '} from 'struct device *' makes integer from pointer without a cast [-Werror=int-conversion] #define _PCH_DEV(slot, func) pcidev_path_on_root_debug(_PCH_DEVFN(slot, func), __func__) ^~~~~~~~~~~~~~~~~~~~~~~~~ src/soc/intel/cannonlake/include/soc/pci_devs.h:187:23: note: in expansion of macro '_PCH_DEV' #define PCH_DEV_LPC _PCH_DEV(LPC, 0) ^~~~~~~~ src/soc/intel/common/block/lpc/lpc_lib.c:179:20: note: in expansion of macro 'PCH_DEV_LPC' pci_devfn_t dev = PCH_DEV_LPC; ^~~~~~~~~~~ src/soc/intel/common/block/lpc/lpc_lib.c:183:29: error: passing argument 1 of 'pci_read_config8' makes pointer from integer without a cast [-Werror=int-conversion] bc_cntl = pci_read_config8(dev, LPC_BIOS_CNTL); ^~~
