Attention is currently required from: Angel Pons, Arthur Heymans, Felix Held, Krystian Hebel, Kyösti Mälkki, Michał Żygowski.
Nico Huber has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/77338?usp=email )
Change subject: device/pciexp_device.c: Fix setting Max Payload Size ......................................................................
Patch Set 19: Code-Review+1
(2 comments)
File src/device/pciexp_device.c:
https://review.coreboot.org/c/coreboot/+/77338/comment/b0187717_efe5701a : PS18, Line 596: unsigned int
All `pci_find_capability(dev, PCI_CAP_ID_PCIE);` calls were assigning a value to unsigned int (with […]
I have no strong preference. Though, in general, limiting the type also constraints the compiler in the choices of optimizations it can make. So `unsigned int` seems fine as long as there is no benefit to a human reader when using a fixed-width type (I see none, but can only speak for myself).
https://review.coreboot.org/c/coreboot/+/77338/comment/1b88f28b_c2ba7180 : PS18, Line 721: parent's
Shouldn't the root's (real one, not what `root` variable points to) Max Payload Size be limited here […]
pciexp_scan_bus() should be called for the next pair of parent and child after the loop below (line 760) is done with the current level. That should propagate it further up to the root port. pciexp_sync_max_payload_size() should only run on the upper-most level after *all* calls to pciexp_scan_bus() below a given root port are done.
